Harmonic balancer wont budge
So I rented the standard HB puller from Autozone. Got the bolts in as far as I could. Bolts were either junk or my dumbass crossthreaded them somehow but they flew out and stripped the threads in the HB.
Ok so on to plan B...3 jaw puller. It starts to budge but then I notice the dang center bolt is starting to freaking bend and the puller is about to slip off!!!
I watched all the videos ever and it looks like one good pop and then its just sliding off. Am I missing a step somewhere?
I really dont want to re-tap the holes as I have never done that before and we all know how tight it is in there.
Anyone have any good ideas besides rolling it out in the driveway and setting fire to it?
Thanks as always!
Perhaps, spritz the hub-snout juncture w/ favorite penetrating aka break-away oil.
Perhaps, center bolt "should" have a separate, discrete conical bushing that slips over the end of center bolt; while bushing's cone tip fits into crank snout's bolt hole ?
Perhaps, puller's center bolt-hole threads need some hi-pressure lube.
If you pull hard-enough on outer inertia ring, you'll tear its rubber bonds loose (ruining it); plan now to replace damper.
Suggest you Re-thread/chase the three bolt holes & replace bolts w/ fresh Grade 8. Return to pulling using those three bolts and stop using jaw-puller.
If you "smear" damage the face of crank's snout; that alone can prevent hub from sliding past it.
So I am not following what you mean with Perhaps, center bolt "should" have a separate, discrete conical bushing that slips over the end of center bolt; while bushing's cone tip fits into crank snout's bolt hole ?
Edit: I missed you have stripped threads. Maybe find some bolts that can be forced in the holes and still use the HB tool. I assume your HB is junk now anyway.
If the 3 bolts stripped the threads out of the balancer, you used the metric bolts that are normally supplied with the tool. Try installing the tool as shown in my article here using the correct thread size bolts to see if they will "grip" on the remaining threads:
https://www.corvetteforum.com/forums...blem-post.html
Lars
Stephanie pulls a harmonic balancer off a chevy small block - YouTube
The puller tool looked so easy. Nope not for me...
depending on manufacturer, some fit Over end of center bolt, others (as pictured) fit Into end of center bolt.
* many puller kits include include more than one size thread bolt to fit those three holes in hub. Perhaps ya started off on wrong foot by choosing wrong size bolts ?
Do also ensure you have all the kit's moving bits greased up !
* when ya borrow or rent tools that were previously used /abused by rookies, you might be bringing home rotten tools; just sayin'
Lars
I just used a small 3 jaw puller to remove the crank sprocket and stuck a 7/16-20 grade 8 bolt & washer in the crank snout to give the puller's screw/bolt something safe to land on. You said the HB is toast anyway so if you wind up trying to use a larger 3 jaw puller and some heat I'd do that. It would suck to get the HB off only to find you boogered up the snout's threads. Incidentally, if you need to do the crank sprocket too I used that same Proform kit and a 2" section of old pipe I had laying around as a spacer to install the new sprocket. Put in the oven @ 350 for a half hour first and it slipped right on with virtually no effort - and no hammers.
Of course, since you very well might be using a torch on it you might have had the right idea right out of the gate. What's it insured for?
? Did You remove the damper's hex-head retaining bolt; that threads into crank's snout ?
as an aside:
The cheap-azz china ProForm install tool Not recommended. Years ago, New tool's first push snapped threaded tip off in crank snout. Garbage. Returned to ProForm and received No refund; but rec'd a replacement of SOS.
Upon that failure, immediately ordered a real tool from BHJ $$$, but worth every penny. I rarely loan gaging/tools; but, with a warning, have lent that crap ProForm out a couple times.
BHJ install tool P/N HD-1 is rock-solid and performs flawlessly; smooth as butter. Sadly, learned BHJ has recently ceased production of its automotive performance lines; thanks for the best of the best !
as an aside:
Install tool not much help getting one out. Proform tool worked great pulling for me and from what I see looks higher quality than the cheap ones loaned out by auto stores. I'll be careful when I use it to install though.
as an aside:
Yeah the crank bolt is out
When you purchase the new HB double check the diameter of the crank and the inside diameter of the HB.
The new HB may need to be bored to the correct hole size to fit properly onto the crank snout.
It’s something that should always be checked when installing a new HB so it goes on and comes off as it should without much force.
The biggest thing is to put moly on the threads of the puller........this is probably the most important thing.....don't fight the resistance of dry threads.....also, use an impact on the end to pop it from its frozen position.
Jebby
