HYDRATECH GROUP PURCHASE
Old Mar 14, 2003 | 09:57 AM
  #41
mpro71vette's Avatar
mpro71vette
Default Re: HYDRATECH GROUP PURCHASE GUIDELINES (Hydratech Braking)
:cool: Great price! Im in!
1972 LT1 Corvette/factory power/level III, I also have steeroids so I think I need longer hoses correct?
[Modified by mpro72vette, 12:33 PM 3/14/2003]
Old Mar 14, 2003 | 10:24 AM
  #42
mrvette's Avatar
mrvette
Default Re: HYDRATECH GROUP PURCHASE GUIDELINES (mrvette)
OK, just talked to Paul at hydrotech....yeh, I"m in for a 225 bux unit without lines.....I will have to fab up my own lines....but apparently everything else will bolt up.....
apparently...these units are plumbed IN SERIES with the power steering units....regardless of type....
in other words..it does from pump to brakes, to pwr steering rack....then leave the return line from the rack to the reservoir.....
or whatever steering system you have....
I had ASSUMED they would be plumbed in parallel....hummm....RONG!!!'
so I think this makes it easier....
GENE
Old Mar 14, 2003 | 11:42 AM
  #43
81vette's Avatar
81vette
I'm in for the Level III for my C3. :D
mark
Old Mar 14, 2003 | 11:43 AM
  #44
Weird Science's Avatar
Weird Science
count me in level II, no lineset for a kit to work with manual brakes. Thanks!
[Modified by Weird Science, 8:49 AM 3/14/2003]
Old Mar 14, 2003 | 01:11 PM
  #45
PureSilver's Avatar
PureSilver
I'm committed - model 3002. How soon can we order, let's get 20! :chevy
Old Mar 14, 2003 | 02:08 PM
  #46
Never Finished's Avatar
Never Finished
Default Re: HYDRATECH GROUP PURCHASE (Hydratech Braking)
I want in! I'll take the Level III for a '77 with steeroids. Do I need to sign up anywhere other than here?
My power assist is going out and this would be an excellent replacement. If you haven't read the VETTE magazine review, go to the Hydratech web site.
Old Mar 14, 2003 | 02:30 PM
  #47
71'AirStrike's Avatar
71'AirStrike
I dont think this would be a Hydroboost post without me chiming in and shamelessly plugging Paul, his great product, and Superior Customer Service!!
F.Y.I here is the tech link of a great How to install the Hydroboost.
https://www.corvetteforum.com/techti...=190&TopicID=3
cheers
chad
Old Mar 14, 2003 | 02:44 PM
  #48
Gordonm's Avatar
Gordonm
Default Re: HYDRATECH GROUP PURCHASE GUIDELINES (71'AirStrike)
I'll be in for a Level II system. I have manual brakes now. Can't wait for some good brakes
Old Mar 14, 2003 | 02:54 PM
  #49
mrvette's Avatar
mrvette
71'Air, I just talked to Paul, and yes, his act is together pretty good....he totally makes sense to me....only one thing...wish I had his press for making up weird hoses and such....;-)))
GENE
Old Mar 14, 2003 | 04:01 PM
  #50
ricketyray's Avatar
ricketyray
Level III Kit complete... 1973 Corvette / factory power brakes / rack and pinion steering conversion.
Thanks,
ricketyray
Old Mar 14, 2003 | 04:11 PM
  #51
Robert8096's Avatar
Robert8096
I am in if this will work with a steeroids system.
If so then put me down for a Level II Complete system - 1980 Corvette / factory power brakes / factory power steering
Old Mar 14, 2003 | 06:46 PM
  #52
'79ProwlerOrange's Avatar
'79ProwlerOrange
Sign me up for the level 2 complete kit. Factory PS/PB
and if/when i decided to go to steeroids, what is needed to make it work? :confused:
also is the $90 added to the complete kit or is that just for the Lineset-less kit? :confused:
[Modified by '79ProwlerOrange, 5:03 PM 3/14/2003]
Old Mar 14, 2003 | 07:44 PM
  #53
my74ls4's Avatar
my74ls4
Default Re: HYDRATECH GROUP PURCHASE ('79ProwlerOrange)
Put me down for a level 2 !!!!!!!
Old Mar 14, 2003 | 08:01 PM
  #54
Paul in Warren's Avatar
Paul in Warren
Default Defining the only Steeroids spec lineset difference...
Here is the deal on the Steeroids spec lineset difference, which is actually so minor that maybe it doesn't even count!? Maybe just a matter of taste or specific engine compartment needs only. View the pic of our regular lineset connected to the rack and pinion, it is illustrating the use of a regular production 90 degree fitting to connect to the rack inlet. Some customers have simply reported back that a 45 degree fitting may have suited them better...
So, when customers tell us they are installing our hydraulic brake assist system in conjunction with a rack and pinion conversion, we simply supply a 45 degree fitting on that end of the hose as opposed to a 90 degree fitting. It really is the only difference! Countless customers report back no real preference between the 2 fittings, stating that either one fits fine. I can just as easily supply either one based on your preference.
79ProwlerOrange - whaddaya mean? the master cylinder? If so, you can add a brand new Wagner master cylinder to any order for an additional $89.95 if you like.
Old Mar 14, 2003 | 08:12 PM
  #55
'79ProwlerOrange
Default Re: Defining the only Steeroids spec lineset difference... (Hydratech Braking)
*Add $89.95 for the addition of a brand new Wagner master cylinder to your order.
Maybe i just read it wrong... is that just if you want a brand new unit over a used one? or do you add that to every order?
thanks for the info on the rack & pinion that clears that up. :cheers:
Old Mar 15, 2003 | 12:23 AM
  #56
ridged84's Avatar
ridged84
Hurry ! Cut us a deal im looking to change over.
Old Mar 15, 2003 | 03:23 AM
  #57
WashingtonRacer's Avatar
WashingtonRacer
Default Re: HYDRATECH GROUP PURCHASE (ridged84)
I am really intested I have to wait about 2 weeks, I need to test fit some new headers first, as well as test fit the block :) But other than that, for the price, you can totally count me in. I also need to do my homework on which system level offers what? What happens if the power steering belt comes off? do the breaks still operate?
[Modified by WashingtonRacer, 8:25 AM 3/15/2003]
To HYDRATECH GROUP PURCHASE
Old Mar 15, 2003 | 08:54 AM
  #58
Paul in Warren
Default More info
CF group purchase deadline cannot be extended - the 28th is the last chance to enjoy these super savings! The suppliers have given in, but have firmly stated that they don't like it (!) and will not extend these savings into April. :nono:
Some general answers to some of your questions are:
Q: How do the pressure lines hook up?
A: You would remove your existing ps high side line, connect one of our braided stainless, direct fit, lines to the pump, then to the inlet / driver's side of the assist unit. Then you would connect the second braided stainless high pressure line from the passenger side of the assist unit, then route it down to / connect to the steering. The 3rd line is simply a low pressure return line (a heavy duty black rubber hose) that would run from the hose nipple on the assist unit, down to the T fitting you have spliced into your existing ps return line. That's it!
Q: What are the differences between the Level II and the Level III?
A: The Level III is the latest greatest design - ala 2003 - featuring an ever so slightly refined operation, and is also BRAND NEW. The Level II is also a stellar unit, but is of a mid nineties design and is just ever so slightly less refined in its operations by comparison to the Level III. You actually would have a hard time telling the 2 apart in back to back test drives, under most circumstances. So, basically: brand new vs high quality remanufactured. Visually, both levels are of the same show quality appearance. Both are covered by the same one year warranty against defects in materials and workmanship!
Q: What happens if the engine stalls or you suffer a ps belt failure?
A: This, right here, is the primary reason why the Level I has been discontinued. All systems now feature the nitrogen charged pressure accumulator / bottle on the side of the unit. This simply stores up enough pressurized ps fluid to offer up to 2-3 assisted brake applications in the event of engine stall / belt failure. It acts just about how a properly functioning vacuum brake booster would act in the same situation. The minute you start the engine back up again, the accumulator "charges back up" with pressurized ps fluid and is ready for next time.
Q: Can I use my current / original type master cylinder?
A: Yes! Our systems are designed to work with your original master cylinder, so long as it is in 100% proper condition. When in doubt, purchase a new one from us for $89.95 or from your local supplier. The manual brake upgrade kit does function well with the original manual spec master cylinder, though the installation of a power brake spec master cylinder with its 1/8th larger bore size will provide an ever so slightly tighter pedal response.
Q: When can I place my order? How can I pay?
A: As soon as 20 committed purchasers have been placed on the list, you can call in your order at 586-531-2115 (during normal business hours - eastern standard time) stating that you are a verfifiable CF Member, and that you are part of the group purchase. We accept Visa, Mastercard, Discover, Amex, Paypal and checks / money order. Please allow up to 2 weeks for shipment of your order. The window for these savings will remain open until the 28th of March deadline!
When you post that you are in on the deal, please also include your year, make, model, factory manual or power brakes, factory or rack and pinion steering, and indicate the kit level you are interested in - thanks! :cheers:
[Modified by Hydratech Braking, 1:00 PM 3/15/2003]
Old Mar 15, 2003 | 12:17 PM
  #59
WHTSHARK's Avatar
WHTSHARK
Default Re: More info (Hydratech Braking)
Sign me up! I need the complete level#2. whats 395.00 if it saves your **** just once. :yesnod:
Old Mar 15, 2003 | 12:35 PM
  #60
Paul in Warren
Default Re: More info (WHTSHARK)
WHTSHARK - you are going to love the system! Your profile says that you own a 1970 Corvette convertible. Are you factory manual or power brake equipped? Stock power steering? Let us know...
