[PICS] New engine is in!!
Old Jan 26, 2005 | 12:01 AM
  #61
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Originally Posted by Homie
Grandsport---
I thought you already put a new AR Racing engine in awhile back? Am I remembering correctly? If so, what happened to that one, and who built this one? What are specs on this one?
I bought my last AR engine about 3.5 years ago.. Pulled it a few months ago and sold it to isoceless. My new engine is also built by AR Racing and it is a solid roller 406, fully forged short block with all lightweight components, Dart Pro 1 heads (fully ported), 11.71:1 compression, solid roller cam with .672 lift and 264/270 degrees .050 duration....
Old Jan 26, 2005 | 12:03 AM
  #62
GrandSportC3
Originally Posted by Schmucker
You're not thinking like a racer... don't expect anything to work perfectly forever...
I can't see what should go wrong with headers?? I'm not going to convert to a regular exhaust system... and the Hooker sidepipes are the best available sidepipes...
Old Jan 26, 2005 | 12:06 AM
  #63
GrandSportC3
Originally Posted by norvalwilhelm
How would you hear if anything is wrong with open exhuast?? YOur engine was dynoed before???
I believe in a full exhuast for firing a motor so I can hear if something doesn't sound right and shut down before something get too galled.
Looking good
I also like my hearing and too much running around with open side pipes will destroy your hearing. The big questions is how soon, not will it???
The engine was dyno tuned by AR before they shipped it to me.. Even with open exhaust I can hear if something is wrong.. I've driven over 40k miles with 2 different 383 powered Vettes with open exhausts... and my hearing is still fine...
Old Jan 26, 2005 | 12:09 AM
  #64
GrandSportC3
Bronze also deposits itself in your oil. After numerous changes I contacted comp cam and found out I could run the stock hard steel gear.
Then why do they supply the bronze gear with their cams??
Mark from AR told me to run the engine for 15 minutes to break in the bronze gear and then chainge the oil because it'll be full of shavings from teh bronze gear...
Old Jan 26, 2005 | 12:12 AM
  #65
GrandSportC3
If you are using this car on the street and it sound like it how can you get away with open pipes, What about noise pollution, your hearing and annoying everyone else. Open exhausts have no place on the street.
Hope you don't have to open a window.
I've driven 40k miles with open exhaust and have never gotten any tickets
Gotta love Florida . In any other state, they'd probably arrest me ...
Well - I also drove around Bowling Green without getting arrested
Unfortunately - there are no mufflers that won't cost HP.. so I'll stick with open exhaust... I'm a racer and every 1/100 second counts
Old Jan 26, 2005 | 12:14 AM
  #66
GrandSportC3
Another good idea is installing studs in the valve covers, well not in the covers but in the head. 1/4 inch extra long set screws screwed only finger tight in the head makes installing valve covers really easy.
Slide the gasket over the studs, holds perfectly, install the cover and use self locking nuts and small washers.
Gaskets never slip.
That's the way my valve covers are set up!! Got the studs and the wing bolts are screwing to the studs!!
Old Jan 26, 2005 | 12:15 AM
  #67
GrandSportC3
Originally Posted by yellow 72
And do you know what serious racers think about guys cruzin' around the streets with uncapped headers?
I don't know any racer that would object to driving my open exhaust Vette on the street...
Old Jan 26, 2005 | 12:21 AM
  #68
jimvette74's Avatar
jimvette74
I live in oklahoma. We have no state inspections,no emmissions laws, If you outrun the cops they dont show up at your door next day -and if they do it's to collect for ther charity fund( you'd better give) but if they see you three times on the same street thay will ticket you for Cruzen the bulivard. God bless the south.
Old Jan 26, 2005 | 12:23 AM
  #69
GrandSportC3
Old Jan 26, 2005 | 12:28 AM
  #70
jimvette74's Avatar
jimvette74
PS You can't hear me over the tuner Honda's sterio thumping anyway.
Old Jan 26, 2005 | 02:37 AM
  #71
Twin_Turbo's Avatar
Twin_Turbo
Have you checked out Stahl sidepipes??
Old Jan 26, 2005 | 03:13 AM
  #72
Bangkok Dean's Avatar
Bangkok Dean
Originally Posted by 81' Corvette Guy
Yeah they would not notice till he drove by and scalded all the bicyclist... with those sidepipes!
More like motorbikes here, but I have to be carefull when passing a heard of Elephants.
Old Jan 26, 2005 | 07:46 AM
  #73
GrandSportC3
Who sells the Stahl pipes? What's the header pipes diameter? Sidetube diameter?
Old Jan 26, 2005 | 07:55 AM
  #74
Twin_Turbo's Avatar
Twin_Turbo
Stahl sells them of course:
http://www.stahlheaders.com/
Those are about the best headers money can buy
http://www.stahlheaders.com/Frame%20New%20RR.htm
Old Jan 26, 2005 | 09:01 AM
  #75
GrandSportC3
Those Stahl pipes look good! I wonder if there's any performance difference to the Hookers.. Are the Stahls available chrome plated? Didn't see them offering them with chrome plated finish...
Old Jan 26, 2005 | 09:10 AM
  #76
Twin_Turbo's Avatar
Twin_Turbo
Don't know, they are ceramic coated, maybe they offer chrome plating as well. Those stahls are the best on the market, they will almost certainly outperform the hookers.
Old Jan 26, 2005 | 09:34 AM
  #77
GrandSportC3
I might consider those for the future..but I'd need chrome plated finish...
A chrome bumper shark needs chrome pipes
To [PICS] New engine is in!!
Old Jan 26, 2005 | 09:48 AM
  #78
Twin_Turbo's Avatar
Twin_Turbo
These are the stahl pipes:
Old Jan 26, 2005 | 09:50 AM
  #79
Fevre's Avatar
Fevre
That vette looks like mine.
Old Jan 26, 2005 | 09:52 AM
  #80
Twin_Turbo's Avatar
Twin_Turbo
....from a distance
