C4 Exhaust thread
Old Dec 14, 2009 | 12:14 PM
  #61
Wayne Pennell's Avatar
Wayne Pennell
Default Resonance??
Newbie here and am wondering what is resonance?
Also I am looking to dress up the rear of my 91 Coupe, it looks to have stock mufflers on am interested in something a bit nicer to replace them with. Having a high performance boat with BBC engine, I am very familiar with Corsa products and would recommend them for anyone in the boating world. How are they on automotive products? Second question, where is the best place to purchase exhaust products....is there a Forum Sponsor?
Old Dec 15, 2009 | 01:06 AM
  #62
dogfish246's Avatar
dogfish246
Resonance- Acoustics Intensification and prolongation of sound, especially of a musical tone, produced by sympathetic vibration.
Pretty much it is the drone noise that you hear in the interior of your car that can give you a headache. It is a certain frequency of noise that is usually found around 2000-3000 rpm range. Hard to explain, easy to recognize! Pretty much, Corsa is the only exhaust that will give you no (minimal) drone. All the others will give you some drone; some worse than others. The resonator is supposed to limit the amount of drone/resonance in your Vette, and it does work to a certain degree.
Hope this clarifies what resonance is...
Old Dec 26, 2009 | 12:56 AM
  #63
94lt1vette94's Avatar
94lt1vette94
I really like the sound of the chambered corvette central exhaust video posted in the OP. I think I'm going to go to the local shop and have 2.75 straight pipe welded in place of the mufflers and I'm not sure if I want just an x pipe or a magnaflow center res w/ x pipe. Any suggestions?
Old Dec 26, 2009 | 11:06 AM
  #64
RedLS1GTO's Avatar
RedLS1GTO
Stainless long tube headers, 3 inch exhaust with a Dr Gas X-pipe and Flowmaster mufflers.
At idle:
Old Dec 27, 2009 | 11:14 AM
  #65
McGirk94LT1's Avatar
McGirk94LT1
I got a kinda out there question. I bought the magnaflow muffler set on my 94(part 15623 i think?) and had the exhaust shop make me a cat back to connect with it. Horrible resonance honestly considering i drive it literally everyday. Then had an x pipe installed and it quieted it down a bit and cut resonance a little. Just worried if i installed full headers and bullet cats its gonna be way too loud. So anyone have any experience switching from an x pipe to magnaflows dual in/out resonator/xpipe? with or without headers?
Old Jan 6, 2010 | 10:13 PM
  #66
94lt1vette94
I was getting the c4 aligned the other day, and I asked the guy about what he thought of my exhaust plans. I told him that I wanted to replace the mufflers with straight pipe and replace the center res with an x pipe. He said it would sound awful and that I should put flowmasters on. Any comments?
Old Jan 7, 2010 | 12:35 AM
  #67
Rex Ruby's Avatar
Rex Ruby
Philly 'Burbs Events Coordinator
Originally Posted by dubin4life
Muffler Eliminators
The lows:
-Resonance!
Untrue
Old Jan 7, 2010 | 12:37 AM
  #68
Rex Ruby's Avatar
Rex Ruby
Try it, you always add mufflers.
That is exactly what I have on my ZR1 and it is outstanding
Old Jan 7, 2010 | 02:10 AM
  #69
McGirk94LT1
I think alot of exhausts are stereo typed (but true) to certain cars. AKA flowmaster=mustangs, SLP=camaro/transam, corsca/magnaflow=C4. Though certain random combinations of headers, midpipes or resonators, and mufflers do sound amazing.
Old Jan 7, 2010 | 02:55 AM
  #70
Eakster's Avatar
Eakster
Here's a couple of short flybys of my LT4 with muffler elims and the stock resonator. Also stock headers and cats. So you can get an idea of the sound in normal driving, if you're thinking about doing it
Old Jan 7, 2010 | 04:40 AM
  #71
GREGG-73's Avatar
GREGG-73
This is a great thread, with many great response's / opin's. This should open up a lot of minds when trying to figure out cost vs sound produced / wanted.
I have had both the Billy Boat's and the Corsa systems. Both systems were on ZR-1's (no headers). I prefer the Corsa's....the sound is unmistakable and are indeed fully functional. They have the more European raspy sound (Ferrari /Lambo) to them as opposed the low drone of the B&B's. I felt my B&B's made my car sound more like a boat, than a car, no pun intended. Both are nice systems, I guess its what the owner is really after, performance / sound quality or both, that will detemine his purchase. As for the home made systems on here, they are definitely an option if you have the shop or can do most of the work yourself....and definitely worth the monies!
I do have one question....Somewhere on another thread, I read that Corsa does not produce the stamped outlet's (the exhaust tip with Corsa on the top) any longer. Is this true and if, it is, when did they stop?
Stay in tune....
Old Jan 7, 2010 | 09:40 AM
  #72
Donne Trav's Avatar
Donne Trav
Default Questions??
Informative thread. I've been wanting an aftermarket exhaust for a while. Most interested in a Corsa system. My question: How do you select the pipe size? I've seen sizes from 1 7/8" to 3"s. I have a stock LT1. Strickly street-no racing. What size is suitable for me. Also, cat or no cat? Is the word "cat", as its refered to, the catalytic converter or a
muffler of some sort or something totally different? I need to know if I
need this as I reside in D. C. THANKS
Old Jan 7, 2010 | 10:04 AM
  #73
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Cat=catalytic Converter. Pre cats on the L98 are the cats in the front Y pipe before the maincat.
Corsa sells their systems as a complete system, for the C4 and probably most vettes, from the cats back. This is from Corvette Central just select the appropriate system for your car. I am not promoting CC, just using them as an example.
I don't know if you can purchase just part of the system or not. I know I haven't found just the mufflers for my L98. It's the complete system or nothing. magnaflow does sell just the mufflers for the LT1 for $415.00. And IMO just as good in both looks and quality of the Corsa. I have listened to video after video of every muffler I can find on youtube and I always go back to the Magnaflows for the sound I like.
something else I might add is that from my research on an LT1 your only going to get a a fraction of performance increase if any. Seems the LT1 and beyond had a pretty good stock system.
Heres the link
http://www.corvettecentralexhaust.co...ance_corsa.php
Oh, you can also listen to magnaflows on CC's website.
Old Jan 7, 2010 | 10:41 AM
  #74
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
Here's my custom magnaflow system. 3" magnaflow cats, 3" X-pipe, 3" magnaflow 14" oval mufflers. It was almost a week before I turned the radio back on.
Old Jan 7, 2010 | 11:35 AM
  #75
darkstallion_69's Avatar
darkstallion_69
I just want to make it clear that the Billy Boat Exhaust systems do not sound good on camera! There tone is too deep for a camera to accuratly produce. I have the 3 inch Billy Boat Exhaust without a resonator and it sounds amazing. It has a deep muscular tone at idle and at WOT it stays deep. Without a resonator I get no resonance. Which is wierd when I had the stock resonator the system was quieter and had resonance from 1700 rpm to like 2500 rpm. I love my Exhaust and the sounds turn heads everywhere I go.
Old Jan 7, 2010 | 11:51 AM
  #76
darkstallion_69
Originally Posted by wolverine1967
But, the Corsas and Billy Boats really caught my eye when I was looking for exhaust systems.
I ended up going with the Billy Boats because they seemed to have a lower "muscle car" sound to them. The Corsas seemed a bit louder.
Now that I have my Billy Boats - I'm kind of sad that they aren't louder. I kind of expected a bigger sound out of them.
Anyway, I love the looks of the Billy Boats and I went stainless - so I'm going to have these puppies for awhile.
This thread is looong overdue and a great start. I agree with above. I searched and searched and ended up going with the B&B 3" for my 95 vert and overall I am very satisfied. Yes they do have drone around the 1500 range but only and only when there's a low strain on the trans. If you switch to D vs OD (auto) there's barely any noise inside. Looks and stainless is why I went with the B&B and was happy to see the quality of the build when they came. Fit perfectly with no mod needed.
I was happy with the new lower old school muscle car sound but was surprised that they weren't louder outside (not much more than stock). The deep tone is a thing of beauty though and what an American car should sound like.
One of peeves about most of these exhaust discussions is about the resonance. If you don't want to hear your exhaust, save your money and stick with the more than adequate stock system. If you want power, put that money into your engine. I personally love the look and sound of the B&B and got it on sale from MidAm for 900 shipped.
Do you have a resonator on? When I took off my resonator all the resonance I had from 1500 to 2500 rpm dissapeared. Aside from that the resonator would quiet down my exhaust after 3000 rpm. Now without it I have no resonance and it produces a constant band of sound. And my oh my is it deep as hell. I love it.
Old Jan 7, 2010 | 11:58 AM
  #77
3D-Aircrew's Avatar
3D-Aircrew
Default What is a cat back system
I know it has a catalytic converter but how is is different than a normal system?
To C4 Exhaust thread
Old Jan 7, 2010 | 12:13 PM
  #78
shakedown067
A cat back system bolts from BEHIND the cats and replaces everything from there to the tips. Other systems will just replace mufflers and may not be bolt on. Most cat-backs are a bolt on affair.
Old Jan 7, 2010 | 12:17 PM
  #79
RetiredSFC 97
A cat back system is the part of the exhaust that goes from the cat back to the the exhaust tips. That is why it is referred to as Catback.
On the early C4 it is this
http://www.parts123.com/parts123/yb.dll?parta~partsort
On the 92 to 96 it is this
Old Jan 7, 2010 | 05:43 PM
  #80
94lt1vette94
Does anyone on here have experience with flowmaster super 40's, super 44's, and/or 2 chamber 40's? I think I might pair these with an x pipe in place of the center res
