Jake
Old Dec 25, 2010 | 12:44 PM
  #81
Pete K's Avatar
Pete K
I am terribly sorry Ryan.
Your dad and I shared alot of technical views regarding these builds. I am no expert, but will offer anything I can to assist with your project.
Old Dec 25, 2010 | 08:42 PM
  #82
larry93lt1's Avatar
larry93lt1
From: Gaithersburg MD A member since 2007 but then the computer crashed and then the car crash loss of memory X 2
Originally Posted by corvetteronw
Aw jeez. It really hurts to lose one of the good guys here.
My prayers are with you and your family.
Can you post a picture of him? All I have ever seen is the one in his avatar.
I know he was always damn proud of you.
Ron that is a bit of an understatement. Jake exuded pride in Ryan, and now Ryan will do the same in everything he does, not that he hasn't already.
Heck take a look at the pic with them together. The light didn't come from the sun, it came from Jake's smile.
Old Dec 26, 2010 | 01:03 AM
  #83
fc_soldier's Avatar
fc_soldier
Sorry to hear about this Ive talked to your father and hes a linked friend of mine in Corvetteforum. I hope you stay in touch with our corvette family on here.
Old Dec 26, 2010 | 02:12 AM
  #84
slickfx3's Avatar
slickfx3
Your dad kepted his cool and was cool....
Old Dec 26, 2010 | 03:43 AM
  #85
prinzSD455's Avatar
prinzSD455
Finalist 2020 C4 of the Year - Unmodified
My prayers go out to you and your family.
Old Dec 26, 2010 | 10:01 AM
  #86
Red 91's Avatar
Red 91
prayers from my family to yours
Old Dec 26, 2010 | 07:22 PM
  #87
helphos's Avatar
helphos
Default Jake
Ryan- My condolences go out to you. As others have stated, he was very proud of you. I have children who recently finished college, and I am so proud of them and the way they turned out, I can truly understand how your dad felt.
As you finish your car, draw up a rough plan or schedule, so that we can provide ideas and help as you proceed. I think we'd all look on it as a privilege to help you as your dad would have liked to have done.
I honor your military service. You sound like a wonderful living tribute to the values your dad stood for.
All the best to you.
Paul
Old Dec 26, 2010 | 08:46 PM
  #88
Epimax's Avatar
Epimax
Prayers go out to you and your family..
So sorry for your loss...
Old Dec 26, 2010 | 10:06 PM
  #89
dizwiz24's Avatar
dizwiz24
sorry to hear about this. One thing that he made us all sure of, from his discussions here, was that he was proud of you.
Hes such a valuable resource here on this site ! I miss him.
Old Dec 26, 2010 | 11:52 PM
  #90
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
real sad to hear about your dad, Ryan. I spoke to your dad a few times and had long conversations about all kinds of things. I know he was very proud of you. Our prayers are with your family.
Old Dec 27, 2010 | 12:01 AM
  #91
87 vette 81 big girl's Avatar
Ryan,
I am sorry about the loss of Your Father.
I always looked forward to his posts back.
I learned from him also.
He was a Corvette Fanatic and had much knowledge and experience to share with all us here on Corvette Forum.
We will all miss greatly.
He was indeed very Proud of You and your acomplishments.
You will have all the help you need to finish that engine build.
I will gladly help out any way I can.
The rest here will too.
Brian R.
Old Dec 27, 2010 | 03:53 AM
  #92
Doughboy2k3's Avatar
Doughboy2k3
Your father has many friends on this forum and has helped many people with his knowledge. Just a few weeks ago I PM'd him and he gave me great advice on steps I should take prior to firing my new engine.
Below is the PM your father sent me. You can use in when you fire your new engine one day. -Walt
Hi, Walt.
Here are my thoughts and how I do mine:
First off, of course, the lifter preload has to be properly set. I strongly recommend the IC/EO method. If the preload isn't right the engine will have a really hard time running, that is if it'll run at all. So that's crucial.
Many guys don't prime the oiling system well enough. You should use an oil priming tool attached to a 1/2" drive electric drill and prime the system until oil comes for all 16 rocker arms.
This will take some time and will also require you to manually turn over the engine many times in order for oil pressure to reach all the lifters, then pushrods and finally rocker arms. As it does that the priming will force all the air out of the oil galleries.
Prime, prime, prime and when oil is seen coming from a rocker arm keep priming until not air comes out along with that oil. You want to force out all the air.
Then turn the engine over - manually - a very little, maybe 1/8th turn - and begin priming some more. Keep repeating that until all the rockers are flowing oil with no air bubbles.
While priming, have someone keep a look out for any oil leak.
A 1/2" drill will be needed because a 3/8" drill will over-heat. Also, don't use synthetic oil for the break-in. Rings seat quicker and better by using good old dyno oil.
Once the oil system is well primed, it's time to install the distributor which I always do as follows:
I remove the #1 spar plug, then either manually or with a bump starter turn over the engine while detecting when the #1 piston is on the compression stroke. If I'm alone, I stick a piece of toilet paper/paper towel in the #1 spark plug hole.
Using the starter, I bump the engine until the cylinder pressure forces out the paper/towel. With a helper, I let him/her turn the ignition key and do the bumping. While doing that I have my finger in the #1 hole and feel for compression building.
The ideal position is for the timing mark on the balancer/damper to stop somewhere between 4 and 10 degrees BTDC. Our engines need some amount of timing advance in order to start and run immediately.
So, now we have the timing mark aligned with between 4 and 10 BTDC on the COMPRESSION STROKE, time to drop in the distributor.
When you do align the rotor tip with the distributor cap's #1 terminal. As you probably know, the #1 terminal in the distributor cap can be anywhere - the engine doesn't know or even care. Just as long as all the other wires are in the proper sequence 1, 8, 4, 3, etc.
This most often requires aligning the distributor with the oil pump drive shaft.
Some guys use a long screwdriver to turn the oil pump drive rod so it properly aligns with the distributor. Others do as I do and just drop in the distributor to as far as it will go then just bump over the engine using the starter. At some point the distributor and oil pump drive rod will align with each other and the distributor will drop all the way down, flush with the intake.
Install the hold down clamp and make all the electrical connections to the distributor.
I prime the fuel system by turning the ignition key on, off - wait - on, off - wait - etc. I attach my fuel pressure gauge to the Schrader valve location so I can visually monitor the fuel pressure wile doing this.
Fill, top off the coolant; check for any tools, rags, etc. that may be in the way. I then look at all my connections, hoses, etc., to make sure none has been left disconnected.
I DON'T DISCONNECT THE BY-PASS WIRE. I leave it plugged in so the engine will get full timing once it starts. If the By-Pass is disconnected, the engine will only get a small amount of timing advance and will quickly overheat. If you're running headers they'll turn a new, cherry red too.
I DON'T DISCONNECT THE FPR VACUUM HOSE. Unless you have an adjustable FPR, there's no setting of the fuel pressure required or possible. Fuel pressure is automatically controlled by the regulator.
I DON'T DISCONNECT THE IAC.
If the lifter preload was set correctly and nothing was left disconnected, the engine should quickly fire and run.
FIRST THING TO CHECK IS OIL PRESSURE.
Immediately after seeing the reading check for any sign of a fuel leak. Now check OIL PRESSURE AGAIN. Then look for coolant temp and any sign of coolant leak.
Since you're running a roller cam, you can keep the engine RPMs on the low side - 1500/2000 - until you've verified no leak and good oil pressure. Vary the RPM to cause oil to be sprayed/splashed to all the internal parts of the engine.
WATCH OIL PRESSURE LIKE A HAWK!
IF YOU FIND ANYTHING AMISS, SHUT DOWN THE ENGINE TO ADDRESS IT. Don't try fixing it with the engine running. Shut down the engine, fix the problem, re-fire.
Once the engine will idle on it's own, shut it down, disconnect the by-pass wire and re-fire the engine. Set the base ignition timing to 6 degrees BTDC, which is the stock recommended setting. You can always play with that setting later once the engine is through with its teething-pains.
I always change my oil and filter right after the initial fire-up, timing setting, coolant top off, etc. If the engine's been run for, say, half an hour, that's long enough to me before putting in fresh oil and a new filter.
Once the engine has stabilized, has fresh oil, etc., I take it out for it's first drive. I find a roadway with minimal traffic and load and unload the engine to help seat the rings.
There are different opinions on break-in, here's how I do mine:
Half throttle in 2nd gear to 3500 or so, then release the pedal and let the engine pull down back to near idle speed, then I repeat that. I do that several times then increase my pedal pressure to, say 3/4 throttle to around 4000, always letting the engine pull down with no pedal pressure.
ALL THE WHILE WATCHING OIL PRESSURE LIKE A HAWK!
Hopefully everything will go smoothly, but don't be discouraged if there's hiccup or two. Newly built engines often go through their problems.
Let me know if I can help further. GOOD LUCK!
Jake
Old Dec 27, 2010 | 04:12 AM
  #93
Ant1981's Avatar
Ant1981
Ryan, my condolances go to you and your family.
Old Dec 27, 2010 | 10:42 AM
  #94
pcolt94's Avatar
pcolt94
Ryan, did not know you Dad personally but did see and read his posts for years. Sorry for your loss. He will be missed.
I lost my Dad this time of year many years ago who was my best friend and I grew up in the auto business with him. He was a wealth of information as was your Dad, so I have some understanding of your feelings. I inherited his tools and still have them. When I work on the cars, he is still with me and I think of him. God Bless.
Paul
Old Dec 27, 2010 | 11:09 AM
  #95
engle1147's Avatar
engle1147
We are going to miss him around here.
Old Dec 27, 2010 | 12:55 PM
  #96
TJM's Avatar
TJM
Originally Posted by JAKE
Hello everyone,
Thank-You for your time
-Ryan
He had everything Ryan... he had you.
Be strong.
TJM
Old Dec 27, 2010 | 01:03 PM
  #97
95wht6spd's Avatar
95wht6spd
Very sorry to hear of your loss.
To Jake
Old Dec 27, 2010 | 06:30 PM
  #98
eguyett1985's Avatar
eguyett1985
Ryan, my deepest condolences to you and your family in your time of loss.
Old Dec 27, 2010 | 07:55 PM
  #99
yedister's Avatar
yedister
Default Jake has passed on
I just received a call from Ryan, Jake's will not post on this forum anymore.
Old Dec 27, 2010 | 08:09 PM
  #100
STL94LT1's Avatar
STL94LT1
