Headlining!
Old Feb 4, 2012 | 03:48 AM
Chgperformance's Avatar
Chgperformance
Default Headlining!
The headlining on my c4 is drooping badly! How/what is the best way to sort it? The roof is fixed on mine, wish it was a targa top sometimes!
Cheers!
Old Feb 4, 2012 | 10:41 AM
pcolt94's Avatar
pcolt94
I did mine after years of pondering. First one in a vet that I as attempting to do. I read many posts and spoke to people and the information was all over the map. I did want to remove the foam and some people did have had luck not breaking it. But chances are and felt it would probably break and there are no replacements. So I decided to do a less perfect job than I wanted to for a trade off of not breaking it.
Since you can't take off the roof, I think it's still doable. Follow the same rules although it is going to be much more of a pain. Another set of hands would probably be very helpful.
What I found was the glue on the edges due to age was not very strong anymore so I was able to pull the fabric off carefully. After gluing it on, the edges tucked in remarkably well which was my concern. It came out really well and with it being in there, upside down with limited light, you can't tell I tucked the headliner fabric in. I did use some dabs of glue around the edge as I tucked it in.
You might actually need to make a structure to put pressure on the headliner (braced against seat) till the glue dries and then tuck the edges in as a last step in a 2 step process.
Here is my last thread on it. Cleaning the foam well is key as well as taking your time and measuring carefully. Used basic headliner glue and bought headliner from Jo-Ann's fabrics. Read other thread to see what other did.
http://forums.corvetteforum.com/c4-t...placement.html
Old Feb 4, 2012 | 10:56 AM
Kmcoldcars's Avatar
Kmcoldcars
As I recall all C4 Corvettes were either targa tops or convertibles. Take the targa off, lay it upside down on a table with cloth under the targa. Working carefully you can remove the glued cloth which is under the edges. I reglued mine with a spray adhesive, starting with the cloth folded back so I could spray 1/2 of the targa top. Then I did the other half. I then carefully sprayed glue to go under the edges, folded the edges under and put the top back on the car.
Old Feb 4, 2012 | 01:36 PM
HlhnEast's Avatar
HlhnEast
The targa does come off. If you didnt get the targa removal tool with your car, go to a tool store and buy a T40 torx bit (and associated drive wrench) at least 3" long to reach the front bolts. There is a hole in the A pillar fascia to insert the torx bit into.
An owners manual will help with the procedure. Its easy.
Old Feb 4, 2012 | 04:11 PM
ch@0s's Avatar
ch@0s
Old Feb 4, 2012 | 05:20 PM
nutz4c4's Avatar
nutz4c4
Originally Posted by ch@0s
Old Feb 4, 2012 | 05:27 PM
SQUIRMIN VERMIN 84's Avatar
SQUIRMIN VERMIN 84
From: Supreme Soviet Peace-Loving Pipple's Kollektive of Seattle Wa
WHAT????????????
Old Feb 4, 2012 | 05:45 PM
Jon Hekking's Avatar
Jon Hekking
Old Feb 4, 2012 | 05:57 PM
WW7's Avatar
WW7
You have one of the rare C4 "Fixed Roof Coupes" the best way to repair it is to flip the car over on its roof , this makes it much easier to get to...... ......WW
Vette Daddy's Avatar
Vette Daddy
Probably has the Z51FRC option.
Old Feb 4, 2012 | 06:02 PM
nutz4c4's Avatar
nutz4c4
This is the only way to repair this..
A very rare car indeed...
Old Feb 4, 2012 | 06:03 PM
Jon Hekking
Old Feb 4, 2012 | 06:37 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Old Feb 4, 2012 | 06:40 PM
nutz4c4's Avatar
nutz4c4
Originally Posted by PLRX
...does it come with tape????
Old Feb 4, 2012 | 06:48 PM
Jon Hekking
Pretty much put the death nail in this one so..............
Old Feb 4, 2012 | 06:56 PM
nutz4c4's Avatar
nutz4c4
Might as well drive in another one...
Old Feb 4, 2012 | 07:09 PM
dukeallen's Avatar
dukeallen
Weren't all C4s hardtops? I seem to recall the owner's manual included a small saw with mention of a dotted line on the roof...
To Headlining!
Old Feb 4, 2012 | 07:13 PM
nutz4c4's Avatar
nutz4c4
I think that is RPOsawzall12...
Old Feb 4, 2012 | 09:41 PM
ddahlgren's Avatar
ddahlgren
RPO999 targa delete 1of 1 hope no one painted the all clear body panels!
Old Feb 4, 2012 | 10:09 PM
C4fan's Avatar
C4fan
St. Jude '10
That would be the Headliners R us department.
