Really? We've got these bit's of "advice":
*Tarps on the floor.
*Over inflate the be-jeezus out of the tires
*Magic potions in the gas tank
*Rodent control
*Ritualistic placement of "Bounce" Dryer sheets.
*Battery rituals.
Of those (and all the gems yet to come)....what are they going to do, to "preserve" an old car....that a new car is immune to??
My 26 year old car gets an oil change and I fill the gas tank (with gas) before putting it away. Same with the boat. And the snowmobiles. And the snow blower...and lawn mower.... Been doing this routine for over 18 years. Where have I failed? Where the the "problems" that I've "insured" (sic)?
Geez, I didn't think this post was SO hard to understand.
*Rodent control
*Battery rituals.
Light a candle, place a silver bullet on the dashboard, and garlic in the ashtray! lol Seriously, I don't think and of these suggestions would cause damage, and some will actually help! No car ever died from fresh oil and fuel! Besides, my garage now smells freshly laundered!
Right? That's about what some of these ideas effectively amount to.
No? It's hard to understand or figure what parts of an old car would be more "vulnerable" to storage than the same parts on a newer car. Why would a new car be any more fit for storage than an older car? Is the gasoline in a new car more impervious to going bad and evaporation? Are the tires radically advanced so as to be able to avoid "flat spotting"? Is the engine oil special? Do mice prefer the wires of old cars, only? Of course none of that stuff is any different, new car or old. If you believe in any of the rituals suggested in this (and other threads), then they should apply to all cars, both new and old.
But I've been topping my gas tank and changing my engine oil before storage for decades. Therefore, I can't help but wonder what problems I've "insured" by that neglectful regimen? AFAIK, none. Car fires up and runs fantastic every year. Fastest stock LT1 in UT and this past spring I got it out of storage and ran the fastest drag track pass it's ever run here. No problems.
Again, I thank everyone for their input. It goes in the barn tomorrow. Sadly, upstate NY is no longer top off weather. I have topped her off and added stabil. Changed the oil and bought a box of bounce. I have a tarp to lay down on the stone floor and will undo the negative side if the battery.
That being said..... I’ll post up the results of all this effort in the Spring. Best to all this winter. Stay warm and thanks again.
No. They like new car wires just as well. Some better (Subaru with soy insulation, for example.) But where I live, rodent control is an issue. One of my cars, one of my son's cars and at least two friend's cars that I can think of have had wiring chewed by mice. And a motorcycle I had was temporarily disabled by mice storing acorns in the intake system. So I'd argue this rodent control thing with you til one of us turns blue.
Ill be there with ya.
In Michigan (where you would actually store a Corvette for winter), you better do something proactive about mice or you will be sorry, and that's all there is to it.
All kidding aside, our new neighbors have approximately 2 or 3 cats that they let run around outside. I was pretty upset about it at first, but now we are finding dead mice and ground moles laying around every once in a while. I'd rather have the cats get them instead of having to deal with them inside.
For myself, I don't store my car in a remote location, so I just set mouse traps and I'm diligent about maintaining them. I cant speak to all the other things people do to keep mice away, but traps work fine if you pay attention to them.
This is the "Boris Automotive Rodent Repellent" system. Boris operates 24/7, locks on to prey quicker than a Schwarzenegger Predator character and will curl up in your lap at the end of a patrol.
He looks like a dictator and despot.
He also looks like he will wipe out anything, and everything on the nearest table, if you leave the house.
I have read through the posts and find all good, even the humorous ones. I will be storing a new to me 1996 in an unheated garage for about 5 months in sub freezing temps. Other than what I've done; Stabil in a full tank, oil change, battery tender, wax and cover. Is it necessary or wise to start it monthly just to move some oil to the top end?
Since it isn't in my garage, I'd toss a cover.on it. I'll have it waxed in spring with the detail job if needed when I get it out.
I left a 99 turbo diesel in the field during the storage months since I needed it out of the driveway Hooked up battery, glow plugs and crank.
It's an excellent idea to start it monthly because it actually DOES move the oil around and keep things lubricated preventing dry seals and leaks. Also so the antifreeze/coolant gets moved through the entire system. Moving it around a bit is good to prevent flat spotting of the tires and the brake parts will keep loosened up. Covering it up will help keep it clean as well as protecting it from bumps and scratches that can occur in the garage. Parking it, forgetting about it, and not doing anything for many months on end may very well cause you a few slight problems. Unless you too have one of those magic cars that always start on the first crank, never leak oil, always run perfect no matter what and doesn't require any cleaning or detailing.
Bill, you have the exact cat I have! Looks identical in every way!
