11 seconds
Old Aug 15, 2006 | 06:33 PM
dagrump's Avatar
dagrump
Default 11 seconds
i'm interested in seeing if anyone has broke into the 11's with 355 cu. in. and a modified tpi i setup. no power adder. if so what combination are you running.
Old Aug 15, 2006 | 07:57 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I'll let you know soon
I built a 355 with a super ram intake but have yet to make it to a track. I don't forsee an 11 but hell, it could happen
Old Aug 15, 2006 | 08:24 PM
dagrump's Avatar
dagrump
what heads and cam are you running?
Old Aug 15, 2006 | 09:11 PM
TA's Avatar
TA
I sus pect that people have been in the 11s with such a set-up. Vic'89 ran a 12.00 his first pass with his heads/cam 350 that still retained the TPI style intake.
Old Aug 15, 2006 | 09:40 PM
sami85L98's Avatar
sami85L98
That's tough, might through a radical cam, a true dual exhaust with headers with No cats, drag radials, sway bar removed, skinny's on front, high stall TC, Emmission stuff removed, A/C/heater removed, pulleys, Low gears, spare tire delete, ..............but still its tough. Fingers crossed.
Old Aug 15, 2006 | 10:17 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Right Here Bottem 11s And Dropping Has A Converted 4 Bl Intake From Jeb Tho
Old Aug 15, 2006 | 10:31 PM
bjankuski's Avatar
bjankuski
11.81 at 114 MPH with 355 superram, 219 cam, headers, 3000 stall, 3.45 gears, dual exhaust, basically the same car as in my sig minus the 406 and ZZ-x cam.
Old Aug 15, 2006 | 10:53 PM
AKS Racing's Avatar
AKS Racing
11.91 on the old 350 with heavily ported 113 heads, TPIS 288/288HR12 cam, heavily ported SR, 58MMTB, 700R4 with Art Carr 3200 stall, 3.33 gears, slicks, skinnies, swaybar disconnect in '87 roadster. This was back in like '94, then started spraying it to 11.30's, but never could get a 10 sec timeslip.
Aaron
Old Aug 16, 2006 | 12:57 AM
AGENT 86's Avatar
AGENT 86
128 heads with some home head work and Comp cams CS XE262H-14 Lift In .464 Ex .470 Duration @50 In .218 Ex .224 with 1.6 rockers.
Old Aug 16, 2006 | 06:00 AM
93 ragtop's Avatar
93 ragtop
If you are talking about modifying the orig. TPI and not replacing it with a different brand etc., I think you are going to have a hard time getting it into the 11's especially on a street car. JMHO
Old Aug 16, 2006 | 09:21 AM
cv67's Avatar
cv67
St. Jude Donor '05
I think skatepark dave runs 12's with a stock TPI and some Nitrous.
Old Aug 16, 2006 | 04:42 PM
dagrump's Avatar
dagrump
Aaron
thanks for all the reply's.
Old Aug 18, 2006 | 07:32 PM
Vic'89's Avatar
Vic'89
Corky
Can you give us some details on this new setup you have ?
It is very impressive.
What heads and Cam ?
Vic
Old Aug 18, 2006 | 07:44 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In V Veteran
afr 195 heads that i touched up a little and a solid roller cam its preety small is all i can say about the specs on the cam
Old Aug 18, 2006 | 10:41 PM
85vet's Avatar
85vet
Cruise-In V Veteran
This is one sick motor, every time I see it run the d@mn thing runs faster.
To 11 seconds
