It's the washers!!
Old Oct 26, 2007 | 10:42 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Originally Posted by AGENT 86
Lubing the splines and more torque on the axle nut is the answer for the click.
No flames from me but I can tell you that I tried lubing the splines and re-torquing the nut. It worked for about a week then the noise was right back. With the exception of my labor, which is cheap I figure what little the washers cost it's worth a try.
Old Oct 26, 2007 | 10:58 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I await your results. I have been click free for a few years with just lubing and 200 lbs on the axle nut.
Old Oct 27, 2007 | 12:21 AM
Midnight 85
Maybe I'll try more torque, I've been going with the recommended 166 ft.lbs.
Old Oct 27, 2007 | 01:55 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Originally Posted by quickcat
You know... for doing just the washers you are right. The pictures are from when I did my u-joints and I was so used to pulling the half shafts I didn't think about just pulling the bearing out. Thanks.
Matt
You have to remove the bearing assembly no matter what.
If you stick the teflon washer on the spindle and shove it in there it will not fit past the dust seal without tearing it.
I think the washers are designed to slip and the coating is there to let it slip quietly. There's no way in hell that nut tighted down on a ~25mm threaded shaft is going to hold up against 300 ft lbs of engine torque multiplied times 10 through the gear ratios.
Old Oct 27, 2007 | 01:57 AM
CentralCoaster
Tried that and it hasn't lasted. It is galling the surface of the washer and spindle. Anti-sieze, grease, same thing. Hell I put a washer in one side this month and now the other started clunking!
You need to quit driving like a grandma.
Old Oct 27, 2007 | 08:24 AM
AGENT 86's Avatar
AGENT 86
I drive nothing like Grandma
Old Oct 27, 2007 | 11:09 AM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
Nice write up, but I don't see how the washer is the cure. The way I see it , is the washer is there so there is no metal to metal contact. Instead of the shoulder of stub and face of bearing unit taking the wear from friction caused by backlash, the washer is there taking the wear and is serviceable(replace).
As you say, the backlash is still there. Lubing the splines and more torque on the axle nut is the answer for the click.
Flame suit on
It just fixes it
The fact that some people cant understand why, including me, doesnt change that
Lubing the splines etc just covers up the problem
Old Oct 27, 2007 | 11:12 AM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
Please dont
That will only put more stress on the whole assembly and also cause more friction
The part= washer =costs about $7 and 95% of the time is the proper fix for the problem
Old Oct 27, 2007 | 05:40 PM
Midnight 85
Originally Posted by 94ZR1
Please dont
Not to worry, I had already made up my mind to go with factory specs. My washers should be here next week sometime so I'll get them installed and post results.
Old Nov 2, 2007 | 08:18 AM
airblaine's Avatar
airblaine
Default Symptoms again
I have a very light clicking comming from my rearend I beleive, this clicking is only under acceleration. When the car is rolling to a stop there is no clicking. I can only hear the clicking if i shut of the radio and listen for it.
Will this clicking get worse? sounds like you guys are describing a loud clicking, I dont feel people outside my car can hear this but i may be wrong. Should i have my car serviced or just replace these washers and see if that solves my problem?
Old Nov 2, 2007 | 08:35 AM
KeyWestJack's Avatar
KeyWestJack
Great write up!
Old Nov 2, 2007 | 10:37 AM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
The washers fix it 95% of the time and they are $7 at the dealer
Old Nov 2, 2007 | 12:22 PM
  #33
CentralCoaster
It's more of a low muffled *thunk thunk* like you'd hear from bad Ujoints, but happens when the car first starts rolling after being parked for a bit.
You can also get some high pitched *ting ting ting* noises from it. I suspect this is the actual metal galling from the surface and resonating through the halfshaft.
Old Nov 7, 2007 | 10:40 AM
  #34
Midnight 85
To Agent86 and others, it is definitely the washers,,,, or in my case, the lack of them. Mine were MIA for some reason. I changed the hubs about a year ago, and although I'm sure there were none I suppose they could have been stuck to the old hub. At any rate, my car is a whole lot quieter going into gear now. I haven't driven it because I put it on storage insurance but I can tell the difference without driving it.
I want to thank quickcat again for the write-up, excellent tip.
Old Nov 7, 2007 | 08:27 PM
  #35
schrade's Avatar
schrade
Originally Posted by Raysur
What was the noise?
I'm with ya. ???
No pics of the offenders/scraped parts?
Old Nov 23, 2007 | 07:51 PM
  #36
GaDoll's Avatar
GaDoll
Cruise-In 11 Veteran
My '96 has a 'knock' when the wheels roll.....fast start, slow start, forward, backward......knock-knock.....got the washers today and will get this done asap.....it is driving me nuts.....will keep you posted on the outcome.....thanks so much for all the info....you guys are the BEST....and I am so grateful to have CF for all this help.....
hope y'all had a great Thanksgiving....
Carol
Old Nov 23, 2007 | 09:40 PM
  #37
1irishprince's Avatar
1irishprince
Originally Posted by 86PACER
Probably the common clicking, knocking from the rear spindle area.
http://www.artscorvetteparts.com/par...3-59f3634e182b
These weren't even on mine when I replaced the bearings! Are they a critical part. I got a used spindle off ebay and they sent me the wrong year, but it had a big, thin, metal flat washer on it...thought it might have been specific to those years (88-96), while I have an 86 which the spindle is shorter and doesnt have the thick boss that sticks past the ring. The diagram, now that I look at it, says it has a lip on one side that goes towards the spline???All the washers I have seen look just flat.? In another thread I had also asked about the "obsolete" hub bearing seal and figured the same with this washer...as I had no washer upon disassembly. But being as **** as I am when it comes to noises in the rear, I will pull the bearing back out when the washers come in and replace them!
To It's the washers!!
Old Nov 23, 2007 | 11:38 PM
  #38
Cyclonite's Avatar
Cyclonite
I've got to replace my rr hub/bearings...is this something I should go ahead and replace while I'm in there?
Old Nov 24, 2007 | 01:56 AM
  #39
hexane's Avatar
hexane
Couldn't someone just fab up their own washers out of sheet metal??? Might be cheaper than $7 each...
Old Nov 24, 2007 | 02:16 AM
  #40
86PACER's Avatar
86PACER
Ain't that easy. They have a special coating on them.
