Throttle Body Bypass
Apr 19, 2008 | 11:28 AM
From: One day you're a Comet...the next day you're dust... Arkansas
Quote:
Originally Posted by
Calderone
yes i understand now but ...any pics ?
im kinda lost !! im crazy about all the hoses !!!!
thanks
Look at SamLam's picture. The heater hose that runs from directly below the intake coupler around the A/C components back toward the firewall is it.
Apr 19, 2008 | 11:48 AM
Calderone
thanks
Here is my bypass.
The hose with clamp goes under AC compressor and straight onto intake base nipple.In the pic you can also see where the other heater core line ties into tee(water pump and oil cooler).
Her you can see the coolant line going into intake base nipple.
Few more pics
Apr 19, 2008 | 11:54 AM
Oh, and if you are wondering why you don't see any coolant nipples on TB, it's because I cut them off.
Apr 19, 2008 | 08:28 PM
i will do this mod while im there .....
i am posting pics to find out if what im doing its OK
And to illustrate others who want to do this mod.-
PLEASE CORRECT ME IF IM WRONG,Bypassing the TB leaves the TB ..with zero water contact ??? i mean if i bypass this ...the TB has nothing to do with water anymore ????
Here i go...
PLEASE CORRECT ME IF IM WRONG ...OR IS THIS PERFECT ?
Apr 19, 2008 | 08:31 PM
While you were posting ...i was doing this guide..
not sure if im correct...
i think it is
So the TB its free of coolant ...?
Apr 19, 2008 | 08:32 PM
AGENT 86
what's that picture ? is that a electrical connector?
Apr 19, 2008 | 08:33 PM
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
AGENT 86
Good idea, because their kinda in the way. I have to look at the TB and see what to do with those hose fittings.
Apr 19, 2008 | 08:34 PM
Calderone
It's the IAC but I'm not sure how it relates to cutting off the H2O passages.
Apr 19, 2008 | 08:35 PM
jsup
i was wondering the same !!!!
Apr 19, 2008 | 08:59 PM
Now my doubt its what should i do with port 2 of TB ? Should i cap it ?what's there for 87's ?
thanks !
Apr 19, 2008 | 09:05 PM
Calderone
thanks !
#2 is a vacuum fitting that swings around from the drivers side, which has a 90 degree connection on it.
Apr 19, 2008 | 09:07 PM
jsup
Can you post a pic ?
most of the big cool pics i got were from 86's and they do not have the # 2 port
thanks
Apr 19, 2008 | 09:08 PM
Calderone
thanks
My car is at the shop, for the next week. Go to
www.picturetrail.com
on the top right put in jsupino. I looked, can't really see it.
there's a lot of motor pics there, maybe you'll see something that helps.
Apr 19, 2008 | 09:23 PM
jsup
It's the IAC installed in what's left of the lower TB plate, after removing the nipples and coolant passage.
Turn your TB over and you will see.
Apr 19, 2008 | 09:25 PM
AGENT 86
OK GOT IT!!! Nice work.
Apr 19, 2008 | 09:27 PM
Calderone
thanks !
Port 2 is plugged on my 86, 87 may be the same. Does the aluminum tube for PCV>intake vacuum port(drivers side) have a nipple and hose going to canister ?
Apr 19, 2008 | 09:42 PM
AGENT 86
My pcv has a hose that goes directly to the driver's side port of the intake...is that right ¨?
Apr 19, 2008 | 11:41 PM
Calderone
This pic is correct.
Apr 19, 2008 | 11:44 PM
thanks pacer !
but ....now my only mistery its ...
what goes on port 2 ?
Apr 19, 2008 | 11:45 PM
I can't help you with port 2. '86 cars did not use them. The vacuum diagram on radiator shroud will show what it goes to, but obviously won't show how it's actually routed on the engine bay.
