Throttle Body Bypass
Old Dec 6, 2007 | 10:51 AM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Default Throttle Body Bypass
Should I just simply bypass the throttle body coolant lines when I put my intake back together.
Opinions?
Old Dec 6, 2007 | 10:56 AM
CFI-EFI's Avatar
CFI-EFI
I wouldn't "bypass the throttle body coolant lines". I would bypass the throttle body with the coolant lines.
RACE ON!!!
Old Dec 6, 2007 | 11:26 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
There's a theory that by not heating the throttle body, you keep the intake air cooler and make a little more power. Not sure how much difference it makes, but I've done it on my 86, couldn't hurt
Paul
Old Dec 6, 2007 | 12:38 PM
Hotred94's Avatar
Hotred94
I agree, it couldn't hurt and it will help, just not very much. Less heat is always an improvement. I did it to help clean up the engine area a bit. I capped one side and put a radiator flushing tee in the other side. In combination with the electric water pump I have, flushing the engine is eeeeeeasy.
Old Dec 6, 2007 | 01:00 PM
vader86's Avatar
vader86
Yeah i'd go ahead and do it.
Old Dec 6, 2007 | 03:24 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Losing a hose that crawls over the valve cover, makes it worthy.
Old Dec 6, 2007 | 03:54 PM
TA's Avatar
TA
Another advantage is that it'll make it much easier to take off the TB next time.
Old Dec 6, 2007 | 06:47 PM
Sam Lam's Avatar
Sam Lam
jsup: Here is a photo of ONE method of bypassing the TB coolant passages.
Old Jan 6, 2008 | 12:41 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Help me out here...my heater core leaked, and is currently bypassed...
I want to bypass my throttle body as well, where would I run teh hoses
to and from?
Please illustrate if possible with pictures...thanks!
Old Jan 6, 2008 | 12:59 PM
jsup's Avatar
jsup
FWIW, I went to Napa, they had 5/8 hose with a 90 degree bend in it. I will cut to size, and done.
Old Jan 6, 2008 | 01:40 PM
derekguzz's Avatar
derekguzz
I am wanting to know EXACTLY where to cut and what im confused and dont want my engine to bleed trouble
Old Jan 7, 2008 | 03:55 AM
NocarbutaVetteforme's Avatar
NocarbutaVetteforme
I agree wholeheartedly with the capping. All you do is cap the supply and return points as well as the spots on the t/b. They have the cap kits at most of the parts supply stores. As others have stated, benefits are cleaner engine bay with less hoses and you can take off your t/b without making a mess.
Old Jan 7, 2008 | 04:21 AM
86PACER's Avatar
86PACER
to and from?
Look at the pic in post#8. The end that you cannot see goes straight into the coolant fitting on the front of intake base where your throttle body is connected to right now. Once that is cone, the hoses on the throttle body can be eliminated and you are now bypassed.
Old Jan 7, 2008 | 10:44 AM
'Shifter's Avatar
'Shifter
NCM Member '09
That's what I figured when I was looking at it yesterday, but it just wouldn't make sense to me....
Thanks!
Old Apr 18, 2008 | 10:35 PM
Calderone's Avatar
Calderone
interesting,its a good mod ?
Old Apr 18, 2008 | 11:18 PM
Muffin's Avatar
Muffin
BINGO, we have a winna. I doubt if you will ever see even a single pony but it helps in cleaning up where the engine lives.
Old Apr 18, 2008 | 11:33 PM
Calderone's Avatar
Calderone
Would be cool to see the stock route
compared to the bypassed route ....
any before/after pics ?
To Throttle Body Bypass
Old Apr 19, 2008 | 09:15 AM
TA's Avatar
TA
Its not really rocket science. The hose originally goes from the heater core into your throttle body and then out of the throttle body into your intake manifold. All your doing is running the hose from the heater core directly to the intake manifold, thus "bypassing" the throttle body.
Old Apr 19, 2008 | 10:34 AM
Calderone's Avatar
Calderone
yes i understand now but ...any pics ?
im kinda lost !! im crazy about all the hoses !!!!
thanks
Old Apr 19, 2008 | 10:48 AM
TA's Avatar
TA
I don't have any pics, but I only used a single piece of hose. I ran one piece of 5/8" hose from the heater core directly to the intake, so no connections.
