TPiS Mini-Ram vs. Accel Intake system
http://forums.corvetteforum.com/show...t=First+Intake
Look at the dyno results for the First Intake vs. The MR.
The good part is you get all of the low end grunt of the TPI, and the HP numbers of the MR. The TPI only falls off at 5500 RPMs, it is superior at every other RPM range. You will RARELY drive the car at 5500 RPMs. Therefore, the FIRST seems to be a real good option.
I have a FIRST intake. I'm still in the process of building the motor so I don't have any real world data yet, but I can tell you that the casting quality and machining work is top notch.
Be aware that the FIRST is not a true bolt-on system. The fuel rails are different and the stock fuel lines will not work with them. Also, you will have to use an external fuel pressure regulator and you will also probably have to do a bit of grinding on the bottom of your distributor housing so it will clear the intake, but these are minor things that are easily fixed.
You can get a nice set of heads for just shy of $1000 and probably get $300-400 for yours.
If the $600 won't kill you, perhaps heads in this mix can help.
I'm going to "chince-out" and try everything except head/cam (i.e., headers, intake, and 1.6 rr). It took 6 months to thoroughly read about the options (in my spare time). I just shared with you -- a summary -- of what I learned.
Some would say do all or nothing. Most would say headers is a definite regardless of what you do. You got that one "right". I pulled my intake because of injectors. I find it hard to replace something I know could be better. You sounded like you were in the same boat.
My view is that headers + intake + rr = 50+ hp gain over a stock motor. That's 20% improvement. 20% is something you can feel. If I can feel it, it's worth it.
gp
Btw,most of these mods will sometimes make a stock TPI engine feel a bit slower off line until higher rpms,say 2500 or so...most are not noticeable and need a dyno to prove otherwise,or track times.
If someone wants a stop light stomper,steeper gears,torque converter change,(If an auto),is gonna do it if they dont want to mod/change the engine inside.Or even better,supercharge the engine and hang on!
To "fix" a faulty, under powered design I don't like gears as a solution.
On a stock L98, gears will bring the RPMs up to a point where the motor was not made to operate.
Back to the stock TPI,
I put 3.73s in my former 86 TPI and it was fun on the street and highway.In fact,it took off even harder than stock and hit 60 very fast.I rarely ever went to 5000 rpms on the street because by then youre going so fast its illegal,and you usually run out of road somewhere before the engine runs outta steam.I loved the gears,its probably overkill for most people but I enjoyed it.
Anyways,Im speaking of keeping an engine stock,and what to do to make it be more fun on the street,not trying to suggest a band aid fix for an engine that cant run over 4800 rpms.
If someone wanted more power,I suggest head,cams,more cubes,way better intake etc.But for a stock engine,non track car,I suggest gears and exhaust.If someone already has 3.54 stock,I dont suggest 3.73 because it wont be that much of a difference.
That's what happened to me. It made no sense to do bits and pieces....
A quik fix is always NOS, but u have the problem of refilling and the bottle taking up space in an already small hatch space. U may also consider saving for a supercharger system, that should satisfy ur need for speed for a time, anyways. More expensive, but they always add to resale and u just can't beat the "cool" factor. They are also upgradeable and are always there, so there is no need to worry if the botlle is full or not. Another advantage, is u can take them off and resell for at least part of ur investment. Of course the addition of these power adders should be considered only if ur engine and drivetrain are up to snuff. Or...., u can do like I suspect alot of us do, and, that's to buy a piece here and there with a final goal in mind, and then drop the major coin for the eventual rebuild.
"IF" there is the slightest possiblilty that u will upgrade to a newer model Vette in the future, I would strongly suggest u save ur cash and enjoy what u have. Once u start adding speed parts, realize that the resale goes down and the costs of the parts is a throw away, only for ur satisfaction. U'll get nothing back on a monetary return, only the smile when u drive it. At least, that has been my experience in this crazy addiction we all seem to have. Hope this helps.
I said in another post if one had 3.54 and went to 3.73s they would not do much.
My Vette had 3.07 auto,stock form.I went to 3.73 and it was an animal on the street.Not suggesting that for track use with a TPI style set up.
For someone that didnt want to get into the engine,and have more stomp down low,its a very easy way to go.
If one has at least 3.45 and 6 speed TPI,I would leave the gears alone.
Its plenty and going to 3.73 wouldnt be a big jump.
4.11 is way too much for a street TPI,3.73 was pushing it.If the user switched to a MR or LT1 style intake,4.11 would rock with the 6 speed.
I did a thread last Fall and the consensus was the alum head L98 had close to 300hp in it without doing heads/cam. And, I'll be doing a couple of other things like the frisbee and tune. So I don't think getting close to 50hp more is out of the question.
If I wasn't happy, do you think 3.73's are a waste vs my stock 3.33's (on a ZF6 car)? How much (time) would that gain in 1/8th and 1/4 mile times? (How about if this was matched up with the HSR vs the LT runner setup?)
gp
Here's another informative post I found useful on the subject. This post suggests 40-50hp gain.
I asked what mods are required to install on our motors...They did say an adapter is needed for the fuel lines and something to connect the TB cable. They said the large dist would fit and didn't mention grinding! I think they said a different TPS or IAC was required, but I don't remember which. Vacuum fittings were all present. And MAFs could be put in front of their round TB with an adapter hose they sell.
Current pricing is about $100 higher than the group purchase amount at the beginning of the year.
