393 update:1
I'm just offerin the pan since Jim is local to me and if he knows how to weld that little ding up the pan is perfect.
Good luck
The oil consumption issues are not from the pump or windage tray situation (nor the valve guides as that type of symptom is smoke on start up). I would encourage you to do a leakdown test on the engine....its obviously broken in at this point and ideally you would hope to see it less than 5% hot....10% max for a fresh engine.
Also, its disheartening the windage tray wasnt installed....its common to shim the tray away from the rotating assembly for adequate clearance with a stroker.
Keep us posted and good luck
Regards,
Tony
http://forums.corvetteforum.com/show...post1565930642
Because some folks might not know... When you use AFR cyl heads on an GEN II LTX, the front drivers side cyl heads oil return gets blocked off completely because of a shelf (its actually a casting support for the waterpump bolt) that is cast in to the GEN II blocks (not there in a regular SBC). So we don't have any problems I modify that shelf so, oil will drain out of the front of the head properly. Most people who are having or had problems with AFR's on LTX motors don't even know this is a big part of their problem....
\More pics will follow after I get it cleaned, decked and bored/honed.
Will
- I told him to use standard tension rings and he says he did
- I can't weld Mike but thanks for the offer
-I will do a leak down next week and check/replace all the plugs although #2 and #4 looked fine a week ago.
-Tony, is that true about the drainbacks on even the new AFR heads when used on the LTx block?
http://www.youtube.com/watch?v=g_REuskEebI
I now have virtually no oil consumption, oil is clean (due to blocking bypass valve which oil pressure was usually above 60 psi, and I lowered the pressure witha standard spring for my Mellings HV pump).
I have a standard Corvette pan and windage tray. Leak down didnt show any problems due to rings seated properly and the compression rings dont affect oil consumption.
Low Tension Oil Rings are the enemy on a street car. I will never ever use them again.
Also, my rings were at .018 and JE's SRP higher silicon pistons to keep things tighter.
i can't help but wonder why is it that sometimes home-build motors have these blow-by issues. i've seen and heard of more than a few, a few too many...even motorbikes
new cars and hence their ensuing break-in out number home builts
and new car buyers are probably less incline to bother, or are even aware, of proper break-in procedures, coupled with the fact that some new cars don't mention break-in.
these cars go on their merry way of delivering transportation, oil consumption free.
there has got to be a time tested, part; build procedure dependant aspect to engine overhauls that even the apathetic approach can ensure a proper seal.
this is what i'm after, the peace of mind that once the last bolt is tighten, and that the collective effort of all invloved should yield a motor set for another 150,000 trouble free miles
I'll be paying him a visit on Monday to discuss things. I spoke to his partner today and he told me he feels confident that the rings just need a little more seat time and that they "should" be seated and smoke free before I put the car away. My experience tells me otherwise. I've installed a bunch of hypo motors in the past and none of them smoked past the first 100miles.
We'll have to wait and see I suppose.
This is what I have done, works every time..
http://www.mototuneusa.com/break_in_secrets.htm
No oil consumption problems, or smoking.
This is what bugs me the most. The two motors I had built for me in 89 and 93 had no wide bands to check air/fuel, no data logging, no dyno tuning and I falsely babied them since I was not even an apprentice yet and didn't know any better.
when i said home built i meant not mass produced factory motors,but one-off custom built: having issues....thats all
Yes you still need to grind the block even with the new AFR casting. That engine used the new AFR Elims (195 Comp Ports to be exact).
It's only the DRIVERS SIDE FRONT oil drain back that gets blocked and needs to be ground on.
As for other stuff to look at I agree with a few others here.
1. Do a leak down check (and post the results).
2. Get a new pan with a windage tray (Kevco, or Canton will work fine).
Will
Will
Talked to the guy I normally order parts through and he says there's a good chance he can get me everything in a few days so hopefully I can have an update by the weekend.
With grinding the block, I understand that you said it will improve drain back but are you saying without it that there's no way to assemble an LT1 and not have consumption issues with AFRs? That being said, if one of my drain backs is blocked I would think a high volume pump would make it worse.
lary00-Of course GM doesn't want you beating on the car under warranty but I believe they do break in allot of their motors at the factory.
slickfx3-My bad I misunderstood you. Of course the mass produced ones don't have pistons that expand as much as 500HP and over engines do but regardless, it's still a SBC. If you make your living building engines and you can't get a SBC to seal right 2 times in a row, that's pretty sad no matter how the customer drove it even though I did do the break in procedure correctly.
Now the issue with AFR's has nothing to do with this at all. With the AFR's if you do not grind that trench, into the drivers side water pump bolt support pad, the front oil drain back in the head will be 100% blocked off. That forces oil to puddle in the front of the head and eventually it can finally run to rear drain and get out that way. You end up with more oil laying around in that head.
I know there is alot of grinding and polishing in the pic. If your unsure of what I'm talking about, I'll Photo-Chop a pic and highlight precisley where to grind for the drivers side front oil return. However you will have to at least take the drivers cyl head off and tape the rest of the motor up to fix it....
A few things about HV oil pumps. They will NOT pump any more oil to the top of the motor. Common misconception. If they were allowed to pump unregulated they could, but once the pump meets a certain amout of resistance the bypass opens and dumps excess oil directly back into the oil pan. All a HV pump does is bypass more oil directly back into the pan...
This can cause problems on some SBC's because the bypass dump/port is directly above the pick up tube. The oil dumping directly back in the vincity of the pick up causes cavitation and oil pressure loss in some pan/pump combinations.
Will
