mass air flow censor problem
Old Nov 21, 2008 | 09:26 PM
2c4sforme's Avatar
2c4sforme
1st Gear
Default mass air flow censor problem
installed new censor on 1987, will not run right. whats wrong?
Old Nov 21, 2008 | 09:34 PM
engle1147's Avatar
engle1147
You should change the 2 relays that work with the MAF when you change the MAF....The power relay & the burn off relay.
If the burn off relay sticks closed it is bye bye new MAF
Old Nov 23, 2008 | 08:59 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Why did you replace the MAF sensor ??
Is the "service engine soon" light, on ??
Are there any stored codes in the cars computer ??
To mass air flow censor problem
