Code Help
Old Jan 5, 2009 | 02:40 PM
RogerZ06's Avatar
RogerZ06
Default Code Help
Just replaced the opti and ICM and my check engine light is still on.
I have FSM but I can't read or find half the pages they tell you to look
I get codes
Module 4 H42
Module 9 H62
Old Jan 5, 2009 | 05:16 PM
rodj's Avatar
rodj
Module 4 is the powertrain (PCM )
Module 9 is the ABS/ASR
Maybe check in those sections of FSM
Old Jan 6, 2009 | 04:14 PM
MikeC4's Avatar
MikeC4
Here is more detail on the H42 :
42 PCM did not detect any EST signal within 84 crankshaft revolutions.
This is saying that no "Electronic Spark Timing" is being detected by the PCM.
Doe's your engine start OK, or does it just keep cranking ?
Did you install the Opti correctly with the "keyed Spline" ?
Old Jan 6, 2009 | 05:36 PM
RogerZ06's Avatar
RogerZ06
My post must got deleted from last night.
Every time I look in the damn book it refers me to a page I can't find or doesn't exist
Old Jan 6, 2009 | 09:18 PM
Red Dwarf's Avatar
Red Dwarf
Have you tried clearing any codes?
Old Jan 6, 2009 | 09:22 PM
engle1147's Avatar
engle1147
What color FSM book do you have for your '94 is it red or white?
Old Jan 6, 2009 | 10:08 PM
pcolt94's Avatar
pcolt94
Does the engine run?
Have you cleared the codes, do they re-appear.
DTC 42, Mod 4 - is in 94 FSM page 6E3-A-90, for full description.
DTC 62, Mod 9 – is on page 5E2-88 Tach pulse malfunction
You must use the on board diagnostics to clear module 9. Disconnecting the battery will not do it, (but will clear mod 1 & 4). Go to each module an clear individually.
Page 8D-9 & sections will tell you how to clear codes.
There is definitely a skill level associated with using the FSM. The more you use it the better you get. When I got it I would just read thru it to see what was where and how it was structured. I still hunt for stuff as some of it is in no logical order. When I find something useful I use markers on the pages.
Old Jan 7, 2009 | 01:17 AM
RogerZ06's Avatar
RogerZ06
Car runs and drives good now that optispark and new icm installed.
Code 62 Tach pulse malfunction. My Tach is fine and works good.
It says Repair open in CKT 121 between EBTCM and connector c100 terminal "G1" . Refer to "intermittens and poor connections" in section 8a-4 to help identify a poor connection causing the open.
So where the hell is the CKT 121 EBTCm crap ?
Old Jan 7, 2009 | 01:55 AM
rodj's Avatar
rodj
Elementry, my dear Watson.
I don't own one of those fancy late model cars but my take on it.
The fault code is in Module 9 = ABS/ASR .
NOT a fault with your tacho
There is a bad connection in the tach pulse signal to the ABS/ASR system.
The wire in question is circuit 121 which runs from the Electronic Brake Traction Control Module to pin # G1 at the C100 connector.The connector should be on a wiring loom.
Your circuit diagrams will show the colors for the 121 cable; easier to follow.Need to locate EBTCM and follow wiring
Somewhere in your FSM there is a diagram of the wiring loom connector locations and numbers.
Old Jan 7, 2009 | 09:58 PM
RogerZ06's Avatar
RogerZ06
I'm just looking for quick answer so I don't have to spend all day reading the manual.
Old Jan 8, 2009 | 12:58 PM
BobRR3's Avatar
BobRR3
quick question....Have you reset the check Engine light after making the repairs ???
Old Jan 8, 2009 | 03:22 PM
RogerZ06's Avatar
RogerZ06
I cleared the codes with the battery off and put in optispark and icm. The check engine light is still on because ebtcm wiring or some crap I gotta find now.
Old Jan 8, 2009 | 06:29 PM
JAKE's Avatar
JAKE
That's part of the problem right there. 'Ya gotta' bite the bullet.
Jake
Old Jan 9, 2009 | 12:55 AM
RogerZ06's Avatar
RogerZ06
Jake
Yea I did read the book a lot. Guess when someone else has the same problem, I'll hold the answer dick them around for days until they lose patience.
Old Jan 9, 2009 | 01:39 AM
rodj's Avatar
rodj
Guess when someone else has the same problem, I'll hold the answer ,dick them around for days .
What more can we do , come around and fix your car for you
The "quick answer" is you have a problem with your wiring to the ECTBM.
Find it and fix it or puts some tape over the check engine light so you can't see it.
People like you **** me ;
I don't own a late model car but I went to the trouble of doing some research on YOUR behalf to solve YOUR problem and all we get is "I'm being dicked around."
You have the answer ; sort it.
Old Jan 9, 2009 | 02:24 AM
RogerZ06's Avatar
RogerZ06
Yea fly down from Australia fix it.
Just asking for quick answer. Like buy new wiring harness to fix it or buy ebtcm fixed my problem from someone who had problem. All the wires look new I cleared the abs code and it came back. Guess I will have to take it to a shop or dealer to fix it.
Old Jan 9, 2009 | 06:53 AM
rodj's Avatar
rodj
Start a new post asking if anyone has had a EBTCM wiring problem
To Code Help
