Rear Wheel Power
Old Apr 27, 2009 | 05:54 PM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
Default Rear Wheel Power
Kind of a dumb quiestion but here it goes. I have noticed that alot of jeeps and even mustangs that only one wheel turns until they reach a certain RPM/Speed. What about our C4s? Both wheels or just 1 wheel spins?
Old Apr 27, 2009 | 06:02 PM
farscape1a's Avatar
farscape1a
i think both wheels spin at the same rate because of the posi rear end. i think both the D36 and the D44 do this.
anyone else?
Old Apr 27, 2009 | 06:03 PM
rklessdriver's Avatar
rklessdriver
All C4 Corvettes have a clutch type limited slip positraction differential, so unless the clutches are completely worn out. both tires should spin from the get go.
Will
Old Apr 27, 2009 | 06:10 PM
TWISTERUP's Avatar
TWISTERUP
Will
Old Apr 27, 2009 | 07:35 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Well that's virtually true. On the 1-2 at WOT I sometimes get a little "wag", caused by one wheel moving faster for just an instant before the posi kicks in.
Old Apr 27, 2009 | 08:45 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
Both marks on the road are the same length.
Old Apr 28, 2009 | 10:36 AM
M.J.L.'s Avatar
M.J.L.
Thanks everyone. Anyone know why those cars only use one wheel? It seems that for power, they would need both.
Old Apr 28, 2009 | 11:21 AM
Ramrod92's Avatar
Ramrod92
As it seems to always happen, it comes down to the $$$s.
Old Apr 28, 2009 | 11:48 AM
bjankuski's Avatar
bjankuski
I need to clarify something on this post. All cars use both wheels to transmit power to the ground. Most cars have a open differential which means both wheels get exactually the same torque and the wheel with less traction will spin (but they both have the same torque being applied to them). On cars with posi traction there is a mechaical device that locks both axles together on acceleration and the wheel with less traction will not spin until you have overcome the traction at the wheel with the most traction and then both wheels will spin.
Old Apr 28, 2009 | 12:07 PM
F1Fan's Avatar
F1Fan
There are varying degrees of it, but virtually all non-performance cars have open differentials. Even some "performance" cars do too.
"Positrac" is a name trademarked by Ford. I don't think Ford has made them in quite some time either.
Old Apr 28, 2009 | 12:13 PM
cdig's Avatar
cdig
So when I do a brake stand both wheels should be spinning? And if only one is spinning it means the clutches in the rear diff are shot?
Old Apr 28, 2009 | 12:51 PM
vader86's Avatar
vader86
Originally Posted by bjankuski
I need to clarify something on this post. All cars use both wheels to transmit power to the ground. Most cars have a open differential which means both wheels get exactly the same torque and the wheel with less traction will spin (but they both have the same torque being applied to them). On cars with posi traction there is a mechanical device that locks both axles together on acceleration and the wheel with less traction will not spin until you have overcome the traction at the wheel with the most traction and then both wheels will spin.
Ford has generally used a more primitive unit in their 3-link/live axle Mustang. I suspect Jeep also has a similar thing in it. Usually the cheaper sports cars and most RWD passenger cars will have such primitive diffs in the rear.
http://en.wikipedia.org/wiki/Differential_(mechanics)
Old Apr 28, 2009 | 12:56 PM
M.J.L.'s Avatar
M.J.L.
Im just saying. I have seen numerous cars do burnouts. The mustangs, jeep Cherokees, and even some trucks had only one wheel spinning. Automatics and sticks. It's the left wheel that was spinning. I know both wheels get power to make the car move. I was just asking why only one was moving at the lower rpms. It was quite perplexing. Thanks though. I understand now.
To Rear Wheel Power
