Intermittent Problem, Running Poorly
Old Jun 17, 2009 | 11:32 PM
Pwnage1337's Avatar
Pwnage1337
Default Intermittent Problem, Running Poorly
85 A4.
Every once in a while, the car will start, and run like absolute ****. Will idle, but its all over the map. It only does this like 1 in 10 times I start it, and seems to be completely random. It does it when its hot, cold, or anywhere in between.. During this time, its runs VERY rich. It will move, and at about 55 mph, my instant mpg is 10. When its running normal, my 55 mph readout is usually 28-30.
I'm thinking that its an injector thats clogged, so the other injectors on that bank just inject a whole ****load of fuel, to make up for the cylinder thats running lean.
What do you guys think?
Old Jun 18, 2009 | 01:10 AM
rodj's Avatar
rodj
Need to pul the codes and see if any faults are present
Old Jun 18, 2009 | 02:52 AM
Pwnage1337's Avatar
Pwnage1337
I checked the codes, and the only one that showed was a 42. not sure if thats the right #, but i remember the definition of the code was rich exhaust which i already know
Old Jun 18, 2009 | 04:11 AM
rodj's Avatar
rodj
"Code #42: Electronic Spark Timing.
Check wiring at ignition module. Replace ignition module. "
DTC 44 is rich exhaust.
If that one I would be looking at the O2 sensor and it''s wiring.Maybe a intermittant connection?
Old Jun 18, 2009 | 03:01 PM
Pwnage1337's Avatar
Pwnage1337
OK now this is where stuff gets really ****ed up.
It has done this three times, don't laugh it sounds stupid but its true.
I went outside today, started the car, and it was running like crap. So i open the hood, look around for arcing or something, and when I DROP THE HOOD, IT STARTS RUNNING GOOD. ITS DONE THIS THREE TIMES. WHEN I DROP THE HOOD, IT JUST STARTS RUNNING LIKE NOTHING IS WRONG. WTF?
It must be from when i drop it that something connects? I have no fkin clue..this is some of the wierdest **** i've ever seen.
Edit: By drop i don't mean slam, just close.
Old Jun 18, 2009 | 03:18 PM
C409's Avatar
C409
Your engine sounds like my X .... always wanted attention , but hated being stared at
Old Jun 18, 2009 | 03:22 PM
Jims1988C4's Avatar
Jims1988C4
85 A4.
Check your MAF burn off relays.
Old Jun 18, 2009 | 06:40 PM
Pwnage1337's Avatar
Pwnage1337
My car doesn't have burn off relays, it has the burnoff module. Any way to test that thing? I know its buried way up in the dash by the ecm
Old Jun 19, 2009 | 03:41 PM
Jims1988C4's Avatar
Jims1988C4
My relays were cheep,ID replace the module anyway just because its 24yrs old .
Old Jun 19, 2009 | 04:56 PM
Pwnage1337's Avatar
Pwnage1337
The module is like 300 dollars new, and you can hardly find used ones on ebay and when they are on there they are about 100-150. Is there a way to test it? Or convert it to a style where i could use relays?
I'd like to test it before i just throw one in there just for shts and giggles.
I think its strange how the hood closing makes it go away..isn't there a part that gets better when you hit it? I think its the MAF that you can tell is bad if you give it a smack. Not sure though.
Old Jun 19, 2009 | 05:36 PM
engle1147's Avatar
engle1147
If you have a code "42" pull the fuse for the ECM, leave it out for 30 seconds and then put it back in. Restart the car and see if the code 42 comes back...it shouldn't come back if the EST circuit is sound.....but if it does check to make sure the black "in-line" electrical connector(located near the brake booster) is still plugged in/intact and not grounding on anything. This electrical connector runs to and from the EST module. It has a connector on it so you can unplug it to check/set the "base" timing on the engine. You may also want to use a timing light to see if your engine is being allowed to electrically advance properly when your crappy gas mileage/poor running situation occurs. If the car is running with only 4-8 degrees of total advance this would explain the hard starting and poor fuel economy situation.
Old Jun 19, 2009 | 05:46 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
LOL, that right there is funny
Old Jun 23, 2009 | 03:44 PM
Pwnage1337's Avatar
Pwnage1337
What would it be "grounding" on? I checked it and it was kinda loose, so I plugged it back in and it hasn't done it since I plugged it in. The clip on the connector is snapped off though, should i get a pigtail and splice it in?
To Intermittent Problem, Running Poorly
