Factory Roller Cam Blocks
Old Sep 21, 2009 | 11:07 PM
cumbercr's Avatar
cumbercr
Default Factory Roller Cam Blocks
Are all Chevy 350 blocks with 1 piece rear main seals compatible with factory roller cams?
My daughter has a 91 Chevy 3/4 ton truck with over 200,000 miles and still running. I haven't dropped the oil pan but I believe the heavy duty trucks had 4 bolt mains. If it works with a factory roller cam, I may use it for my 383 project.
Old Sep 21, 2009 | 11:13 PM
Pwnage1337's Avatar
Pwnage1337
I think they switched to roller blocks in 88? not sure
Old Sep 22, 2009 | 12:10 AM
engle1147's Avatar
engle1147
Think off hand it was 87.
With today's aftermarket think you can put a roller hydrolic cam in any engine now a days....though you may have to machine the lifter bores to accept the roller lifters. Most factory roller hydrolic cams I've seen have a step in the face of the cam for a retaining plate....other old school aps have a button which extends from the timing cover to hold the cam in place. I have no idea what is in a '91 heavy duty block though.
Old Sep 22, 2009 | 12:18 AM
rodj's Avatar
rodj
Need to pull the pan and check. I have seen the same block casting as used in the late L98's ( 1 pce , roller cam ) used in truck motors fitted both 2 and 4 bolt mains.
All the 1 pce blocks I have seen have been machined for a roller cam even if a flat tappet was fitted at the factory.Have the 3 tapped bosses in the valley for the lifter spider and the threaded holes in the front for the cam retainer plate
Old Sep 22, 2009 | 09:28 AM
1986-z51's Avatar
1986-z51
Default roller
Thats a good Queston. Have a 86 w/aluminum heads,wich is a late producton 86. I beleve the roller started in 87,or has any body seen a roller in a late 86???
Old Sep 22, 2009 | 10:07 AM
Pete K's Avatar
Pete K
The 86 block was unique. It has a 1 pc rear seal, but did not have provisions for a roller cam set up. 87 and up had both 1 pc seals, and the boss' cast into the lifter valley, and for the cam retainer plate behind the timing gear.
Old Sep 22, 2009 | 11:17 AM
cumbercr's Avatar
cumbercr
That's what I'm hoping. But I think Chevy continued to use flat tappet cams in many of them.
Old Sep 22, 2009 | 11:58 AM
Pete K's Avatar
Pete K
You are correct.
Old Sep 22, 2009 | 06:23 PM
Blastoff's Avatar
Blastoff
I also have a late model {alum. head} 1986, it has a flat tappet cam. The reason i'm chimming in is because i was just speaking with someone selling 86-95 shortblocks with roller cams.
Old Sep 22, 2009 | 06:30 PM
JackDidley's Avatar
JackDidley
Yes, even though they would accept a roller most of the non Vette motors had flat tappet cams.
Old Sep 22, 2009 | 07:35 PM
rklessdriver's Avatar
rklessdriver
Be aware that GM also used 2 different bolt spacings on the cam thrust retainer.
Will
Old Sep 22, 2009 | 08:34 PM
pr0zac's Avatar
pr0zac
2wd trucks had 2 bolt mains and 4wd trucks had 4 bolt mains. 87 and up have provisions for roller cams but not all had roller cams. i believe up until 91 all non performance v8's were flat tappet
Old Sep 22, 2009 | 09:03 PM
cumbercr's Avatar
cumbercr
Will
So I have a 50/50 chance of choosing correctly. If that's my biggest concern, I can deal with that.
Old Sep 23, 2009 | 09:36 AM
rklessdriver
91 year model SHOULD have the narrower/smaller bolt pattern 2nd design camshaft thrust retainer. GM PN 10168501 is for 3.294" bolt centers. It is all of $8.20 on GM Parts Direct.
The 1st design camshaft thrust retainer is GM PN 10088128 and is for 3.62" bolt centers.
Once you have the block apart just measure acoss the bolt pattern with a dial caliper and you'll know which one you need.
Will
Old Sep 23, 2009 | 09:55 AM
cumbercr's Avatar
cumbercr
Will
Thanks. This is very helpful. I'm saving this info. I think I've concluded that this block will work, assuming it is a 4 bolt main.
To Factory Roller Cam Blocks
