Here is what I borrowed from someone else in regards to the "holes" in the bottom of the manifold. This is a modification done when the manifold is ported to ensure proper BLM's/Idle etc as it is a manufacturing problem. This came from a very highly respected head porter.
""Also, another thing that's worth mentioning that some still don't know about.... "IF" your interested in getting the nicest possible idle out of a cammed LT-X set-up (if you haven't done it already).......Next time you have the LT intake manifold off the car.....flip it over, and remove the bottom (metal cover with the 4 bolts)......then remove ALL of the large Allen type pipe plugs that are under it......By removing the large pipe plugs, you'll gain access to the individual IAC port holes that go out to "each" manifold runner (there are two under "each" plug)..........From the factory, these holes are not perfectly even (size wise) from hole to hole like they should be.....And (very commonly) one of them is usually REALLY bad (small)......Many of them also have thick aluminum burrs partially blocking the passages due to a sloppy factory drill job......Take your largest hole out of the bunch (verified by sliding drill bits in them), then once you get the drill bit for the largest one....Drill the rest out to match.....Then RE-install your pipe plugs with some permatex #2 (the non-hardening sealant), and ofcourse loc-tite your metal splash cover back on.........This process also made a noticeable difference on mine, and is something that I always do on ALL of the LT-X engine's that I do Heads & Cam packages on.......The end-result is Not as drastic as the IAC hole being sized properly, but it's a nice difference none the less."
I always use Permatex "The Right Stuff" Gm developed this with permatex to rid their engines, LTx type, of manifold leaks in the rear. Never leaks, even under boosted engines.
Right, Steve. I even mentioned that in my doc file, that some like the Right Stuff.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!! Graduation Day Parade 20 May 2010!!!
Mike, I sent you a PM with the Intake Install information. Here's a photo of mine when I was building my 388. Best one I have.
If you look closely at the rear China Wall you should be able to see the dimples.
Oh, and feel free to share the doc file with others.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!! Graduation Day Parade 20 May 2010!!! ARMY Vs NAVY TODAY!!!!!
Thanks Jake, that's a great write up!
As I had mentioned in my PM I didn't have any leaks. I guess that's because I did it about the same as your write up except for the rough sanding of the heads and intake surfaces. I also used the right stuff to seal the china walls. Let me tell you though, that stuff doesn't come out of those dimples very easily at all. I took lacquer thinner and dissolved it the best I could to get most of it out.
Everything I can do is done. Lifters are out, guide plates are off, intake is cleaned up and I did drill out that small hole in the intake as Steve had pointed out in his post above. I also ran the bit down through the rest just to make sure they all were the same size. So I'm waiting on parts. No telling when they'll get here with the time of year and all. I'll continue when they do get here.
Must be why I've always had such good results from RTV. Removing the residual RTV from the dimples was easy for me. I figure it's the Right Stuff that caused your removal problem.
The friction resulting from sanding/dimpling increases RTV adhesion. Think about how easily your hand will slide across a sheet of glass as compared to a sheet of 40 grit sand paper.
I once bought a can of Right Stuff, didn't like it, so I threw it under my work bench and haven't bothered to look for it since. No need to re-invent the wheel was my thinking on that. Had I had a problem with the RTV, I would have used something else, but since I didn't, I didn't.
Waiting on parts isn't all bad; you probably need that break anyway.
Hang in there and MERRY CHRISTMAS!
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!! Graduation Day Parade 20 May 2010!!! Army Vs Navy Today!!! - Doesn't Look Good :-(
From: Southside of Western Norte Americano State of Confusion, ColoFornia
St. Jude '13
Ok I finally have to ask.. " the great wall" you mention.. the front and rear of the block casting that meets the manifold ? Going between the heads? (the place where all the 1st gen SBC's leaked until we got RTV ?)
Just had to ask.. thanks
This is a better picture of what Jake is referring to about dimpling.
I never had to dimple the mating surface.I would not recommend that unless you are running forced induction.I also use the Right-stuff all the time at work & love that stuff!It also works on exhaust gaskets as well(its good to like 300 degrees F).You could lightly rub sandpaper on the mating surface so the silicone will not slide off or do like I do & put a thick bead down then lick finger & push silicone down alittle so it spreads out(licking finger or finger being wet won't allow silicone to stick to finger).I've done many intake R&Rs & used the Right-stuff each time & never had issues with leakage plus that stuff drys in about 10 minutes.I also would put Blue Locktite on intake mounting bolts & torque bolts down an extra pound or 2-Example if spec is 13ft-lbs I would & do round to 15ft-lbs & NEVER had leakage problems.Plus the Locktite will not allow bolts to come loose from engine vibration,etc,but make sure you blow out mounting holes with compressed air then spray some brake clean in holes & blow out again-this will clean out holes allowing proper torque & allow Locktite to not come in contact with oil or at least until it drys.Dimpling I believe is not nessisary & takes up unneeded time to do.This is just my professional opinion
LOL! Never fails. Seems that no matter what gets posted there's always someone who'll disagree and is absolutely convinced that "his way" is the better way. Then, to support that position, cites the trillions of miles of use with no problem. Brings a smile to my face each time I come across them.
Great living in America, isn't it!? Freedom of choice and all that. LOL
Jake
Jake
Jake, Its good to have professional opinions here too.
I support/use the Right stuff because it works very well, on all engine areas needing RTV. Being GM developed it with their R&D after having LT1 manifolds leaking issues, as well as L98 (back cylinders due to heat on manifold to head), I say it probably has a few miles to account for being a good product.
Yes, there are many fine products out there for sealing things. But, Mike needs opinions and peoples actual real life experiences to go forward.
I'm so afraid that after I have gone back and done all this work, again, I'm going to end up with the same problem at the end. I mean look at these dyno pulls. How can this be? How can a cam that is supposed to add probably 35 or 40 rwhp end up this close to a stock motor with a stock PCM? It's drivin me nuts guys... I really do hope it's that opti or not having the LT4 module in there. If it's not I guess I'll just put it back to stock and call it a day. Just wasn't meant to be......
If the changes you are making doesn't solve your problem, and I'm thinking the opti will be the only real change. Then the next step is to do some data logging, which should have been done after the initial dyno session.
I understand that and it was done I just don't have the results and they weren't saved. The guy at RPM Motorsports did it when he made the pulls. All he said was that one side of the motor was acting differently than the other. He had no explanation as to why.
Well, while waiting for parts etc, look at fuses, wires, connectors etc etc. just for a quick check prior to restarting it. Cant hurt.
Like the H.A.L. 9000 computer said when it was playing chess with Dave in the movie, "2001: A Space Odessey", "I'm sorry Dave, I think you missed it". LOL
I wasn't referring to you, or your Right Stuff preference, Steve.
Jake
There is also a possibility the valves weren't adjusted correctly before.
I feel for you Weav, you have been through the ringer fiquring out this problem. I've always been nervous to restart my car after engine mods, but I've been fortunate that everything somehow seems to work out.
Jake
If that was directed at me I just want to say it is my professional opinion like I stated.No one has to believe me but I do this for aliving & only post comments that I know alot about subject from experience.But if something works for you post what you recommend too.Remember opinions are like assh--es everyone has one but the only difference is it seems on this forum there is alot of valuable opinons.No harm officer,check my posts, I do know alot but also don't know everything thats why I'm here.You seem to know alot about corvettes & I am impressed with yours & everyones knowledge
