Problems, problems, problems......
Old Oct 20, 2009 | 07:51 PM
  #41
Weav's Vet's Avatar
Weav's Vet
Default Compression test
Did a compression test this afternon just to see what it produced. Good pressure on all. Is this about normal for a 95,000 mile motor?
#1- 210
3- 210
5- 200
7- 200
#2- 220
4- 225
6- 235
8- 225
Old Oct 21, 2009 | 01:57 AM
  #42
96GS#007's Avatar
96GS#007
#1- 210
3- 210
5- 200
7- 200
#2- 220
4- 225
6- 235
8- 225
Not bad. A little more variation than "typical" but that may be due to inconsistencies in how you tested.
Did you check the wires and plugs? Your dyno graph has "ignition problem" written all over it.
Old Oct 21, 2009 | 02:02 AM
  #43
Weav's Vet's Avatar
Weav's Vet
Wires are new MSD 8.5 but no, I did not check them. The car does not skip at all that I can tell.
The plugs...........not to good. Most were really dark but not like oil dark just didn't appear to be burning right. A couple were light on one side and darker on the other.
Old Oct 21, 2009 | 10:12 AM
  #44
rickneworleansla's Avatar
rickneworleansla
Damn, Sorry to hear of your troubles. I just came across this. Are you able to datalog it? I hope you get it worked out soon.
Old Oct 22, 2009 | 12:47 PM
  #45
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
I know you did it right, but when the camshaft gears are installed, it should look like this. Notice where the pin is. The gears on the cam and crank have the dot aligned with each other.
When you put your Opti on, you have to really really try to get the dowel pin into the other holes within the back of the Opti. I am not saying it isnt possible, especially if the dowel pin is a little smaller than normal due to machining, but not very likely. Retrace your steps on the Opti and see if she is plugged in right, plug wires on correct and also check that your injectors are plugged into correct injector. OBD2 cars usually give a code if they are plugged in wrong.
Also, what do the exhaust headers look like when running at night with no lights on? Are they cherry red anywhere?
Old Oct 22, 2009 | 01:35 PM
  #46
blue94's Avatar
blue94
I would use a laser thermometer to check the header tubes when running. If all temps are close it is not your plug wire setup. If one or more are off then you know those are the ones not running correctly. If all are close to the same look at PCM and tune via some datalogs first.
Last year I had to do this to find which 2 wires were flipped, motor was hot so did not want to trace the wires.
Old Oct 22, 2009 | 03:13 PM
  #47
lt1396corvette's Avatar
lt1396corvette
Check your pushrods and rockers.How do the rockers sit on the top of the valve.Is it center.I think your pushrods are too short.And your rockers are not adjusted right.
Old Oct 22, 2009 | 03:20 PM
  #48
neat's Avatar
neat
Since the graphs look so similar before and after the cam, I would think there might be a problem not associated with the cam swap. I suspect ignition issues, but I'm not an expert.
Old Oct 22, 2009 | 03:46 PM
  #49
Weav's Vet's Avatar
Weav's Vet
When you put your Opti on, you have to really really try to get the dowel pin into the other holes within the back of the Opti. I am not saying it isn't possible, especially if the dowel pin is a little smaller than normal due to machining, but not very likely. Retrace your steps on the Opti and see if she is plugged in right, plug wires on correct and also check that your injectors are plugged into correct injector. OBD2 cars usually give a code if they are plugged in wrong.
Thanks again Steve
I know the dots are correct but I swear I thought that pin was on the other side. I probably turned the crank though after I installed the chain. That wouldn't matter would it? The FSM says to have #1 at TDC when installing the opti. Of coarse I read that after I put it on. I didn't think it mattered. I'm positive I got the pin in the correct slot. I've read to many opti threads not to do that. I'll look at the headers tonight. I have another PCM coming probably tomorrow with my tune and a corrected AFR. If that doesn't fix it I guess it's time to start taking things back off.
Old Oct 22, 2009 | 03:48 PM
  #50
Weav's Vet's Avatar
Weav's Vet
Thanks good idea. I'll do that tonight also just for kicks. I like that little gadget.
Old Oct 22, 2009 | 03:50 PM
  #51
Weav's Vet's Avatar
Weav's Vet
I went through this already and found the 7.1 were to short. The roller was on the intake side of the center of the stem. I installed some 7.2 I had when I did the rr upgrade and the roller hit perfect in the center of the stem. Thanks though
Old Oct 22, 2009 | 03:54 PM
  #52
Weav's Vet's Avatar
Weav's Vet
I'm thinking bad opti if it's not the tune. Could be wiring could be anything I guess in the ignition. Frustrating to try and do all this correctly and end up with a mess like this. I'll get it though! Want to thank you all again for all of your help and suggestions!
Old Oct 22, 2009 | 04:14 PM
  #53
lt1396corvette
Did you check too see if there is an intake leak.
Old Oct 22, 2009 | 06:08 PM
  #54
Weav's Vet's Avatar
Weav's Vet
If there is I can find it. Vacuum is 16, that's about right with this cam, yes?
Old Oct 23, 2009 | 05:40 AM
  #55
Weav's Vet's Avatar
Weav's Vet
Default Dyno Video
This is the car on that last dyno pull.
Old Oct 23, 2009 | 12:00 PM
  #56
steve40th's Avatar
steve40th
Thanks again Steve
As long as you put the cam in like this, with the dots facing each other, it will be fine. The Opti will tell the ecm where it is in relationship to the cam etc. Mechanically you are good.
I am concerned about the pushrods. I have used Comp Cams lifters and now GMPP, and never had to get custom length pushrods, with Fel Pro and GMPP head gaskets as I have done this engine a few times. Do yo have pics of your heads with valve covers off to see the geometry and studs etc etc
Old Oct 23, 2009 | 12:20 PM
  #57
Weav's Vet's Avatar
Weav's Vet
I thought I did it correctly.
As for the push rods. Aren't the stock rods 7.2? That is what I have in there now but hardened Trick Flow's and they are damn close to the center of the stem. A whole lot better than the 7.1 that was suggested I use if not measuring. I don't think I have a photo that would be close enough to tell anything about the valve train.
To Problems, problems, problems......
Old Oct 23, 2009 | 12:27 PM
  #58
STL94LT1's Avatar
STL94LT1
Yes, 7.2 is the stock pushrod length. Pushrods are not your problem.
Old Oct 25, 2009 | 07:23 AM
  #59
Weav's Vet's Avatar
Weav's Vet
Default Could these be to strong?
Could the lifters be collapsing? They have started to tick a little. Would a heaver oil help this if they are?
Got the new PCM yesterday with my tune in it and adjusted AFR. Seems a little better but still not right. It was recommended that I use Autolite 104's for plugs gapped at .030. I did that and the idle is awful but accelerates nicely it seems. I'm going to re gap them to .050 and see if that helps the idle any.
Old Oct 25, 2009 | 09:02 AM
  #60
Pete K's Avatar
Pete K
That is quite a bit of seat pressure. What is your installed valve spring height?
If it is less than 1.800, you could have 170 pounds on the seat.
If you did not measure the distance from the top of the valve sping seat to the bottom of the retainer (installed height) you need to pull one apart and do so. Also, find someone with a spring tester, and verify the spring pressure is what it is supposed to be both at the installed height, and open height.
I have a hunch you are beating your valvetrain to death with those springs. Verifying open and closed pressures will confirm or deny that.
