Problems, problems, problems......
Old Oct 25, 2009 | 10:17 AM
  #61
Weav's Vet's Avatar
Weav's Vet
Originally Posted by Pete K
That is quite a bit of seat pressure. What is your installed valve spring height?
If it is less than 1.800, you could have 170 pounds on the seat.
If you did not measure the distance from the top of the valve sping seat to the bottom of the retainer (installed height) you need to pull one apart and do so. Also, find someone with a spring tester, and verify the spring pressure is what it is supposed to be both at the installed height, and open height.
I have a hunch you are beating your valvetrain to death with those springs. Verifying open and closed pressures will confirm or deny that.
Well damn Pete, you'd think LE would know what would work! Why would he suggest these springs knowing they'd be to strong. If nothing pans out in this ignition thing I will do as you suggested.
Old Oct 25, 2009 | 10:41 AM
  #62
Pete K's Avatar
Pete K
In my opinion, 135-145 pounds on the seat is a good amount for that cam, and 340-355 pounds open.
Those springs may be fine, but they need to be installed at the correct height to provide the correct spring rate and pressures for that cam.
If you did not verify the height, it isn't fair to blame LE. It is always the installers job to determine all parts purchased are correct, and suitable overall. If it were my car, I would stop what I am doing on the ignition, and shift my focus to valvetrain. I would hate to see the cam and lifters kill your motor while you are troubleshooting.
I see this alot. Although a cam swap is a bolt in, it is never that simple.
Everything needs to be what it is supposed to be for a direct swap in, and that rarely occurs. i.e: sping pressures, installed height, pushrod length, etc.
Old Oct 25, 2009 | 11:44 AM
  #63
Weav's Vet's Avatar
Weav's Vet
I did ask him about checking the spring height and shimming springs for pressure. He says it's not usually neccessary to do that unless the heads have had work done on them so I didn't bother checking after that. Didn't mean to sound like I was palcing blame. It's just that like you said I was expecting a plug and play deal and now I have all this going on. I just emailed him about these springs and sent this picture. His response.........."Yep, those are the right ones". Thanks Pete
Old Oct 25, 2009 | 12:26 PM
  #64
rickneworleansla's Avatar
rickneworleansla
FWIW, I'm running the same spring kit but with a different cam.
I bought the height micrometer and the shims. Didnt need the shims.
I checked pushrod length with a trickflow adjustable checker and the magic marker method. I had to bring the length checker to a machine shop that had a digital caliper large enough to measure it. Most of the ones I found local only went up to 6".
I've had no problems since the install. Well, other than the initial intake leak I had to fix. I would get a laptop and Datamaster TTS to get it datalogged.
Old Oct 25, 2009 | 12:34 PM
  #65
Pete K's Avatar
Pete K
I think if you actually have 1.800 valve spring installed height, you may be fine. But man, in my eyes, 155 lbs on the seat is a boatload of pressure. With hydraulic rollers, my comfort level is 145 on the seat, and 350 open max.
I guess the question is 2 fold:
1) Is your height 1.800
2) Were the springs in the box correct. Misboxed happens to me often.
My last experience with misboxed was a set of .010 under rod bearings that were in a standard box, and stamped standard. Glad I checked it, or I would have been screwed.
That was on the same build as a mis boxed TPIS cam.
Old Oct 25, 2009 | 01:22 PM
  #66
Weav's Vet's Avatar
Weav's Vet
Default It's Much better!!!!
Ok, As I stated I installed the Autolite 104's gapped at .030. That was not the ticket. The car ran like crap. I took them out re gapped to .048 and that seemed to do the trick. Remember, I have the new PCM in now. The car runs the best it has since this install. Idle still isn't very good but I can work with that. Before, I had a very rich exhaust fume odor especially at idle and low rpm. That is gone now. I'm still going to take it (hopefully next week) for a dyno tune. That should tell the way things are for sure. So to sum things up I guess the culprit was the PCM or tune or both. I doubt the plugs had that much to do with it all along but who knows.
Thanks for all the help and support!
Old Oct 25, 2009 | 01:42 PM
  #67
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
The idle generally needs to be worked. Simple trick is to open the throttle blades a little to allow the IAC to not have to work so hard. Other than that, get the tools to retune yourself or keep sending your pcm back and forth to tuner for little idle work, with data.
Old Oct 25, 2009 | 01:45 PM
  #68
STL94LT1's Avatar
STL94LT1
I'm running the same springs with a 1.80 installed height. But, I have aftermarket .050 longer valves. With stock valve you will end up with a ~1.78 installed height.
You mentioned the car died right after the last dyno run, and then started later. This sounds like you could have a bad ICM. I would get it tested.
Old Oct 25, 2009 | 03:56 PM
  #69
Weav's Vet's Avatar
Weav's Vet
Thanks, I will do just that. Who can do it though, dealer?
Old Oct 25, 2009 | 04:00 PM
  #70
STL94LT1's Avatar
STL94LT1
Try AutoZone or Advanced Auto.
Old Oct 25, 2009 | 04:03 PM
  #71
Weav's Vet's Avatar
Weav's Vet
Sorry, one more question. Does it have to be removed from the car?
Old Oct 25, 2009 | 04:07 PM
  #72
STL94LT1's Avatar
STL94LT1
I'm pretty sure it does need to be removed, you might give them a call.
Old Oct 25, 2009 | 04:09 PM
  #73
Weav's Vet's Avatar
Weav's Vet
Thanks for your help............again. Much appreciated!
Old Oct 29, 2009 | 05:08 PM
  #74
Weav's Vet's Avatar
Weav's Vet
Default No improvement.......
Got another PCM with the same tune and a readjusted AFR. Went to the dyno and there was no improvement except for the AFR. It was dead on. Brian at RPM Motorsports couldn't quite pin down what the problem is but said if it was his car he would degree the cam in an then go from there.
So, where do I get a good deal on cam degree kit?
Old Oct 29, 2009 | 05:12 PM
  #75
Pete K's Avatar
Pete K
It is likely degreed in. Your symptoms are consistant with too much spring pressure. Start there. It is more likely, and easier to get at. Trust me.
Old Oct 29, 2009 | 05:14 PM
  #76
Weav's Vet's Avatar
Weav's Vet
Thanks Pete
Would it be a waste of time just to stick the LT4 springs I have back in just to see if that changes anything. Or should I just get another set of diffferent springs and just keep these until I get new heads?
Old Oct 29, 2009 | 05:16 PM
  #77
Weav's Vet's Avatar
Weav's Vet
I'd whole lot rather change those springs than take everything apart again
To Problems, problems, problems......
Old Oct 29, 2009 | 05:22 PM
  #78
Pete K's Avatar
Pete K
Thanks Pete
Absolutely not. Valve spring set up is not a bolt in. It is a critical set up step that should never be skipped. Not enough valve spring will cause additional problems.
Since you can't put the toothpaste back in the tube, you have to figure it out, or swap cam, lifters, and springs back to stock.
You need to know:
The installed height you currently have.
A valve spring mic is a handy way to measure the distance from the top of the seat, to the bottom of the retainer. Once that is determined, you can take the spring to a machine shop that has a spring tester. He can then determine closed pressure. The valve lift is then added to the equasion, and the sping is compressed that amount.
Now you can determine the open pressure.
Compress the spring an additional .060 to see if you bottom out. If you do, the spring will coil bind, and is useless.
Without the above info, you are spinning your wheels.
Old Oct 29, 2009 | 05:25 PM
  #79
Weav's Vet's Avatar
Weav's Vet
That's what I'll do then. Thank you very much! You're going to make me learn something at the same time. Thanks Pete
Old Oct 29, 2009 | 05:47 PM
  #80
Weav's Vet's Avatar
Weav's Vet
You need to know:
Ok, I got this valve micrometer coming (1.6 -2.220) and the guy I take my car to to dyno is a machinist so he can help me with the rest. We're doing something now!
