Problems, problems, problems......
Old Oct 31, 2009 | 02:15 PM
  #101
grumpyvette's Avatar
grumpyvette
http://forum.grumpysperformance.com/...php?f=52&t=727
http://victorylibrary.com/mopar/cam-tech-c.htm
these might help, as will reading thru the linked and sub links posted earlier
Im not saying your cam being correctly or incorrectly indexed is your only problem, but with out a step by step systematic approach checking and eliminating each potential problem area from the discussion its rather pointless to jump around guessing and swapping parts randomly in the hope you hit on the answers
Old Oct 31, 2009 | 02:20 PM
  #102
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Originally Posted by Weav's Vet
Steve....I asked him to take a look at the thread. Looks like I'll be tearing it back down.
I apologize. I felt there was already too much information overload going on.
Steve
Old Oct 31, 2009 | 02:38 PM
  #103
Pete K's Avatar
Pete K
I think this is one of the best threads in a while. Athough I am sorry to see the op in a jamb, it does offer some great info.
Once the internet caught on, it has become a great source of info. Unfortunately, it makes every project sound somewhat easy. Cam swapping has never been a bolt in. Nor has any modification to an engine that changes it geometry.
As grumpy has discussed, proper cam phasing, verification of parts, spring pressures, spring set up, rocker arm and pushrod geometry etc, always require verification before the motor fires.
There is a good lesson here. I too, learned it the hard way.
Old Oct 31, 2009 | 03:56 PM
  #104
grumpyvette
the first step is verifying all the sensor outputs and making sure any adjustable factors like the TPS, O2 sensors, mat,heat sensors,etc. and timing and fuel pressure meet the aligned ranges,and potential problems like vacuum leaks, and the TIMING TAB INDICATING TDC are correct and reading all trouble codes , then move on to the mechanical problems, like adjusting the valves and verifying the cams indexed correctly, and the valve train geometry is correct.
if you don,t own a factory shop manual, a vacuum gauge, timing light, V.O.M. meter and a few injector NOID LIGHTS, and a fuel pressure gauge you need to get those
Old Oct 31, 2009 | 04:17 PM
  #105
Weav's Vet's Avatar
Weav's Vet
Steve
There probably is but I have to start to get a grasp on it sometime and somehow. It is obvious I'm still learning as we all are so info is good as long it's correct info and I knew Grumpy would know it and how to convey it. Not that you guys gave me wrong info it's just that it's all in one place now.
You're probably right on with this Pete. There may be a lot of second guessing going on right now as to whether they did it correctly or not. Had I not taken my car to a dyno I would probably have never known it had a problem until went to the track of coarse. It feels really good up to about 4500 or so. As I understand it a advanced cam will get your torque really quick and then peter out.That's exactly what is happening in my case. I hope it helps a lot of present and future Corvette owners. At my expense of coarse.....
Originally Posted by grumpyvette
the first step is verifying all the sensor outputs and making sure any adjustable factors like the TPS, O2 sensors, heat sensors, and timing and fuel pressure meet the aligned ranges,and potential problems like vacuum leaks, and the TIMING TAB INDICATING TDC are correct and reading all trouble codes , then move on to the mechanical problems
Got all those Grumpy except the timing light. How can that be used on my car with no marks?
Old Oct 31, 2009 | 05:04 PM
  #106
grumpyvette
http://forum.grumpysperformance.com/...it=+tabs#p1864
when you degree in a cam youll mark TDC on the damper and ideally add a timing tape (YES IM fully aware the LT1 has very limited room for timing tapes and you have the CPU control timing) but the marks are still useful for verifying the timing, and indexing the cam,
http://www.jegs.com/i/JEGS/555/51605/10002/-1
http://ep.yimg.com/ca/I/spideraccessories_2077_17686689
Old Oct 31, 2009 | 06:09 PM
  #107
steve40th's Avatar
steve40th
LT1s have no timing marks, and you only can check timing via datalogging. I am sure someone has gone down the path of putting an aftermarket damper, but even then timing is set electronically via programming.
The TPS is not adjustable unless you physically grind it out like and L98 engines. So, that is not adjustable.
Fuel pressure should be factory set at 43.5 psi with vacuum line off. To adjust it you need an aftermarket adjustable regulator. But, this tune was set for your injectors at factory psi of 43.5.
You injectors first test should be whether they are in good resistance, which is 14-16 Ohms, simple test. Put a Ohm meter on the two metal tabs on your injectors.
If you have a data-logger, vacuum and every other thing we need to see to determine problems will be shown. Your dyno operator already told you one significant one, in regards to BLMs being way off. And being sequential, and BLMs being off on one side, tells me allot of ways to go.
ANd there are no codes, no check engine lights either.
I am going with Bad Opti, or loose O2 sensor within the bung.
Steve
Old Nov 5, 2009 | 04:04 PM
  #108
Pete K's Avatar
Pete K
What's the good word Mike? Any headway?
Old Nov 5, 2009 | 04:22 PM
  #109
lt1396corvette's Avatar
lt1396corvette
I had a similar problem with my car.It would drive pretty good at lower rpm's but if I stomped on it at higher rpm's it would cut out like I was hitting a rev limiter or something.I changed my ICM(ignition control module)and problem was fixed.Check your out if you have'nt already.
Old Nov 5, 2009 | 05:27 PM
  #110
Weav's Vet's Avatar
Weav's Vet
Pete, I haven't even cranked it back up since last Sat. I have a little home project going on that I have to finish first. It's taking up my carport/garage/woodworking shop. Another week or so of this project and I hope to get back into the garage part. Don't worry, I'll post the results here if I ever find them.........
I had an extra one lying around and tried it but no change. Other than a sluggish feeling when it hits 3rd I can't tell anything is the matter. No backfiring or skipping going on. It's looking like I'm probably going to have to degree the cam in. If for no other reason just to eliminate it as the problem or it fixes the problem, one or the other.
Old Nov 10, 2009 | 03:33 AM
  #111
Weav's Vet's Avatar
Weav's Vet
Default LT4 knock module
I didn't change mine to an LT4 module.
I believe my tuner changed knock retard desensitizing so I didn't change the module. Does this get the same results as changing the module?
I read somewhere that this can reduce HP by 29 if the module isn't changed with regular sensitivity of the LT1 module when using 1.6 rr's with a cam.
I haven't started back on the car yet, just been reading. That can be good or bad sometimes.
Old Nov 10, 2009 | 06:02 AM
  #112
lt1396corvette
I don't think the module would make that much of a difference.But it would'nt hurt to get it.I'm using it.
Old Nov 10, 2009 | 06:13 AM
  #113
lt1396corvette
What kind of tune do you have on the car.Tunercat,LT1 EDIT.It would'nt hurt to look at the file.
Old Nov 10, 2009 | 06:33 AM
  #114
ddahlgren's Avatar
ddahlgren
Steve
Checking the timing with a timing light to know what you have is what is being reported in a datalog or scan tool whould be a very handy check.. It can't be that hard to use a tdc stop and create your own marks.
Old Nov 10, 2009 | 06:45 AM
  #115
Weav's Vet's Avatar
Weav's Vet
These are examaples of what he does. Some of these obviouly do not apply to my car. I did ask Brian at RPM Motorsports if the timing looked ok and he said yes.
I have asked my tuner for the file but he is reluctant to let me have it. Just ask what I needed to know and he would tell me.
Examples of programming options:
- Powertrain retrofits into other chassis
- Transmission conversions (A4 to M6, A4 to Th350, Th400, etc.)
- Idle adjustment
- Adjusting for different size injectors
- Knock retard desensitizing
- Skip shift elimination (M6)
- Shift points/shift firmness/shift kit/different stall adjustments (A4)
- Rev limiter adjustment, disabling/adjustment of the speed limiter
- Ported heads/headers/exhaust/aftermarket camshaft tuning
- Fan turn on temperature adjustments
- Speedometer/Auto transmission shift point adjustments for different gear/tire size
- Premium gas power tuning
- Larger throttle body adjustments
- Larger/ported mass airflow sensor adjustments
- Different engine displacement adjustment
- Programming for supercharged applications, if you have access to wideband o2 readings and your own cable.
Old Nov 10, 2009 | 06:46 AM
  #116
Weav's Vet's Avatar
Weav's Vet
I have a Tech 1. It tells what the timing is at any rpm.
Old Nov 10, 2009 | 07:32 AM
  #117
glennjr91's Avatar
glennjr91
good day, noticed oil under the driver side near the middle, what could be the problem now?
To Problems, problems, problems......
Old Nov 10, 2009 | 07:34 AM
  #118
glennjr91's Avatar
glennjr91
when driving, getting some hessitation when i try to punch it. it seems like it want to shout down. i was told to replace the o2 sensor.
Old Nov 10, 2009 | 07:39 AM
  #119
glennjr91's Avatar
glennjr91
i'm hearing a noice at the fuel pump location, thing that it need to be replaced, also getting lots of hesitating while trying to accelerate to a passing gear. any advise
Old Nov 10, 2009 | 12:08 PM
  #120
Weav's Vet's Avatar
Weav's Vet
uh......you may have put these is the wrong thread.....
