Lateral Acceleration switch
Old Mar 17, 2010 | 08:57 AM
torchred89's Avatar
torchred89
Default Lateral Acceleration switch
I need to replace mine on my 89. how hard to get to and where do i get one. Thanks!
Old Mar 17, 2010 | 10:36 AM
engle1147's Avatar
engle1147
I didn't think the '89 had one of those
Old Mar 17, 2010 | 12:51 PM
CAJUN C4's Avatar
CAJUN C4
If it does check right behind the Radio. That's where my 95's is.
Old Mar 17, 2010 | 02:54 PM
torchred89's Avatar
torchred89
Yea! Its says I have to remove Inst. Panel and Gages panel and console trim and Air con. control head. anybody done it and how hard
Old Mar 17, 2010 | 03:18 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
It's under the center console
Old Mar 17, 2010 | 03:30 PM
torchred89's Avatar
torchred89
Thanks! that don't look bad. Now I have find one
Old Mar 17, 2010 | 07:01 PM
SunCr's Avatar
SunCr
Did an ABS Tester show that it was open? Once you access or remove, terminals should show 0 Ohms with the Module in a horizontal positon; infinite when tilted. Pretty simple part, never seen one go bad (except with an interior fire, but then there was a lot of other problems too).
Old Mar 18, 2010 | 06:23 AM
torchred89's Avatar
torchred89
I replaced all four speed sensors. checked all fuses,checked all connections. The reason I think its that is, I was parking on the grass on a slight hill when the light came on. I'm thinking it's stuck. I will check Ohms. Thanks! any ideas accepted
Old Mar 18, 2010 | 08:52 AM
AGENT 86's Avatar
AGENT 86
Looking at my ABS info, it's actually under the AC control head, so it seems that you may not have to remove the center console.
http://members.shaw.ca/dankai/ABS.pdf
Old Mar 18, 2010 | 09:08 AM
Aardwolf's Avatar
Aardwolf
There is a very easy way to test it in the FSM. I may not remember perfectly, I believe you tip it sideways for a min and the ABS MIL should come on. There are two mercury switches inside.
Old Mar 18, 2010 | 09:15 AM
torchred89's Avatar
torchred89
Thanks! I'm going to start on it tommorow
Old Mar 18, 2010 | 12:46 PM
SunCr's Avatar
SunCr
If the ABS light is allready on, you should ohm it out with power removed - or maybe you can find a Tester somewhere (every now and then a Dealer has one) to determine exactly what the problem is. Can't imagine more than an hour of Shop time.
A vertical incline shouldn't effect the switch.
Don't know of any way to get at it without removing the Console Trim which means the Dash and Center Trim need to come off also and yes, you need to remove the HVAC control head once everything is out of the way.
Old Mar 18, 2010 | 01:39 PM
Aardwolf's Avatar
Aardwolf
It will read 0 ohms in it's normal position and (open) infinite tipped 90° from vertical.
Old Mar 18, 2010 | 02:14 PM
torchred89's Avatar
torchred89
It was actually horizontal. I was at a corvette show and they were parking us on the side of a hill.
To Lateral Acceleration switch
