SR runner help ASAP
Old Jun 17, 2010 | 02:06 PM
  #41
bill mcdonald's Avatar
bill mcdonald
They look like the ones on my car. I have 1.6 roller rockers as well.
Old Jun 17, 2010 | 05:34 PM
  #42
cumbercr's Avatar
cumbercr
The rockers are not the only clearance issue. I tried talls on mine but they interfered with the wiper controller. They angled in at the top but they were still too close. I used a cheap set of stock height aluminum covers from Summit. No clearance problems.
Old Jun 17, 2010 | 09:02 PM
  #43
John A. Marker's Avatar
John A. Marker
My LPE 74211 cam lifts the 1.6 RR to .562 for the exhaust. I am using stock 85 valve covers with the drip tabs cut off and ground flush with the covers. I also use a little taller gasket. The exhaust rockers were just kissing the VC (no issue with the intake). So I did this:
I sanded off 1/8" off the top edge of the RR. The picture shows the RR wrapped in masking take so when I sanded the edge I didn't get any particles into the bearings. These clear the VC without a problem now. No adverse effect to the RR's.
Old Jun 18, 2010 | 02:25 PM
  #44
Snakecharmer383's Avatar
Snakecharmer383
I got the intake off today...hoooooray! The T-handle did help for the bottom bolts..I only took one rocker off, 6 exhaust was in the way. I marked it at the 12 o clock position and counted how many turns (11.5) till it came off...I hope by doin this I can just retighten that many so I don't have adjust them.
I got a email back about the valve covers, he said they would work with roller tips but not full roller rockers?? I dont understand that honestly. I took a pic and sent it to him for a def. answer. I would like to get new ones but don't want to modify anything or devote more time.
Thanks to everyone also for all the info. Supplied in this thread.
Old Jun 18, 2010 | 03:04 PM
  #45
383vett's Avatar
383vett
If it is the #6 rocker arms you need to remove, it is really easy to adjust them. Find #1 TDC (timing mark on 0 and #1 cylinder intake and exhaust valves closed. Turn the crankshaft 1 full turn (360 degrees until you are back on TDC. This will place the motor at #6 TDC. Tighten the nut until there is no more play in the pushrod and tighten the nut another (whatever the specs are for your lifters). This will be a lot more accurate than counting 11.5 turns.
Old Jun 18, 2010 | 05:13 PM
  #46
bill mcdonald
He is probably not sure of the roller rockers locking bolt which sticks up a lot higher then standar rockers.
Old Jun 18, 2010 | 08:20 PM
  #47
Snakecharmer383
After sending the pic of the rocker, he is saying they will fit but to use a thick Felpro gasket. Part #1648 which are $35.00 according to him. I have not priced them yet.
I looked on my build sheet from LPE. Just says 1.6 ration stainless steel roller rockers. No specific one. Don't know if I should chance it or not. I think they would look niiiiicceeee!
383vett: you are correct, why take a short cut now.
Old Jun 18, 2010 | 08:29 PM
  #48
pologreen1's Avatar
pologreen1
You can get cheap ones at summit. starting at $59 for some plain chrome, and they will match the SR. I would clean your up.
Old Jun 21, 2010 | 12:10 PM
  #49
Snakecharmer383
What intake gasket is everyone using? I got felpro part # 1204 and the middle is blocked off. The old gaskets were blocked off in the rear and in my service manual it says the blocked openings should be in the front. So now I'm really stumped!
I also did find where the suspected oil leak was...passenger side about 1/2 inch in from head on the back of intake.
Old Jun 21, 2010 | 12:14 PM
  #50
383vett's Avatar
383vett
I use the 1205 Felpro gaskets. My ports are a little larger than stock. I don't run an egr so I don't need the middle opening. Can't remember about the water openings.
Old Jun 21, 2010 | 01:05 PM
  #51
pologreen1's Avatar
pologreen1
As long as the ports are all open to the same holes as the heads, and manifold you are ok.
i got scared with mine 2 weeks ago too. i seen they wre different than my old.
Old Jun 21, 2010 | 01:17 PM
  #52
Snakecharmer383
I don't know why I would have put gaskets on that have the rear passage blocked if there aren't suppose to be? Lookin at the bottom of the intake the middle are blocked so I think the felpro 1204 are correct....I think
Old Jun 21, 2010 | 03:51 PM
  #53
cumbercr's Avatar
cumbercr
I'm running AFR 195s with the SR. I used the Felpro 1205 gasket and I punched a hole for the EGR.
Old Jun 21, 2010 | 06:14 PM
  #54
pologreen1's Avatar
pologreen1
[/QUOTE]
mine were fine, i just had to think about it, and look at the intake for a second.
Old Jun 23, 2010 | 12:03 AM
  #55
Snakecharmer383
I'm gonna use the 1204's. I got alot of cleaning up done today but still have a long ways to go.
I got a call back from Proform today, rep. said those covers will fit but I will have to adjust the baffles a bit. He stated I have the pro mag rockers which I didn't know. I guess I'm going to pull the trigger.
Old Jun 27, 2010 | 03:32 PM
  #56
Snakecharmer383
Bill: did you have to do anything to your baffles? If so what and where.
Old Jun 28, 2010 | 10:06 AM
  #57
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Errror in FSM
http://forums.corvetteforum.com/c4-t...fsm-error.html
As for removing roller rockers, if you don't touch the lock screw, you can remove and replace rockers without worrying about preload, as long as the original rocker and adjuster nut are returned to their original stud.
When I was using the stock covers with my wide body rockers, I had to squish the baffle with a pair of channel locks, to clear the sides of rockers.
To SR runner help ASAP
Old Jun 28, 2010 | 02:36 PM
  #58
bill mcdonald
The chrome covers I have didn't have baffles.
I had to add in rubber gromits they had a slit for breathing.
Can these baffles really be any larger then the stock ones? The stock ones are huge.
Old Jul 1, 2010 | 11:26 PM
  #59
Snakecharmer383
Dropping the intake on tomorrow...let the rebuild begin. I hope it goes together better then the tear down.
Old Jul 2, 2010 | 01:10 AM
  #60
383vett's Avatar
383vett
[QUOTE=AGENT 86;1574531174]Errror in FSM
As for removing roller rockers, if you don't touch the lock screw, you can remove and replace rockers without worrying about preload, as long as the original rocker and adjuster nut are returned to their original stud.QUOTE]
This is not a 100% foolproof way of replacing rockers. When loosening or tightening the adjusting nut, the setscrew can move in relation to the nut which could result in an incorrectly adjusted rocker. I would take the time to readjust the rocker.
