It is AHHH-LIVE!
Old Aug 20, 2010 | 07:11 AM
  #41
Lemme's Avatar
Lemme
St. Jude Donor '10
Very impressive.
Are you still using the stock MAF (255 g/s)? If so you must be pushing the limits.
Old Aug 20, 2010 | 07:14 AM
  #42
Pete K's Avatar
Pete K
Looks great Gregg!
Old Aug 20, 2010 | 07:56 AM
  #43
WW7's Avatar
WW7
Glad to see you got that bad boy in..Your going to love a 383....WW
Old Aug 20, 2010 | 08:13 AM
  #44
bjankuski's Avatar
bjankuski
Originally Posted by GREGGPENN
I'm really happy. Plus, its running pretty darn well on the factory tune! (Some minor changes were made. As I drive it around, I wondered if it might take/like some extra timing, but not much to complain about. Nope, I can't complain... OTOH, it's time to plug in TunerProRT and see what's up. That'll be the next step.
BIG THANKS TO THE GUYS AT THE CF!!!
Greg,
Are you running the factory tune, or the chip I made for you? I believe you are running the chip that has the modifications made to support the larger injectors and other changes needed for your car. I would not want to give someone the wrong impression that the factory tune would work on your car with no changes. It is close but has changes needed to support your equipment.
Old Aug 20, 2010 | 12:17 PM
  #45
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Originally Posted by bjankuski
Greg,
I'm running the chip I burned using your parameters. So, the ECM knows the injectors are larger (and how they react at various voltages). I should have been more clear on this. Thanks Brian.
OTOH, I was suprised about how flexible the stock GM programming really is. Besides changing injector size/voltages, GM's program seems to be handing everything else pretty well. No codes and it's running pretty darn smooth. Thanks Brian!!!
Besides injector size/latency data, here are the other parms that were changed....
EGR off
AIR off
VATS off
WOT timing lowered for safety until more scans are completed
FAN turn-ons lowered to 195. (180 stat installed)
With the addition of a hi-flo water pump, I'm seeing max top-end temps around 215 degrees so far. My goal was to keep them down in the 205 range. (An alum radiator might still be warranted/ideal to create a good non-EGR environment.) Between that and the extra overlap of my aftermarket cam, this was how I'm address NOx fumes. Plus, I'm still running 6.2L-rated Magnaflow metallic spun CATS for hydrocarbons.
No emissions checks in my area but I want to keep it somewhat compliant.
Today I need to start running some scans to see if the motor is really as happy as it sounds!!!
  #46
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Clicked the video link. That's the stuff good, hard, firm, stiff, erections are made of right there. That thing sounds crazy dope!
I'll bet it runs like raped ape, too!
Old Aug 20, 2010 | 12:23 PM
  #47
GREGGPENN's Avatar
GREGGPENN
Originally Posted by Lemme
Very impressive.
Yes. And, IDK yet.
Old Aug 20, 2010 | 12:29 PM
  #48
GREGGPENN's Avatar
GREGGPENN
Originally Posted by onedef92
Clicked the video link. That's the stuff, good, hard, firm, stiff, erections are made of right there. That thing sounds crazy dope!
I'll bet the runs like raped ape, too!
From what I can tell so far! (Break-in is SOOO annoying! LOL)
Note: My vid is in photobucket. I'm thinking it doesn't do as well (with file-sharing and/or processor speed) as YouTube. Don't be suprised if it takes a few seconds for the video to load/play.
Old Aug 20, 2010 | 12:34 PM
  #49
Aardwolf's Avatar
Aardwolf
Be careful with WOT, the A/F ratio was way off on mine. Normal driving was fine with the stock tune. I plugged in a LC-1 wide band and WOT was 13.5! Mine pegs the MAF at 256, I don't think it matters for tuning the A/F with the WB.
Brian helped me out too. Thanks man!
Old Aug 20, 2010 | 01:01 PM
  #50
GREGGPENN's Avatar
GREGGPENN
13.5 doesn't sound "way off". Since PE is 12.5, you were still getting power enrichment and lower than stoich.
Hope I don't need a wideband (vs using BLMs). I just had the shop tack in a new O2 bung plug for the passenger side. The one that came with my headers had already vibrated out! LOL
Another funny story...
When I got to the exhaust shop (20 minutes from my home), I noticed antifreeze dribbling on the ground. Turned out I'd forgotten to tighten the bottom radiator (to radiator) hose connection. :o I'd only lost about an inch of water and it didn't blow off the tube. Guess I'm lucky!
I'm surprised I didn't see any drips after startup in garage and shorter runs around the block!!! (OTOH, the new hose was pretty snug.)
No other leaks though. No oil/fuel drips. Tranny sounds good (with new pilot bearing). Power steering is whining a bit though. It's the first time in 21yrs that it's been removed and COMPLETELY emptied. I wonder if it doesn't like fresh fluid or if it doesn't like that I used plain-old PS fluid?
Old Aug 20, 2010 | 01:12 PM
  #51
Aardwolf's Avatar
Aardwolf
The BLM's were great on mine but it was still to lean A/F at WOT.
Old Aug 20, 2010 | 05:28 PM
  #52
GREGGPENN's Avatar
GREGGPENN
13.5:1 doesn't sound "way off", but I understand power was left on the table. I'll use a dyno to tune WOT runs. (Do they put a WB in the O2 bung or measure at the exhaust pipe?)
Old Aug 20, 2010 | 05:30 PM
  #53
GREGGPENN's Avatar
GREGGPENN
Best thing I noticed today is that 3rd AND 4th gear pull WAY harder than they used to. This car is now a full-fledged sports car!
Old Aug 20, 2010 | 05:54 PM
  #54
Caboboy's Avatar
Caboboy
Congrats man, it's way cool to see your hard work pay off
Old Aug 20, 2010 | 08:12 PM
  #55
Orr89rocz's Avatar
Orr89rocz
quick check, is on a wot pull if you do one, watch the o2 sensor milivolts. They should be around 900-920mv for a fairly safe region.
My 383 was running ok on mild modifed bin, but WOT was 17 to 1 on mine Took alot of PE to get near 13.0
Old Aug 21, 2010 | 09:04 AM
  #56
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Nice work, she looks great !!
Old Aug 21, 2010 | 10:23 AM
  #57
STL94LT1's Avatar
STL94LT1
That may be the best looking C4 engine on this forum, good work!!
To It is AHHH-LIVE!
Old Aug 21, 2010 | 01:42 PM
  #58
alrosenzweig's Avatar
alrosenzweig
St. Jude Donor '11
after those pics.... I won't be postin mine that's just friggin unbelievable Gregg.... if mine takes 3 yrs the wife will either kill or leave me !!! Really nice work
Old Aug 21, 2010 | 10:53 PM
  #59
mrc24x's Avatar
mrc24x
Congrats Greg! Looks great!
Old Aug 21, 2010 | 11:05 PM
  #60
dogfish246's Avatar
dogfish246
WOW that sounds and looks really nice!!! And by the sound of it, it preforms well too!!!! I like the old school Corvette valve covers
