Sudden VATS Trouble ????
Old Jul 21, 2011 | 10:16 PM
  #41
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
VATS module is behind crash pad.
Old Jul 21, 2011 | 10:17 PM
  #42
AGENT 86's Avatar
AGENT 86
LOL, answered a post I opened before dinner.
Better late than never.
Old Jul 21, 2011 | 10:24 PM
  #43
Calderone's Avatar
Calderone
HAHAHA I know what you mean , happened to me a couple of times
Thanks !
Tomorrow will put the ground on "V" terminal and will know for sure if its :
Bad starter enable relay or .... Bad VATS Module !
Old Jul 22, 2011 | 08:53 AM
  #44
joe paco's Avatar
joe paco
before you replace the module, did you verify that the "security" was not blinking when key was turned "on"? still could be key related.
joe
Old Jul 22, 2011 | 09:35 AM
  #45
Calderone's Avatar
Calderone
you are right Joe ! yes it blinks on the RUN position, on the ON position it does not blink
Old Jul 22, 2011 | 10:15 AM
  #46
joe paco's Avatar
joe paco
mine does not, 91. read in owners manual or fsm that it blinks if the PASS key is not read. maybe someone can verify that for us.
mine is off in "ON" and start and run.
joe
Old Jul 22, 2011 | 10:31 AM
  #47
Calderone's Avatar
Calderone
Yes, hopefully someone can test it for us !
I Got a new set of keys coming here anyway, hope they arrive soon
But i bypassed the starter enable relay and that made the engine crank
that's why i believed the starter enable relay was the faulty part.
Old Jul 22, 2011 | 12:30 PM
  #48
wildbillmassey's Avatar
wildbillmassey
If VATS is not working, will the fuel pump still prime?
Old Jul 22, 2011 | 12:32 PM
  #49
Calderone's Avatar
Calderone
Not sure bill but my fuel pump still primes nice and loud ,
Guys ....is there any way to test the starter enable relay ?
Old Jul 22, 2011 | 01:10 PM
  #50
wildbillmassey
Where and how?
Old Jul 22, 2011 | 01:13 PM
  #51
Calderone's Avatar
Calderone
Behind the IP Panel,disconnect the starter relay and i connected a jumper between "E" (Yellow) and "A" (Dark Green/White line) connectors and engine cranks !
I read that somebody opened the relay , soldered something and made it work
Not sure if this is safe, i'd rather replace the relay, i don't want to cut the wires and put them together as well
Old Jul 22, 2011 | 01:20 PM
  #52
wildbillmassey
Behind the IP Panel
Forgive me, I know nothing about Corvettes (except how to change a Clutch Master Cylinder and warrant the car unstartable)
Where is the IP panel
Old Jul 22, 2011 | 01:22 PM
  #53
Calderone's Avatar
Calderone
Do you have the FSM ? If you don't , i tell you , its a must !
FSM : Factory service manual
Now , the answer to your question is HERE
Old Jul 22, 2011 | 01:26 PM
  #54
wildbillmassey
No FSM for Corvette. I am a Mazda Rotary repair shop, doing this job as a favor.
I have tons of FSM's for Rotary cars though.
I may have an old Mitchell repair guide though, just thought of that. Pretty much the same as an FSM.
Old Jul 22, 2011 | 01:30 PM
  #55
joe paco's Avatar
joe paco
fsm says "fuel enable and crank disabled."
  #56
Calderone's Avatar
Calderone
i see, hang in there and do a search , my solution can be your solution as well
pm me if you need pics or whatever for the 87 vette
  #57
Calderone's Avatar
Calderone
Fuel pump is alive ...so ...veredict is the relay ?
To Sudden VATS Trouble ????
Old Jul 22, 2011 | 01:39 PM
  #58
wildbillmassey
Thanks, found a Mitchell FSM for 91 GM cars. Wiring diagram shows starter enable relay and four wires, 2 Yellows, Black/Yellow stripe, and Yellow/Black stripe.
Is this located in the same spot on a 91 as the 87, and what wires would I jump. Both yellows go to ignition, Black/Yellow stripe goes to CCM, Yellow/Black stripe goes to clutch switch.
Old Jul 22, 2011 | 01:41 PM
  #59
joe paco's Avatar
joe paco
should conclude that it is NOT a VATS issue if fuel relay is on for the normal 2 secs.
"relay is energized when the ccm determines that all security conditions have been met."
not sure if yours has a CCM, don't think so.
I remind you that I am not the ECM/CCM expert!
I hate to ask: did you verify 12V at the purple wire leaving the neutral switch? If no voltage there WITH KEY TURNED TO START CK TERM E of the same switch, which is incoming yel/blk on 91.
joe
Old Jul 22, 2011 | 01:52 PM
  #60
Calderone's Avatar
Calderone
No , didnt check it , but i think its good, i tried the selector on other than park
(while the starter relay was jumped) and it didnt start, plus its brand new
thanks
