Method to bench test HVAC Programmer?
Old Nov 14, 2011 | 08:14 PM
VetteMed's Avatar
VetteMed
Default Method to bench test HVAC Programmer?
I have a HVAC programmer module (1996 automatic climate control), and want to test it to determine if it's functioning properly. Is there any way to bench test one of these?
Old Nov 15, 2011 | 11:15 AM
engle1147's Avatar
engle1147
Where there is a will there's a way. Know that even if you did power it up on the bench it would still be difficult to determine/conclude if it would be 100% functional once installed on an actual car with the rest of the AC system connected to it. It will/would be way easier to just plug it into the car and then check it.
Old Nov 15, 2011 | 11:49 AM
pcolt94's Avatar
pcolt94
You would have to have almost all the same electronic and boxes that the vette has in a test set up. The programmer works on a serial bus and a few discrete signals. There is also a lot that interaction that goes on during operation and you can't just put power to the box and have it do any of it's normal functions.
In some of the military testing for verification on Helicopters I worked on in a test setup, almost the entire helicopter electronics is duplicated for the entire system that is being worked on. Then any box can be connected and checked out for operation. If a box was bad, then it went to a lower level repair station.
So unless you are really geared up to test the boxes or modules, I would have to say that there is no way to test the operation of the programmer or control head. Some of the smaller less complex parts can be checked on a case by case basis
Old Nov 15, 2011 | 11:53 AM
VetteMed's Avatar
VetteMed
Roger that. Thanks guys.
Old Nov 15, 2011 | 01:27 PM
SunCr's Avatar
SunCr
A Tech 2 with the right cartridge will emulate the Controls and you use that to troubleshoot via the CCM link. Or you can access the Data Stream and get a binary number for the inputs and outputs (see Tech Tips) and with some logic, maybe figure it out. Board failures on this Year seem to be rare so you could post what it is or isn't doing. Most failures are: Temp Door isn't moving: stripped drive gear. Compressor isn't engaging: Open or intermittent Low Pressure Switch; Relay failure; Low or no gas for which there will be a troublecode; or Pressure Sensor failure for which there should/may be a code in the OB2 data stream. Or air flow is through the Defroster only - harness nipples are collapsed at the Programmer blocking vaccum and if it can't suck, it won't blow.
Old Nov 15, 2011 | 01:53 PM
VetteMed's Avatar
VetteMed
Well, I don't have a '96... I bought this module in a lot of spare parts from someone who turned their 96 into a track car, he said the HVAC worked totally fine when removed, but before I sell it I figured I'd see if there was any way to verify it. I guess i'll sell it as-is.
To Method to bench test HVAC Programmer?
