ECM- courtesy lights
Old Nov 16, 2011 | 03:33 PM
Grenkepr's Avatar
Grenkepr
Default ECM- courtesy lights
88, 35th anni. automatic. Replaced ECM and PROM which corrected the problems I was after. High idle, coolant fans not working ,etc. All is great now, except my courtesy lights won't turn off. Pulled the fuse to get them to turn off and that worked. But, when I turn on the ignition and, or start the car ,they come back on and won't shut off, even after 30 minutes of driving. This happens even with fuse out. I am missing something, but don't know what. They will shut off when turning off ignition. Any ideas ? Thanks.
Old Nov 16, 2011 | 03:43 PM
engle1147's Avatar
engle1147
Sounds like you may have pulled on some non computer related wiring when you removed/installed computer. Perhaps they hardware for the lower hush/knee bolster panel creating a problem. If this stuff if all you messed with then it might be a good idea to go back and retrace your steps by dropping the passenger side panel and taking a look.
Old Nov 16, 2011 | 04:06 PM
sailorsteve's Avatar
sailorsteve
Not quite clear on fuse in/out ...I think you said, lights stay on with the key off until you remove the fuse, then they go out. But when the key is on, the lights stay on with the fuse out- correct?
Could you have possibly pulled the wrong fuse? Not always easy to see which label goes to which fuse, I've made that mistake.
If the lights work with the fuse out, you could somehow have a short to B+ in the power side of the circuit, crossed wiring, or something. May or may not be related to the ECM replacement, but 9 times out of 10 a problem that appears after making a repair is related in some way to the work done.
If I've misunderstood, and the lights will not go out unless the proper fuse is pulled, you could check the various switches that turn the lights on- doors, hatch, headlight switch to see if any one of them is stuck closed.
Old Nov 17, 2011 | 09:54 AM
Grenkepr's Avatar
Grenkepr
Let me try to re-state this. After installing the new ecm, my courtesy lights would stay on 100% of the time. Never go off,even with ignition switch off. So I pulled the 15 amp courtesy/clk fuse and they did go off. However when I start the car they come back on and will not shut off,even after driving around for a half an hr. They do turn off when I turn off ignition. I'm totally confused. How can they work at all,with no fuse. Bought this car new,so maybe we are both getting senile.
Old Nov 17, 2011 | 11:33 AM
engle1147's Avatar
engle1147
I don't think you need restate anything. Go back and check your work.
If you want pull more fuses to see which other circuit is backfeeding the lights. Quite a few of the ciruits in your car have power all the time the relay, timers or computer controls (ECM/PCM) simply apply a "ground path" to complete a circuit. As mentioned above pull the passenger side hush panel (there a light and wiring mounted right into panel you might check there first) make sure you didn't bump or pinch any wires when you were in there before.
Old Nov 18, 2011 | 10:43 AM
Grenkepr's Avatar
Grenkepr
Thanks for advice. The hush panel is off as it needed removed to get the ecm out. Just can't find any loose wires. I agree with all of you tho'. If the problem wasn't there before the repair then it must be something that I caused. Grrr !
Old Nov 19, 2011 | 08:51 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
The only thing that comes to mind is, maybe your timer has failed in a way to allow power from gages fuse into light circuit.
Pull the gages fuse and see what happens.
Old Nov 20, 2011 | 02:43 PM
HlhnEast's Avatar
HlhnEast
Headlight switch on maybe? Make sure it isnt twisted to the interior lights on position. Dont feel bad if it is, I had the door panel lights on and thought I had a timer issue.
To ECM- courtesy lights
