Transverse Spring Vs. Coilover Lowering
Old Jan 20, 2012 | 07:55 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Originally Posted by qws
I found these by Bilstein, kinda neat 46mm which would be 1.82 inches are so. A 1-7/8 spring would barely fit over. But you would have to adapt the stud and TieBar on, but the compressed and extended lengths are very close 10 and 13 inches
http://www.summitracing.com/parts/BS...2030/?rtype=10
The 46 mm Bilstein's are not going to work with that spring, you first have to slide over the threaded sleeve, then the spring.
My rears are 46mm Bilsteins, and my sleeves that fit them are 2.350" OD, so a 2 1/2" ID spring is as small as I can go.
Old Jan 20, 2012 | 09:01 AM
qws's Avatar
qws
Originally Posted by AGENT 86
The metal dust shield just slips off the top.
Here is the shock from Bilstein's site
http://cart.bilsteinus.com/product/24-002288/1041219
I didn't realize they just slide off. Looks like for our cars that may just well be the easiest and best way to go it you don't mind using a non adjustable shock... thanks
Old Jan 20, 2012 | 09:23 AM
LD85's Avatar
LD85
You know, another approach is to cut the top parallel flat piece off so there is no top on it.
Then flare the sides out the way you want them, then weld 1/8" thick supports to the side of the tower, just take cardboard and trace a template of each side and cut a piece of 1/8" steel from Home Depot ,, same width and length etc.
Then buy a piece of 1/4" CRS thick by the length and width of the top plate on the car,, and weld it on the top and weld it to the sides, with the side and top pieces cut to size using just a basic band saw or cutoff wheel, this could all be welded up and you would be much much better off in terms of strength.
Old Jan 20, 2012 | 02:28 PM
USAsOnlyWay's Avatar
USAsOnlyWay
Those are threaded bodies so only the perches are needed, no sleeve. They might work, but I'd call bilstein to ask what spring sizes they can take. Also, if you are going to a different shock as opposed to Vette Bilsteins, you'd probably want to get them from Bilstein with a vette specific valving built in. Otherwise you might be at a handling loss when all is said and done.
Old Jan 20, 2012 | 03:22 PM
AGENT 86's Avatar
AGENT 86
I guess I should have opened the link
Old Jan 20, 2012 | 03:40 PM
87L98Z52's Avatar
87L98Z52
Here is a great source for the sleeve kits for the shocks.They also sell hyperco springs and all sorts of stuff!
http://shop.a1racing.com/coiloverkits.aspx
Is this where u are getting your sleeves from agent86?
Did you have your shocks modded for clips to retain sleeves?
Thanks man!
Old Jan 20, 2012 | 05:42 PM
AGENT 86's Avatar
AGENT 86
Thanks man!
A1 has all I needed, but I didn't want gold hats. Search my threads started and you will find my other Bilstein thread with links. I am using my phone, otherwise I would link you.
Old Jan 20, 2012 | 05:44 PM
AGENT 86's Avatar
AGENT 86
Oops, I will have the shocks grooved locally.
Old Jan 20, 2012 | 06:11 PM
qws's Avatar
qws
Bilsteins and parts ordered today..
should see everything in a few days...
Old Jan 20, 2012 | 08:41 PM
AGENT 86's Avatar
AGENT 86
Who did you order from ?
What parts you have coming ?
My front sleeve kits arrived today, they were supposed to be black, but they are silver. I will live with it
I mocked one up to get a rough idea on what I will need to do.
Looks like a flare of about 2 red hairs, will be required on the towers.
Sway bar relocation is most likely not needed, as a slight shaping of the backside of sway end link bracket, will give more clearance(bar it self is not even close).
I will know better when I get to the front, as I'm working on the back suspension now.
Neither of my kits came with snap rings. Yesterday I ordered the correct snap rings direct from Bilstein in California. If you need snap rings, call Wes at Bilstein, great guy to deal with and get info.
Old Jan 20, 2012 | 09:09 PM
qws's Avatar
qws
Ordered from summit, I had to buy the shocks as well. Since I have KYB there now.
Thats funny... I spoke to Wes today twice
The outside measurement of the springs are 2.25 inches so I was thinking of taking a 2x4 and cutting it to the correct size. Then trying to draw it up from botom of the tower using a large C-clamp. This way maybe it would keep the sides straighter and cleaner looking.
Old Jan 20, 2012 | 09:25 PM
AGENT 86's Avatar
AGENT 86
Is Wes doing the grooves for you ?
Old Jan 20, 2012 | 09:33 PM
  #33
qws's Avatar
qws
I talked to him about that. It cost 10 bucks ea to do them. Which is fine..however to ship from NY to CA takes 8 days then back would be another 8 days plus the cost of shipping. Add that to the cost of shipping everything to me first. I was very close to just buying exotic muscle's today. By the time I got done buying the parts $435, then it I did what I said above the differance would be only a few bucks plus less aggravation.
There is a CNC shop locally I'm gonna talk to.
Old Jan 20, 2012 | 09:49 PM
  #34
AGENT 86's Avatar
AGENT 86
I thought maybe you had Summit send to Wes and then to you.
Did you get snap rings from Wes ?
Old Jan 20, 2012 | 11:29 PM
  #35
USAsOnlyWay
Good work guys... You are going to make me regret buying these leaf springs!
Old Jan 21, 2012 | 01:21 AM
  #36
qws's Avatar
qws
No I haven't gotten any snap rings yet.
It was Dan that had gotten me motivated to move forward with this.
Old Jan 21, 2012 | 02:14 AM
  #37
grantar2's Avatar
grantar2
This is an 84,Z51 suspension
Rear height- floor to top of wheel well 27"
Front height- floor to top of wheel well almost 28"
Been trying to figure out for months why all of a sudden the height is so much higher. Haven't found any reason for it.... At this point I'm past that.
My Goal is to get the front down to just under 27", 26.75 would be perfect
A few weeks ago I raised the car up and removed the front transverse spring. I bought a softer spring from an 87... HMZ is the code. It has a higher arch than the Z51 I had removed.
I shaved the rubbers down to almost the spring... even have the new style retainers.....
The C4 had multiple spring suppliers, each apparently had it's own color code. There was a significant height difference between the suppliers. Changing springs is likely your answer.
then I got to thinkin..... maybe coilovers would be the best way to go. They would give definetly give me an adjustment of 0-3 inches to lower.
Now... I've been debating what if the monospring doesn't work the way I want it to... i don't want to do this job twice. So I started shoping around and asking questions/searching.
Bought the QA-1's.... they are NOT going in the stock tower..even if you flare the sides out. I do not have the ability to weld nor am I going to pay a welder to come to me.
Now I'm looking into using the 36MM Bilsteins with 1-7/8 I.D spring.
Now that you know what I'm up to which route would you go? (QA1's are out of the question at this point)
I've also searched an searched but can someone actually confirm that this size spring... 1-7/8 I.D actually work with just flaring out the stock towers?
A picture would be great if anyone has one.
To Transverse Spring Vs. Coilover Lowering
Old Jan 21, 2012 | 10:56 AM
  #38
oldalaskaman's Avatar
oldalaskaman
I was wondering about this version, good info, many thanks, bob
Old Jan 21, 2012 | 06:28 PM
  #39
qws's Avatar
qws
Naturally I don't have any parts yet to do the coilovers. However I was playing out in the garage and came up with an idea. I took a piece of PVC with an outside diameter of 2-3/8, which a 1-7/8 I.D spring should have an O.D of about 2-1/4. I made my pieces 11 inches long. Placed them over a KYB shock and bolted it up. Raised my lower control arm and came up with the following pics
I had plenty of room all the way around top to bottom. It didn't even appear to interfere with the sway bar joint. Of course the true test will be when installing the actual spring but I thought this is a positive result and if it does have to be flared it won't be by much.
Old Jan 21, 2012 | 08:09 PM
  #40
USAsOnlyWay
Looks like you and Agent86 both should be looking good!
