Transverse Spring Vs. Coilover Lowering
Old Jan 21, 2012 | 10:44 PM
  #41
87L98Z52's Avatar
87L98Z52
Originally Posted by AGENT 86
A1 has all I needed, but I didn't want gold hats. Search my threads started and you will find my other Bilstein thread with links. I am using my phone, otherwise I would link you.
Thanks man!
I found your thread and i see the rear sleeve kit but also seen you switched to a diff company for front?
Also,Can shocks be ordered directly from bilstein?I see the shocks on there site but no price.It would be easier because i could just have them machine groove for snapring before shipping shocks.
Any of you guys think about ordering shocks for drm?They have revalved bilsteins to there specs after race testing but they a bit pricey, $750 for for shocks?
Old Jan 21, 2012 | 10:50 PM
  #42
87L98Z52's Avatar
87L98Z52
Anyone have size and location of groove for snap ring numbers?
Gonna talk with a local person about doing it.
Old Jan 22, 2012 | 08:19 AM
  #43
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Originally Posted by qws
Naturally I don't have any parts yet to do the coilovers. However I was playing out in the garage and came up with an idea. I took a piece of PVC with an outside diameter of 2-3/8, which a 1-7/8 I.D spring should have an O.D of about 2-1/4. I made my pieces 11 inches long. Placed them over a KYB shock and bolted it up. Raised my lower control arm and came up with the following pics
I had plenty of room all the way around top to bottom. It didn't even appear to interfere with the sway bar joint. Of course the true test will be when installing the actual spring but I thought this is a positive result and if it does have to be flared it won't be by much.
I have mine sitting in there loosely, pretty much the same look. I see 84 has a different sway bar end link bracket that seems to give more room than my 86.
Old Jan 22, 2012 | 08:33 AM
  #44
AGENT 86's Avatar
AGENT 86
46mm: 1.910” – 1.903” o.d. with 1.906” nominal.
36mm: 1.512” – 1.508” o.d. with 1.510” nominal
Width would be determined by snap ring. Bilstein uses a .059 thick snap ring.
Here are Bilstein's part numbers for the correct snap rings for the early factory Bilsteins.
46mm part number is 2522880 and the 36mm is 2522870
Call Wes at Bilstein in San Diego, he could probably make it all happen and ship you complete coil-overs.
Old Jan 22, 2012 | 08:51 AM
  #45
qws's Avatar
qws
I had asked him about that and he had said he couldn't do it.
You have to buy the shocks at one of there dealers and have them shipped in the the size groove that you want.
Old Jan 22, 2012 | 08:55 AM
  #46
oldalaskaman's Avatar
oldalaskaman
I read on a thread here someplace that any machine shop could do the grooves if you know the spec's.
Old Jan 22, 2012 | 11:02 AM
  #47
AGENT 86's Avatar
AGENT 86
I know that he can't sell you shocks, but would have an authorized dealer near him.
Old Feb 7, 2012 | 03:25 PM
  #48
AGENT 86's Avatar
AGENT 86
My snap rings finally arrived, so I can get motivated now.
How's your progress going ?
Old Feb 8, 2012 | 01:26 PM
  #49
qws's Avatar
qws
LOL..nice,
Mine are all set and ready to go on the car. Installation looks to be a breeze. I may have to very slightly bend out the shock towers.
Shock and spring fit in the tower fine but the edges of the spring do touch the sides of the tower.
Top bolt and bottom bolts all line up nicely, and I may be able to get away with not moving the sway bar.
All and all looks very good..
I should have some pics within the next day or two
Old Feb 8, 2012 | 01:45 PM
  #50
qws's Avatar
qws
I couldn't wait any longer. I had to get them set in there. From the timestamp of my last post until now is how long it took to fit them in there.
Hope these pics help.
Old Feb 8, 2012 | 02:13 PM
  #51
87L98Z52's Avatar
87L98Z52
Sweet man!!!
Can you list links or part numbers where you bought your parts from,sleeve kit,snap ring,springs,and what springs you went with?
Also,who did you end up using to machine the snap rings?
Any pics with spring and sleeve off shock of the groove?
Thanks man!
Old Feb 9, 2012 | 12:33 AM
  #52
qws's Avatar
qws
Sweet man!!!
Thanks man!
Not just any machine shop. They need to be experienced and a have a lathe.
Bilstein can also do the groove for $10 each.
Snapring is from them also.
1-7/8 I.d spring...hypercoil
Bilstein coilover kit
Will cost you about $525 for a pair. Vs. $600 thru em, which is exactly the same thing. If you don't want the hassle then just spend the extra.
Old Feb 9, 2012 | 07:16 AM
  #53
87L98Z52's Avatar
87L98Z52
Ok u used the bilstein sleeve kit? Didnt u order everything from summit? Did they sell bilstein snap ring too?
With springs,i meant to say what rates you went with? I kmow most people use hyperco.
The sleeve kits seem cheaper from the link i listed in begining from a1 and they have the springs for like $60 each.
Thanks again! Cool project! I was gonna do this a long time ago. I remember i posted a thread about it and almost had my head bit off and everyone said jst call drm or em! Lmao
Old Feb 9, 2012 | 09:18 AM
  #54
87L98Z52's Avatar
87L98Z52
QWS,also,did you have that alum looking bushing above the gold hat made or did that come with new shock?
The bilstein coilover kit on summit shows everything black but yours has gold hat and spring seat?
Wondering if im looking at wrong one,you have a part number?
And do you have any plans on getting rid of rubber bushing at the bottom of shock?
Old Feb 9, 2012 | 10:06 AM
  #55
AGENT 86's Avatar
AGENT 86
Looking good
Be sure to keep us updated
Old Feb 9, 2012 | 12:33 PM
  #56
qws's Avatar
qws
After my pre-fitment, I'm starting to get a little more into this today.
Remember my towers are 84's so 85-87 may be slightly different.
First I needed to enlarge the hole at the top of the tower so the bushing would push thru.
I'm also not to comfortable with how close the spring sits next to the bottom of the tower so I need to grind some metal away. Yes since this pic a new stone as been put on..
Old Feb 9, 2012 | 03:18 PM
  #57
AGENT 86's Avatar
AGENT 86
Did you go with ES shock bushings on top ?
To Transverse Spring Vs. Coilover Lowering
Old Feb 9, 2012 | 03:50 PM
  #58
qws's Avatar
qws
Yes they are. Wait til I post the pic of how I opened up my shock towers!
Old Feb 9, 2012 | 05:13 PM
  #59
USAsOnlyWay's Avatar
USAsOnlyWay
Looking good!
Great updates, thanks!
Old Feb 9, 2012 | 06:11 PM
  #60
383vett's Avatar
383vett
Good job qws! Thinking of doing this with my 84 with drag shocks and soft springs. Unsure whether to trust the flimsy looking shock towers.
