Transverse Spring Vs. Coilover Lowering
Old Feb 9, 2012 | 06:26 PM
  #61
qws's Avatar
qws
Originally Posted by 383vett
Good job qws! Thinking of doing this with my 84 with drag shocks and soft springs. Unsure whether to trust the flimsy looking shock towers.
Thanks...but it was really because of agent86 thread that pushed me in this direction.
As far as the strength of the shock tower, I read a thread by plrx on another site that convinced me that they are stronger than we think.
Old Feb 9, 2012 | 06:43 PM
  #62
383vett's Avatar
383vett
I'll let you drive it for a few months. If your car isn't sitting on your tires, I might give it a try. Let me know if they collapse though. Remember, I coming down from bumper touching launches.
Old Feb 10, 2012 | 02:16 PM
  #63
87L98Z52's Avatar
87L98Z52
I just ordered ths kit from a1 racing products for the frnt with 10" 475lb hyperco springs.The shocks i ordered from summit,new bilsten sports.
And ordered some new moog upper and lower ball joints and global west uppper and lower a-arm del-lum bushings to free up the arms.
Old Feb 11, 2012 | 10:43 PM
  #64
qws's Avatar
qws
Here's the finished look. Only thing left to do is move the sway bar ahead 5/8 of an inch
Old Feb 12, 2012 | 08:30 AM
  #65
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I was hoping you weren't going to say that.
Where is the contact area ? Bracket tweaking/grinding is not going to work ?
Old Feb 12, 2012 | 08:57 AM
  #66
87L98Z52's Avatar
87L98Z52
If you get the heim joint sway bar end links it will free up some room,you might not have to move the sway bar.
Here it is from EM.
http://emracingcorp.com/scripts/prod...?idproduct=318
Old Feb 12, 2012 | 09:31 AM
  #67
qws's Avatar
qws
Me too, however you should see where in the pic below. I'm not spending the money for a new heim. I'm just gonna drill a couple of holes, relocate the sway bar and let that pull the heim forward.
Old Feb 12, 2012 | 10:00 AM
  #68
AGENT 86's Avatar
AGENT 86
Ya, I'm not forking out any cash for a heim, either. Your pic angle doesn't really give me a clear idea of how much and where.
I may make some sort of offset bracket, rather than move the bar, time will tell. I'm still fighting the shock eye removal on the rear.
Old Feb 12, 2012 | 10:05 AM
  #69
qws's Avatar
qws
Its not so much the bracket that's hitting, its the sway bar itself that's touching the spring
Old Feb 13, 2012 | 03:28 AM
  #70
Widebody's Avatar
Widebody
Default offset blocks
Dan, If you like, PM me your email address and I'll send you pics of the swaybar offset blocks my road racer buddy Superlund made up for me.
Old Feb 13, 2012 | 09:42 AM
  #71
AGENT 86's Avatar
AGENT 86
Looks like enough meat on it to allow a little grinding.
Old Feb 13, 2012 | 09:53 AM
  #72
AGENT 86's Avatar
AGENT 86
I see one of the pics you sent me, shows the side view of it. If you have others, please send them.
PM on it's way.
Old Feb 13, 2012 | 11:03 AM
  #73
qws's Avatar
qws
I was thinking that as well. Just not sure if I should be grinding down the sway bar?
Old Feb 15, 2012 | 01:41 PM
  #74
87L98Z52's Avatar
87L98Z52
46mm: 1.910” – 1.903” o.d. with 1.906” nominal.
36mm: 1.512” – 1.508” o.d. with 1.510” nominal
Width would be determined by snap ring. Bilstein uses a .059 thick snap ring.
Here are Bilstein's part numbers for the correct snap rings for the early factory Bilsteins.
46mm part number is 2522880 and the 36mm is 2522870
Call Wes at Bilstein in San Diego, he could probably make it all happen and ship you complete coil-overs.
Are these the numbers you guys used?The coilover sleeve kit i ordered from a1 race products came with a snap ring but its like .100 wide and is a rounded snap ring.
Are your snap ring retainers rounded n edges or do they have squared edges?
Also,how far up from bottom of shock did you guys machine center of groove?
Thanks guys!
Old Feb 16, 2012 | 07:42 AM
  #75
AGENT 86's Avatar
AGENT 86
Thanks guys!
My snap rings from Bilstein are flat with square edges. I haven't machined any grooves yet, as my project is a slow simmering one.
