A good Torque converter recommendation
Old Feb 2, 2016 | 09:00 PM
  #61
mrodoc's Avatar
mrodoc
Originally Posted by aklim
I'm not sure. Are you talking about the connector to the trans? If so, dielectric grease might keep water out and help it slide in smoother. It won't do anything for the heat making the plastic brittle. You can wrap it in heat resistant material and it makes it better but sooner or later, it will get brittle. If you are talking about the ground wires, I would chase the threads to make sure they are clean, squirt brake cleaner to wash out any shavings that came out, lightly wire wheel the bolt (DON'T GET CARRIED AWAY) and use anti-seize. If it seems too loose, use a lock washer. Maybe every few years when you drop the pan, if you can get to it, loosen the bolt and snug it back?
Thanks for the advice. These are the ground wires.
