6.0 LS Swap/Build
Old Dec 8, 2018 | 04:06 PM
  #101
84 4+3's Avatar
84 4+3
Originally Posted by Mike Holmen
Wow what a sweet looking car! What you got in for engine mods? Glad to see more LS engine swappers on this forum. Curious if anyone has done a diesel engine swap? I had a 6.6 LLY Duramax in my garage when I did my LQ9 swap, Probably easy get 1000rwhp and 2000ft*lbs out a duramax.
I thought everyone really hate me if I swapped in a diesel engine.
seeing an lly in the bay of my cousins sierra vs the 6.0l in my truck I'd wager a guess it probably wouldn't fit. It's a few inches wider longer and taller...
Old Dec 8, 2018 | 04:22 PM
  #102
MatthewMiller's Avatar
MatthewMiller
Why would anyone do that? It would be much bigger, heavier, and make a lot less power that whatever equivalent you could do with any version of an LS you'd want to try. I don't think making 1000hp (torque numbers are irrelevant to vehicle performance) with a 6.6L diesel is as easy as you think it is, either - at least if you expect it to last more than a few minutes. And if you could, the weight of the transmission you'd need to hold it (torque numbers very much matter here!) would add hundreds of pounds more. If you want easy 4-digit power, my friend at HPR has designed some 527ci LS engines (with taller deck height) that could do that with the smallest of turbos or a supercharger. Depending on the power curve you need, it could even do it n/a.
Old Dec 8, 2018 | 05:16 PM
  #103
Pwnage1337's Avatar
Pwnage1337
Christmas come early boys n girls
PRC LS3 heads. Titanium valve hardware, dual springs for .660 lift. Hollow intake valve upgrade so I can spin some RPM's.
I also got a bunch of other stuff - custom grind cam, timing chain, push rods, head gaskets, head bolts, lifter trays, etc
Old Dec 8, 2018 | 10:41 PM
  #104
1993C4LT1's Avatar
1993C4LT1
I can dig it
Old Dec 8, 2018 | 10:46 PM
  #105
Pwnage1337's Avatar
Pwnage1337
Originally Posted by 1993C4LT1
I can dig it
Hoping she makes at least 300 whp!
Old Dec 8, 2018 | 11:11 PM
  #106
Krusty84's Avatar
Krusty84
I think you will be in the mid to upper 500s at the crank so I think you will definitely make 300+ at the wheel... Haha...
Old Dec 8, 2018 | 11:59 PM
  #107
84 4+3's Avatar
84 4+3
Man this makes me want to build another engine...
Old Dec 9, 2018 | 12:42 AM
  #108
Pwnage1337's Avatar
Pwnage1337
I would love to make 425-450whp out of this.
It's exciting! The slow gathering of parts adds anticipation for sure lol
Old Dec 9, 2018 | 01:53 AM
  #109
Krusty84's Avatar
Krusty84
I think that is easily doable as long as you put a good air intake, good long tube and free flowing exhaust on it.
Old Dec 9, 2018 | 08:19 AM
  #110
cv67's Avatar
cv67
St. Jude Donor '05
Nice...doesnt take much to get one of those to run hard. Keep us posted!
Old Dec 9, 2018 | 12:19 PM
  #111
Pwnage1337's Avatar
Pwnage1337
Still need to buy
An intake
Oil Pump
F Body Oil pan
Lifters
Motor Mounts​​​​​
Starter
Offset Intake Rockers
Accessory Drive
Headers - Want to try to hack up some C5 headers
Ignition Controller - looking at the FAST EZ LS because it would probably work best with the rest of the FAST setup
Old Dec 9, 2018 | 03:19 PM
  #112
rlane5's Avatar
rlane5
rlane5, you have any pics of your ride? Sweet another LS C4. I thought that it was only Krusty and me.
I will take some pics the next time I go to my garage. I've had the LQ4 in my vette since 2013, and have the HCI since 2015. I'm going to either change to ported LS3 heads or a supercharger or turbo over the winter. But right now I'm looking at roll bars that will fit into the car. I was at the track, last week and I was told to slow the car down. I pulled the drag radials, off and stuck the street tires back on, and still ran 11.42 @ 118.9 MPH The car is detonating and it's on the rich side of the AFR. I needs a tune.
Randy
Old Dec 9, 2018 | 03:28 PM
  #113
rlane5's Avatar
rlane5
Old Dec 9, 2018 | 03:45 PM
  #114
84 4+3's Avatar
84 4+3
Originally Posted by rlane5
So you're from Jersey eh?
Old Dec 9, 2018 | 04:22 PM
  #115
Bigpoop's Avatar
Bigpoop
I've had great success with HP Tuners on Multiple GM cars....several personal corvettes
Old Dec 9, 2018 | 04:44 PM
  #116
rlane5's Avatar
rlane5
I have a EFI Live tuner program and trying to learn to tune with it. I had the program for at least three years
Randy
the reason I posted the pic was to show the CAI air ram on the bottom of the bumper
Old Dec 9, 2018 | 04:52 PM
  #117
Pwnage1337's Avatar
Pwnage1337
Randy
Any more detail? Looks like sheet metal. Looks interesting
To 6.0 LS Swap/Build
Old Dec 9, 2018 | 05:04 PM
  #118
rlane5's Avatar
rlane5
It is sheet metal, I fab up, I have a SLP air filter lid that comes thru the bottom of the radiator support, and I fab the air filter box tube so that it was larger. I made two different tube ducts one for a screened MAF sensor and for a cartridge MAF sensor.
Randy
Old Dec 9, 2018 | 06:20 PM
  #119
Bigpoop's Avatar
Bigpoop
EFI live....much better. More detail.
I too have it.. Harder to come off the benchtune.
God bless
Old Dec 9, 2018 | 06:42 PM
  #120
Pwnage1337's Avatar
Pwnage1337
Randy
Post some pictures if you can?
God bless
You have the best screen name on the forum
