Optispark Options
Old Aug 6, 2024 | 01:18 PM
Mitragorz's Avatar
Mitragorz
Originally Posted by rremesal
I have attached my experience working with the Opti for you to study
https://www.corvetteforum.com/forums...th-damper.html
https://www.corvetteforum.com/forums...84k-miles.html
Awesome, thanks for all that info! So this kit (https://bityl.co/RR4B) includes all the gaskets and seals I'll need for the job?
And is this the seal installation tool?: https://amz.run/9SaU
When you say a new water pump will come with o-rings, are those SEPARATE than what comes in the kit? Are they installed on the pump already?
Old Aug 6, 2024 | 01:30 PM
rremesal's Avatar
rremesal
Yes, the gasket kit you linked is the one. Remember, they are year specific! Notice the 2 o-rings for the water pump.
I almost got that tool from Amazon, but went with one slightly cheaper. Didn't work out. Try that and see.
If you buy a new water pump, it will come with the o-rings. I forget if they were installed; however, sliding the o-rings on the shaft will be the easiest part of this job. Either way, you'll have o-rings if you get the gasket set.
Old Aug 6, 2024 | 01:32 PM
rremesal's Avatar
rremesal
Also, check out rockauto. They have pretty good prices on the same items.
Old Aug 6, 2024 | 09:57 PM
IHBD's Avatar
IHBD
Pro Mechanic
Thanks for that. Is that visible with the opti still installed?
Yes. From the passenger side, with a mirror and a flashlight. It has to be clean enough to read.
Old Aug 6, 2024 | 11:59 PM
Slasheshat's Avatar
Slasheshat
Cruising
I'd hold out for a petris if you can. Talked to them yesterday and told me early september to be back in stock. Maybe get in contact with them.
I have my 94 with a vented petris for 2 years and 20k miles. They also have lifetime warranty for 55$
Old Aug 7, 2024 | 08:46 AM
Mitragorz's Avatar
Mitragorz
I was able to get a Petris from ZIP.
