6l80e
Old Feb 1, 2006 | 05:19 PM
  #101
arkansascorvette's Avatar
arkansascorvette
Default new trans
The new 6 speed auto trans has its own separate computer and harness, whereas the C5 the PCM controls the trans functions as well as the engine. From what I've been told it would be a nightmare and many dollars to make it happen. There may be fitment issues also in mating to the C5 driveline. I'll sit back and wait to see what happens.
Old Apr 9, 2006 | 02:59 PM
  #102
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Any updates on this Nick?
Old Apr 9, 2006 | 03:47 PM
  #103
NAVY08's Avatar
NAVY08
St. Jude Donor '06-'07
Nick is off on a cruise at the moment (the kind on a boat...in the ocean) Im sure he'll be back on the board when he gets back
Old Apr 9, 2006 | 06:31 PM
  #104
Bowtie8's Avatar
Bowtie8
I'm keeping my eyes on this as well.
I think the key will be once an Alpha controller is all in and functioning, then guys like RPM will get it to live thru 1200HP, then as Nick has said.
Build it and they will come!!!!!!!!!
giddy UP
John
Old Apr 10, 2006 | 08:06 AM
  #105
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
from what i was told that "they" are working on a "universal" trans controller..... as far as 6l80e still wasnt available last time i callled gean@fred beans. i have late model vette yard looking for trans, diff, torq, tube.
Old Apr 10, 2006 | 08:43 AM
  #106
Tsab's Avatar
Tsab
This Six Speed trans sounds like the way to go. I'm sure it will be released eventually just like the LS7 engine.
Old Apr 26, 2006 | 12:36 AM
  #107
GregRexAdams's Avatar
GregRexAdams
2nd Gear
Hello guys, don't mean to butt in on you, but I thought you might find this useful. I've been watching the 6L80E closely for another application. I may be wrong on some of this information, this is simply what I have been able to obtain thus far.
A friend of mine can get the 6L80E, if I remember right the price was $1,800, but you'd need the bellhousing (or whatever they may call it in this application) to fit it to the rear. That also doesn't include the TC or the *ouch* $1,000 core charge. Prices may have come down since I looked at that. At the time she looked it up, it didn't even have a part number and they were making them about as fast as they were being put in cars. If she ordered one, it was coming straight off the assembly line.
Also, as near as I understand it, you need NO computer to run it, it's all internal. You might have to give it some inputs, such as RPM, but the only real connection on it is diagnostic. You might be able to reprogram it for shift points, but that's unknown as far as I know of. The best bet is to hope the shift point on this one matches the one you need. I believe the C6 is at 6,500, and it varies by the application. I believe the Yukon has the shift point at 5,500. Since they are modular, basically any 6L80E, as long as it's an 80 series, should work should you need a different shift point.
Another problem is the torque capacity. While it's fine for a mostly stock car, modified could be a problem. The only real difference between the 6L80 and the 6L90 is the number of clutches, the other being programming. They do share the same case. So if you needed more torque capacity, you can buy a rebuild kit and use the clutches out of it. Unfortunately, this has its limit, but I've been assured that there is an aftermarket kit coming, but when is up in the wind.
Anyway, the morale of this story is...if you want the 6L80, you can get it and you might need a different driveshaft and you might have to play with the wiring a little. You also might need a different bellhousing. Other than that, it's about the size of the 4L80E, so it should work just fine for you guys. If you need a little more capacity, you can get that also. I have no idea on the shifter though, but you should be able to get one out of a C6 and wire it up. The paddle shifters would be gone, but you could wire up buttons, or use the shifter out of one of the Caddies that use a slap-stick shift method. The shifter and the driveshaft will be the hardest part of the install as far as I can tell, although there could be some issues with the stock ECM being upset that it's missing something, but that could probably be programmed out. When you shift more, torque management hurts more, so remember that.
Hope that helps you guys, I'm in a different situation with the tranny so I have to wait until the aftermarket rebuild comes out.
Old Apr 26, 2006 | 12:50 AM
  #108
Corvette4ever's Avatar
Corvette4ever
http://www.ls1tech.com/forums/showthread.php?t=495742
Old Apr 26, 2006 | 07:50 AM
  #109
NICK YOSKIN
St. Jude Donor '08
Originally Posted by Corvette4ever
thats hot!
Old Apr 26, 2006 | 02:40 PM
  #110
VETZILLA's Avatar
VETZILLA
Originally Posted by NICK YOSKIN
thats hot!
Wow, I have seen the Ohio Boys driving their turbo cars to the track running 8's and then driving home on the 4l80E. Anyone dare to ask how much for the setup yet. I'll start the biding @ $4,500.00 without the diff but but I'm shooting to low.
Mike
Old Apr 26, 2006 | 04:48 PM
  #111
NICK YOSKIN
St. Jude Donor '08
Mike
mike i think your way off!
BTW
new 6l80e will be 1800 then the torque tube 850 then the diff is 2100
then the stall....... then beefin' up the 6l80e
oh yeah the tcu......when it comes out
Old Apr 26, 2006 | 05:26 PM
  #112
NICK YOSKIN
St. Jude Donor '08
Mike
just got off the phone w/mike @ yank....oh no!!!!! i want one!
Old Apr 26, 2006 | 05:32 PM
  #113
0EG@EnglandGreen
Supporting Tuner
BTW
But you just have to go through a couple of Rodney or SLP 4l60e's to make it more than worthwhile.
I'm all over this when the hardened race version comes out from Rodney
Old Apr 26, 2006 | 08:52 PM
  #114
R&D's Avatar
R&D
What was the price Nick????
It looks very nice!
Old Apr 26, 2006 | 09:35 PM
  #115
Mike04's Avatar
Mike04
Old Apr 26, 2006 | 10:22 PM
  #116
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
I say give it up Nick
Old Apr 26, 2006 | 11:47 PM
  #117
GregRexAdams
2nd Gear
I'm still confused as to why you think one is required. According to all of my information, it's internally controlled, even the lateral g-force sensors are within the unit.
Aside from changing shift points or diagnostics, that is.
Old Apr 27, 2006 | 01:41 AM
  #118
STEALTH 99 C5's Avatar
STEALTH 99 C5
Interesting .
