6l80e
Old Dec 18, 2005 | 09:26 PM
  #61
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
Originally Posted by SFengineer
any progress???
no part # yet
i will call again mid week.
software will be the hard part.
Old Dec 18, 2005 | 09:45 PM
  #62
Internets_Ninja's Avatar
Internets_Ninja
I found an article that says the 6l80 will be in the 2006 vette.
http://www.corvetteactioncenter.com/...threadid=76092
Id rather have my M12 tranny instead of the 6l80 even if it would fit in my Z06. The 6l80 is a heavy tranny and Manuals are more fun
Old Dec 18, 2005 | 10:01 PM
  #63
NICK YOSKIN
St. Jude Donor '08
good find. not heavy, your thinking of 4l80e.
fun??? look at my car www.nick.neptune.com see atco vid
Old Dec 19, 2005 | 12:30 AM
  #64
Internets_Ninja
its heavier then the T-56 and 4l65
and nice video
I just sold my 10 second street car, it was an automatic and was fun and consistant. Now that I got my Z06 I love having a manual.
Guess its all about "preference"
Old Jan 22, 2006 | 10:00 AM
  #65
J.M.G.'s Avatar
J.M.G.
Is there any progress on fitting and adapting the 6L80E in a C5?
Cheers,
Johannes
Old Jan 22, 2006 | 01:25 PM
  #66
FreddyG's Avatar
FreddyG
There was a pretty good article about this trans in Nov or Dec. 2005 Hot Rod magazine.
Old Jan 22, 2006 | 03:00 PM
  #67
NICK YOSKIN
St. Jude Donor '08
Cheers,
Johannes
i spoke with gene@ fred beans about a month ago, not in stock told me to call back right about now. i will call early this week.
Old Jan 22, 2006 | 05:00 PM
  #68
NoOne's Avatar
NoOne
If it is a good unit and I could adapt the paddle shift and actually have it work well then I would do it.
Drive a GOOD paddle shifter car like an auto Mini Cooper S, granted not the fastest thing but the trans is done right.
Without the paddle shift I wouldn't consider it.
Old Jan 23, 2006 | 06:23 PM
  #69
J.M.G.'s Avatar
J.M.G.
Thanks’ for the update.
Currently I am quite undecided if I am seriously interested in this upgrade. My C5 is totally stock (except for a Blackwing and a Magnaflow + X-pipe) and I am basically pleased with its performance. However, when shifting from 3rd to 4th (stock shift point at 5,800 rpm ~ 143mph) engine speed drops down to 4,050 rpm…collapse of acceleration
As one can see these kind of speed very regular (and totally legal) here, I basically have 2 choices:
  • changing my differential (to 3.42:1) to displace this rpm-drop when shifting from 3rd to 4th to a lower speed (where the aerodynamic forces are a lot lower which should allow the car to pull stronger in 4th and bring it to the better rpm-range). A very nice secondary-effect would be that rpm at topspeed would approximately match the rpm of maximum horsepower.
  • changing the transmission to one with a closer gearing, i.e. 6L80E
Cheers,
Johannes
Old Jan 23, 2006 | 06:29 PM
  #70
NICK YOSKIN
St. Jude Donor '08
THE most difficult part of this retro fit will be the tcu. the tranny on those 6 speeds are totally different then current c5.
this is were dale cherry will come in, without him and his connections( ) it just simply wouldnt happen...period
QUOTE=J.M.G.]Thanks’ for the update.
Cheers,
Johannes[/QUOTE]
Old Jan 27, 2006 | 05:24 PM
  #71
NICK YOSKIN
St. Jude Donor '08
still no time when one will be in stock at warehouse
Old Jan 27, 2006 | 09:34 PM
  #72
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Why??????
I was really looking forward to you doing this mod, so I could take notes, see your failings and then do it right...
Just kidding :bb :bb
Old Jan 27, 2006 | 09:46 PM
  #73
NICK YOSKIN
St. Jude Donor '08
Originally Posted by EnglandGreen
Why??????
EG
getting the tranny will be the easiest part, installing will be the second easiest part. whats going to hardest is the unit that is going to made to control the tranny. and no, tci current tcu WILL NOT WORK.
if all goes right i should be the first w/6l80e then they will market unit
Old Jan 27, 2006 | 11:04 PM
  #74
Face's Avatar
Face
According to Yank, it would cost most than $10,000. No thanks!
Old Jan 27, 2006 | 11:22 PM
  #75
NICK YOSKIN
St. Jude Donor '08
good for them
when we do it for less we will talk again
Old Jan 27, 2006 | 11:43 PM
  #76
0EG@EnglandGreen
Supporting Tuner
EG
Sweet!
All this talk about 6L80E - has anyone looked at this????
http://www.gearvendors.com/cg2wd4s.html
Replaces the torque tube - costs $5000 and you get 8 gears !!
4L60E 4-SPEED AUTOMATIC OVERDRIVE
1st 3.06
Over 2.39
2nd 1.63
Over 1.27
3rd 1.00
Over 0.78
4th GM O/D 0.70
Double OD 0.55
Part # 3D4L68 - Corvette 4L60 Transaxle
Old Jan 27, 2006 | 11:49 PM
  #77
NICK YOSKIN
St. Jude Donor '08
Sweet!
1st 3.06
Over 2.39
2nd 1.63
Over 1.27
3rd 1.00
Over 0.78
4th GM O/D 0.70
Double OD 0.55
EG the point to running 6l80e is this...the 80# in the tranny idenity
do you understand?
To 6l80e
Old Jan 27, 2006 | 11:56 PM
  #78
NICK YOSKIN
St. Jude Donor '08
80 equals torque capacity rating.
if this tranny is as strong as 4l80e is going to be a bear.
Old Jan 28, 2006 | 12:00 AM
  #79
0EG@EnglandGreen
Supporting Tuner
Nick, I knew that - but I can only speak for myself when I say I would love 2 more gears - or just one more gear between 2nd and 3rd.
So - why not shoehorn the 4L80e into the C5 then?
Or put another way, what's the upper limit of the 4L60e in terms of torque? And here I am talking about a fully built tranny, not stock.
Old Jan 28, 2006 | 05:25 AM
  #80
Earl H's Avatar
Earl H
Sweet!
1st 3.06
Over 2.39
2nd 1.63
Over 1.27
3rd 1.00
Over 0.78
4th GM O/D 0.70
Double OD 0.55
What is the hp/torqe rating for the gear vendor's unit? $5K and $1.8K for the install...kinda steep.
