Overheating problems Poll and solutions
Old Jul 28, 2006 | 02:22 AM
  #101
LV Vette's Avatar
LV Vette
St. Jude Donor '08
Default FMIC is not worth the headaches
You know, from reading all the responses in this post, it seems obvious that the single front mounted intercooler is not worth the problems it creates with cooling. I don’t want to get into which setup makes more power. By looking at them both, it would make sense that the FMIC with shorter tubing would make a little more power, but is the little extra power worth all the headaches everyone is having with them? To me, it is just not worth it. JMHO
Thanks,
Clayton from Las Vegas
Old Jul 28, 2006 | 06:13 AM
  #102
Warp Factor's Avatar
Warp Factor
I'm not sure how you came to that conclusion. There are at least half a dozen responses (including the first 2) from people with single FMICs who say they're having no problem.
And there are posts from people with twin side mounts who say they are having a problem. There seem to be some patterns regarding brands............
Heat may become an issue any time power is increased.
A percentage of the energy from burning fuel creates power, and a larger percentage creates waste heat. Making more power means that there's more waste heat to get rid of. Even bone stock cars which operate for extended periods at high power levels (road racing) have
heat issues.
I'm not sure that spacing the intercooler from the radiator to allow air flow between is a good overall solution. It may allow higher air pressure and cooler air at the front of the radiator, but would also create higher pressure on the back side of the cooler, resulting in less flow through the cooler and resulting in higher intake air temperatures.
Old Jul 28, 2006 | 08:31 AM
  #103
eb02z06's Avatar
eb02z06
St. Jude Donor '08
This is weird. I talked to Slowhawk and he says he rarely has any of his cutomers complain about heat from Andy's setup. I also have talked to Doug from ECS and there intercooler is even larger than Andy's and cover the entire front end. He says he too rarely see's any complaints and when there are it's because the rad, condenser and intercooler are not spaced properly or are dirty.
Old Jul 28, 2006 | 08:49 AM
  #104
eb02z06's Avatar
eb02z06
St. Jude Donor '08
A while ago I posted pics of my condenser asking if anyone thought that his could be the reason for any over heating issues. Here is the thread:
http://forums.corvetteforum.com/show....php?t=1428327
I wish Andy or Doug would jump in on this thread and offer there thoughts solutions.
Old Jul 28, 2006 | 09:22 AM
  #105
LRD VDR's Avatar
LRD VDR
Originally Posted by vetterdstr
I have this on my car... and I am getting a new one in a few days to modify and see if I can improve on what I already have.
VR
I have one of those but I removed it when I did the ECS Novi kit!! I can't remember why I removed it!! Does anyone know if this will work with the ECS kit??
Shahram
Old Jul 28, 2006 | 02:01 PM
  #106
LV Vette's Avatar
LV Vette
St. Jude Donor '08
heat issues.
Maybe I should correct my prior post. From reading many of the posts in the FI section, there are a lot more overheating problems with a front mount intercooler then the side mount twins. True that many FMIC have solved their cooling issues, but look what they have to go through to solve it. The side mount IC’s are just plain more conducive to better cooling. JMHO
Thanks,
Old Jul 28, 2006 | 02:26 PM
  #107
#001 2001 Z06's Avatar
#001 2001 Z06
NCM, WSCC & SCC Member
Thanks,
With one exception, my STS TT FMIC runs about 70 degrees and cools the rest of my components. I think you will find the rest of the STS owners will say something similar.
If I used something on the side, that prevented airflow to my brakes, then I would have considerable heat to mitigate coming into the brakes, suspension and motor from that direction.
Old Jul 28, 2006 | 03:43 PM
  #108
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
I started out with the twin intercoolers on my car. They didnt cool down anything nor did they even cool themselves after a few WOT runs. The Twin IC LPE systems are different because they are ENGINEERED to work. I for one would rather do cooling mods to a single IC than switch back to a twin that couldnt cool itself.
ching... ching...
VR
Old Jul 28, 2006 | 04:15 PM
  #109
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
ching... ching...
VR
VR.............I was under my car today and the more I look the more I see why IC works as well as it does I still think the Tiger Shark front end is the only way to go time to drive gota
Old Jul 28, 2006 | 04:48 PM
  #110
eb02z06's Avatar
eb02z06
St. Jude Donor '08
I've been toying with an idea since I saw Andy's new setup and this is what it is. First off we need 2 aftermarket airbridges-like the one Jim Halltech sells. One would be the regular end the goes from the TB to the MAf. The other would be the end that he sells for the TRAP. The trap end would go into the superchager and the regular end would go into the TB. This would allow the the rad to be raise back to stock or at least very close. It will probably need some rigging to get the MAF to join the intercooler but with the silicone couplers and stuff out there I'm sure i can figure something out. I think this may work so i have emailed Jim Hall and I'm just waiting to see how much for 2 airbridges. The all that's left is something to seal off the area so the intercooler condenser and rad are sealed to picking up air only from the open area where the black cover goes. I think something on an angle would work better. As soon as I can get the airbridges I'm going to start working on this-I'll let you guys know.
Old Jul 28, 2006 | 05:03 PM
  #111
HIGHRPM's Avatar
HIGHRPM
...and if you move the intercooler into the TS nose, your temps (IAT and coolant) will radically drop....mine dropped 40-50 degrees on hot days. GM designed the radiator cavity to cool a stock n/a motor...placing the intercooler there reduces that volume and potential cooling.
VR..the original twins were too small for anything but a stock n/a motor....but the new ones are almost 100% larger in volume. The only answer is to see a side by side road test of IATs on the same car with a FMIC and then the new ATI high flow twins...say from ambients of 85-100+ degrees.
Old Jul 28, 2006 | 06:45 PM
  #112
NemesisC5's Avatar
NemesisC5
I don't know how many TigerShark front ends are out there but I do know they are much better for airflow than factory "C5" design. I have a TS & would immediatly purchase an intercooler for my application if I knew what & where to buy. Which intercooler do you have, what dimensions, & how much did it cost. I saw the pictures of your setup & it looks OPTIMAL!
Scotty
Old Jul 28, 2006 | 07:22 PM
  #113
LV Vette's Avatar
LV Vette
St. Jude Donor '08
Do you have any pictures of this? Sounds very interesting.
Which twin system did you have? The old 3.5” or the new 4.5”? How is the LPE different and could their improvements be done to the ATI twin setup?
Thanks,
Old Jul 28, 2006 | 08:39 PM
  #114
vetterdstr's Avatar
vetterdstr
I had the 3.5's and they were garbage.
VR
Old Jul 28, 2006 | 10:04 PM
  #115
#001 2001 Z06
Clayton, I made a grammar error previously and a correction above.
I tried to take good pictures of my brake package & suspension. To dark. I am going to need a lot of professional lighting to get pictures of it.
I am not big fan at all on blocking airflow to the front brakes in any way. If you do that, then you have two new very hot heat sources to deal with and brake fade as well after hit them once.
I just put a shroud between my radiator and intercooler, the car runs 180-192 now. 192 under full boost. Fans kick on at 190. 200-213 max now with the a/c on full blast.
HighRPM is albsolutely correct on this "placing the intercooler there reduces that volume and potential cooling." Anything in front of motor obstructs air flow in the engine compartment and may even contribute to producing heat.
Old Jul 29, 2006 | 12:31 AM
  #116
LV Vette's Avatar
LV Vette
St. Jude Donor '08
I tried to take good pictures of my brake package & suspension. To dark. I am going to need a lot of professional lighting to get picutres of it.
I agree with you 100%, but some people love the FMIC. If they want to deal with the cooling issues, so be it. I will be using the 4.5” twins with an alky system for safety purposes. So if I make 25 less HP, so what, my engine will run cooler and longer.
Thanks,
Old Jul 29, 2006 | 03:25 AM
  #117
Vince99FRC's Avatar
Vince99FRC
After reading all of this I am thinking I may need to investigate on all I can do for my upcoming FFHP single turbo setup. I know I need the heat extractor hood, but I am going to get that front screened license plate as well. I already have vents in my air dams. I live in Florida and it can get pretty hot.
To Overheating problems Poll and solutions
Old Jul 29, 2006 | 09:04 AM
  #118
vetterdstr's Avatar
vetterdstr
Thanks,
Glad you found a solution that fits you needs.
Old Jul 29, 2006 | 09:15 AM
  #119
peter pan's Avatar
peter pan
Life Time NCM #2196
Seems that what my mechanic did with modifying the intercooler setup and providing a space of 1" between the condensor, my DeWitts, opening up the fog light area and installing the LG license plate screen has put my single intercooler A&A laydown setup in the non-issue category. Had it out twice in the last week and both days temps hovering around 100 with high humidty both killers for FI. On the first day I was out running 3 back to back pulls max temp 199 oil 207 and then back into town in traffic 207, 215 and on Wed again on the highway 199 after a pull to 140+ and then back down to 194 on the cruise to the dyno to watch a friend who installed headers and cam for his tune. Non issue for me, and I plan on a Hill Country run today and I will report back the max temps as the above temps will be with us today and I plan on lots of boost and different speeds as the terrain will dictate the fun of my boosted runs this afternoon. Even a properly setup A&A kit will work fine with a single intercooler. Just my 2c
Old Jul 29, 2006 | 10:38 AM
  #120
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Thanks,
Clayton, You are 100% correct. Not only do I live in Las Vegas, but I also had a A&A FMIC setup on my car. WITH a 2" aluminum radiator & SPAL fans, I ran HOT HOT HOT.. Sometimes it got soo hot that my A/C shut off.
Currently, I have the Kenne Bell S/C and with the placement of the heat exchanger (right in front of the radiator) my car is running hot again. The good thing about this setup is that I am able to order the Tigershark front fascia and actually install a LARGER heat exchanger in the nose itself. This will virtually eliminate any heat issues.
This is NOT able to be done with any of the FMIC systems in our extremely hot climates.
The best thing you could have done is gone with the twin I/C configuration.
