Overheating problems Poll and solutions
Old Aug 3, 2006 | 11:53 AM
  #161
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Originally Posted by Hvymtlc5
Had my Procharger HO installed about two weeks ago. Drove it to work yesterday for the firs time and on the 10 mile drive home (with 3 stop lights) the car was running very hot. Hit 242 as I was pulling in the driveway. Turning the air off didn't help. Seems like the motor had reached it thermal limits and couldn't cool so the temp kept going up.
Where I' concerned is that that I lost my dual fans (temps never exceeded 200 before with the LS1 edit programming them to come on early) and this single one with the K&N taking up the other half the radiator. The single just can't do the job (IMO). Can't drive the car...don't quite know what to do with this 7K SC investment.
Is there a way to re install the dual fans and hook the air cleaner up some other way???
Dont take this the wrong way, but had you done "A Little" research (especially on this forum) you would have seen that MANY MANY MANY people have ripped that crap off the car and started over.
Unfortunately there is really nothing you can do but replace darn near the entire kit. Nothing about that kit works. And even if you do get it to cool down. You will see really high IAT temps, low boost, belt slipping, along with a few other things..
Sorry bud.
Old Aug 3, 2006 | 01:32 PM
  #162
Hvymtlc5's Avatar
Hvymtlc5
I really thought all this had been resolved by the time I bought the kit...the installer said he had no problems with heat in the recent Procharger installs...turns out the "new" kit was new, but from late 2002 manufacture.
Can some one direct me to a post where the radiator mod is discussed. Pretty much know now I have to move the radiator...how did you guys do it?
Old Aug 3, 2006 | 02:22 PM
  #163
FRCTony's Avatar
FRCTony
Just FYI, they still sell the old kit as the "HO" system. The new kit is called the "Stage II" system, and shares only the blower unit with the HO kit...
Old Aug 3, 2006 | 06:24 PM
  #164
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
FWIW, I recently had the LPE external oil cooler installed on my car. It has reduced my engine oil temps by up to 40 deg while cruising down the freeway. It also helped keep my coolant temps lower as well.
ching... ching..
VR
Old Aug 3, 2006 | 06:43 PM
  #165
Corvette4ever's Avatar
Corvette4ever
ching... ching..
VR
Where did you mount the LPE cooler?
Old Aug 3, 2006 | 06:47 PM
  #166
vetterdstr's Avatar
vetterdstr
Since my blower plumbing was in the way of the original mounting point choosen by LPE, it was mounted on a bracket on the framework of the car and placed right in front of the right hand open Z06 screen. a few feet of braided line and a few new AN fittings were used to lengthen the lines supplied in the kit. Oil temps drop like a ROCK when going from city driving to freeway driving!! Much more air than I had previously estimated flows through that open screen and totally quenches that cooler with TONS of cold air!! I am totally impressed with this mod!!
Here is a link to the oil cooler...
http://www.lingenfelter.com/store/rad-10.html
VR
Old Aug 3, 2006 | 09:06 PM
  #167
#001 2001 Z06's Avatar
#001 2001 Z06
NCM, WSCC & SCC Member
VR
Hehe.
Hmm using the Z06 vents...
Wonder who came with that idea?
Works well on external fuel pumps too.
Back under my rock.
Old Aug 5, 2006 | 12:29 PM
  #168
eb02z06's Avatar
eb02z06
St. Jude Donor '08
Steve I just saw these pictures-thanks for posting!
Originally Posted by peter pan
Arun, per your request I took a few pictures showing the spacing my mechanic custom did, it is hard to see how he cut the support frame and made his custom bracket to move the intercooler away from the condensor, I undid the plastic cover for you
From afar shot
Looking down the right front
Drivers side to see the spacing better
Looking down the drivers side
Some bottom shots, drivers side
And one bottom one passanger side
Not as thoughtful to take pictures while my car was put together like EG does, however next time I change the oil I will get some good pictures from the bottom close up and my mechanic has told me he has made a template of this, mine was the first he did this to, the other one he retro fitted Mikes99Corvette as he was having over heating issues and his is now setup like mine other than an A4, he sees about 5 degrees hotter water temp and about the same oil temps as I do. But he does not go out in the Hill Country like I do and do sustained abuse like I do
Old Aug 5, 2006 | 01:26 PM
  #169
LV Vette's Avatar
LV Vette
St. Jude Donor '08
Default Not for everyone
Peterpan’s setup looks nice, but the clearance is still pretty tight. I think how well it works depends on the climate you are in. Here in Las Vegas in the summer (115+*) there is no way that will keep the engine cool enough to be safe. JMHO
Thanks,
Clayton from Las Vegas
Old Aug 5, 2006 | 09:19 PM
  #170
xtream1's Avatar
xtream1
From: Stealth So Cal GOCC ...comming to invade your neighborhood soon
Thanks,
It also depends on what RPM you're driving at steadily and what speeds. For example, at 75 in 6th it may be fine while at 70 in 5th or 3rd at 45 it's steadily creeping up.
I think that besides looking at the front of the rad configuration one has to look at the rear of the rad to see how the air can come out....are any hoses etc blocking the flow?
Old Aug 5, 2006 | 09:43 PM
  #171
NemesisC5's Avatar
NemesisC5
VR
Sounds like a killer setup for oil cooler. I knew those side vents were for more than just looks. Have any pictures.
Scotty
Old Aug 5, 2006 | 10:11 PM
  #172
vetterdstr's Avatar
vetterdstr
Scotty
I will have to put some together and post them...
Old Aug 5, 2006 | 10:25 PM
  #173
NemesisC5's Avatar
NemesisC5
I look forward to seeing them. I too am in pursuit of lower(optimal) operating temperatures to keep my FI setup safe & crisp. I read some posts in the Tech section where members were removing & or drilling holes in the rubber flaps inside the vents. They all said you could feel heat being vented out. I never thought it would be a good place for oil cooler.
Scotty
Old Aug 6, 2006 | 12:31 AM
  #174
HIGHRPM's Avatar
HIGHRPM
VR
I did the same thing with a Setrab oil cooler....I mounted it in the left side cavity..... my S/C intake pipe/filter is in the right side cavity right behind the opening.....works great!
Old Aug 6, 2006 | 10:51 AM
  #175
vetterdstr's Avatar
vetterdstr
Scotty
Keeping in mind my Oe radiator shroud was removed some 4.5 years ago....
I completely removed the black backing that surrounds the factory road lights and installed the Z06 screen in its place just like a OE Z06. This way I get optimal air flow into that opening. I also installed the Halltech screen unit that takes the place of the front license plate in conjunction with the big mouth air dam (which directs cold air right behind the AC condenser and hits the radiator directly). Those two parts made the most difference on my car. With the heat extractor hood I've had for many years I just about have the most ventilated front end in town!!
Installing the oil cooler in front of the Z06 screen was about all we could do because I am NOT going to install it in line with my intercooler or radiator. End result was... that open Z06 screen area really produces the airflow... and it really does a great job providing air for that oil cooler. Example, I was out driving yesterday on the highway with the A/C on HIGH in 85 deg temps, coolant was 180 deg and the oil was 167 deg. Thats 40 deg cooler oil than before the cooler was installed.
VR
Old Aug 7, 2006 | 06:38 PM
  #176
hpcubed's Avatar
hpcubed
What are the approximate dimensions of your cooler?
Old Aug 7, 2006 | 06:46 PM
  #177
vetterdstr's Avatar
vetterdstr
Heat exchanger measures 11"x4"x2"
To Overheating problems Poll and solutions
Old Aug 7, 2006 | 06:48 PM
  #178
hpcubed's Avatar
hpcubed
Old Aug 7, 2006 | 06:53 PM
  #179
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
I guess S/C car don't need as much(OIL) cooling as TURBO's
Old Aug 7, 2006 | 06:56 PM
  #180
vetterdstr's Avatar
vetterdstr
yep you are right! For the size it works great on my car.
