dreaded 1514 code
Old Oct 2, 2007 | 11:00 PM
  #41
RJW's Avatar
RJW
From: Tinker till it blows... then back it off a notch, maybe!!
St. Jude Donor '08
Originally Posted by 95BlueBomber
Nicely said Nick, I must say if I had to pick 3 people that weren't termed "tuners" from the forum to tune my car it would be you, yoskin, and RJ. I think your alls solution is the only "right" one with a stock PCM, in order for everything to jive straight Nick probably needs a FAST system or some equivalent. A cable TB would not even cross my mind...
And I agree with RJ, at least 102 probably even higher
Yu don't want me anywhere near your car, bro...
My idea of tuning is to ebay the maf and intake manifold and slap a pd blower on it....
Otherwise is falls into the untunable category...
Sorry...old school sd tuner here...this vette stuff is fairly new to me...I'm a rookie...
Old Oct 2, 2007 | 11:11 PM
  #42
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
Originally Posted by RJW
But after Mike expalins it, who is going to translate it into English...
just kidding....
So Nick....any update???? Are you having success with the tuning???
actually no.....all final cuts made to fit the dual tips. now we are workin on the the mufflers and the 3" e cutouts. i also trouble shot the ebc problem....its identified. i should have the ebc and the exhaust complete soon then ill be able to get the car off the lift.
once off the lift i will literally drive 2 tanks fulls threw it....
i need to get it broken in...my rental is coming sooooooon!!!
Old Oct 2, 2007 | 11:46 PM
  #43
FreddyG's Avatar
FreddyG
Hey Nick! Have you pm'ed Dr.Phil? He's probably forgot more about turbo tuning than most of us know!
Old Oct 3, 2007 | 08:59 AM
  #44
NICK YOSKIN
St. Jude Donor '08
no doubt about Phil....i wanna try all possibilities before asking though.
i need to learn this stuff....from what i ve researched this looks to be the only work around. phil gets bugged alot and doesnt like spoon feeding people, which i understand. now rob if i lived near phil that would be a different story....my wife makes the BEST BUFFALO CHICKEN WINGS.. listening phil????
Old Oct 3, 2007 | 09:13 AM
  #45
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
Oh that's cute... that reminds me...
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old Oct 3, 2007 | 09:15 AM
  #46
NICK YOSKIN
St. Jude Donor '08
funny skinny
hey i kinda think i look good in pink!
Old Oct 3, 2007 | 09:17 AM
  #47
95BlueBomber's Avatar
95BlueBomber
Old Oct 3, 2007 | 09:27 AM
  #48
NICK YOSKIN
St. Jude Donor '08
the guys is to smart for me.....what mike theroizes that the 16bit pcm cannot handle the sliding decimel like the laters pcm can causing the the values to get ascude (gram/cly.) need him to jump on here.........
Old Oct 3, 2007 | 10:23 AM
  #49
RJW's Avatar
RJW
St. Jude Donor '08
What year is the car/pcm? 2003?
Old Oct 3, 2007 | 12:32 PM
  #50
NICK YOSKIN
St. Jude Donor '08
yes....apparently the packet used for the BE is very small causing some pretty bad delay.....using PE for enrichment.
look at this, i was hitting that grams/per cyl at only 13.X psi.
weird that the 1514 has 4.10 but yet its still enabled at the lower #
Found this on another site.....
"Check dynamic airflow.
If you are over 2.32 g/cyl you will get a 1514 no matter what you do to the 1514 table.
Drop your IFR and VE table by an equivelent amount (say 10 or 20%) and that will drop the dynamic airflow. If you still bang the limiter, go another 10%.
I have had the same problem on a 427 with a ProCharger F1R. I was getting a 1514 at 4000 RPM. It has 750cc RC injectors so my original IFR table started at 83 lbs/hr."
So then I checked your g/cyl on your log and it hit 2.45 when you had the issue (see attached pic).
I think it has to do with reaching the internal limits of what the pcm is programed to calculate, also when I loaded your file it said some of values were out of range on the boost ve, either way this would be worth a start.
Old Oct 3, 2007 | 02:53 PM
  #51
Skunkworks's Avatar
Skunkworks
The PCM CPU (microprocessor) is old Motorola MC68332 variant now Freesclae.
Some CPU details below...
Modular Architecture
*Central Processing Unit (CPU32)
*Upward Object Code Compatible
*New Instructions for controller Applications
*32 Bit Archirecture
*Virtual Memory Implementation
*Loop Mode of Insruction Execution
*Table Lookup and Interpolate Instruction
*Improved Exception Handling for Controller Applications
*Trace on change of flow
*Hardware breakpoint signal, Background Debugging Mode (BDM)
*Fully static operation
*System Integration Module
Dedicated Micro-Engine Operating Independently of CPU32
*16 Independent Programmable Channels and Pins
*Any Channel can Perform Any Time Function
*Each Channel has Six or Eight 16 Bit Parameter Registers
*Each Timer Function May Be Assigned to More Than One Channel
*Two Timer Counter Registers with Programmable Prescalers
*Each Channel Can Be Synchronized to Either or Both Counters
*Selectable Channel Priority Levels
From http://www.freescale.com/webapp/sps/...468rH3DgbNyDvb .
The CPU is 32 Bit but external data path is 16 bit (ram/Flash/misc...) although 8/16/32 bit read/write is not a problem.
Now the Micro Engine or TPU (Time processing unit) is what tracks engine angle (cam/crank), fires injectors and coils... is also 16 bit. The TPU if you read the manual, it was intended primarily for automotive use (engine control) and has native instructions (micro coded) to support reluctor wheel based angle detection and so on...
Now I have worked with MC68332 in the past on a R&D project so I do know it somewhat.
What I had mentioned to Nick Y was that there may be some sort of integer math based limitation. The 68332 is not a floating point processor and table lookup and interpolate instructions are 16 bit if I remember correctly, so some of the critical math, may and likely is 16 bit integer based especially if being passed to and from TPU.
It is not inconceivable that what engineers had as a design spec only supported X values (mass flow, fuel, RPM...). Or by putting putting in values that are beyond the scope of original design spec, calculations may be bouncing off max trap values or even math overflows resulting bogus outputs or results.
Again speculation on my part, but have seen it far too many times with integer based math. The reason I'm thinking this is, it's big engines with big boost that run into this problem capable of 2-3 times the horsepower PCM code was originally written for.
I won't get into details pertaining to integer based math, but can tell you if some values double it's not inconceivable that a math overflow can result in a complex equation, which is typically trapped, but still result is incorrect value and unwanted operation or error can result.
***Disclaimer*** I am not a programmer but have had to clean up others messes... my all time favorite is not trapping for divide by zero (it's infinite).
Mike
Old Oct 3, 2007 | 03:53 PM
  #52
95BlueBomber
Mike
you had me at "the", I am glad someone knows about this stuff....
Old Oct 3, 2007 | 04:57 PM
  #53
RJW's Avatar
RJW
St. Jude Donor '08
Divide by zero usually results in a program crash....so what is the pcm doing.?...it must have provisions to ignore/default to somethng in these cases.
Has the 1514 error been addressed in any more detail by top notch hpt tuners, or is fudging the ifr/ve the only known cure?
Old Oct 3, 2007 | 05:03 PM
  #54
FreddyG's Avatar
FreddyG
I was once told in a Novell Netware class that a Wise person realizes that he doesn't know everything, but knows where to look to find the answer! I'm sure that it's not like you bug him for everything that comes up with your car and he appears to be helpful, so you might want to overnight him some of those wings!
Old Oct 3, 2007 | 06:00 PM
  #55
NICK YOSKIN
St. Jude Donor '08
gotta fudge it....
yeah it would be nice to see some seasoned tuners jump on here
Old Oct 3, 2007 | 07:23 PM
  #56
RJW's Avatar
RJW
St. Jude Donor '08
Nick
I think that you'll be alright. It has worked for many in the past...
Just don't rush to get it finished. You've put in so much time already and you're so close,....so what's a bit more??
Old Oct 3, 2007 | 11:12 PM
  #57
NICK YOSKIN
St. Jude Donor '08
Nick
MY THOUGHTS EXACTLY!
To dreaded 1514 code
Old Oct 3, 2007 | 11:57 PM
  #58
FreddyG's Avatar
FreddyG
If it's any help Nick, the Guys using EfiLive are fixing the problem the same way by manipulating the IFR and the VE tables in their COS's.
Hang in there! You'll get it!
Old Oct 4, 2007 | 12:44 AM
  #59
RJW's Avatar
RJW
St. Jude Donor '08
You guys aren't as stupid as I look....
Old Oct 5, 2007 | 09:20 AM
  #60
Vince99FRC's Avatar
Vince99FRC
Can we just all get along?
