Winter Projects
Old Nov 29, 2010 | 07:15 PM
  #81
C5kid's Avatar
C5kid
Cruise-In VI Veteran
St. Jude Donor '12
Looks like I'll be doing a clutch.
Old Nov 29, 2010 | 07:57 PM
  #82
jobberone's Avatar
jobberone
jobberone
Decided to go with a FAST 102 intake instead of the LS2 on my LS1 motor. They want to use the LS7 throttle body. Why not use the FAST 102 throttle body?
Old Nov 29, 2010 | 08:11 PM
  #83
golfinz's Avatar
golfinz
McLeod RXT and steel FW...priced at around $1k shipped it can't be beat
Old Nov 29, 2010 | 08:54 PM
  #84
C5kid's Avatar
C5kid
St. Jude Donor '12
lol, i am looking at the McLeod RST
Old Nov 29, 2010 | 09:04 PM
  #85
TT Z06's Avatar
TT Z06
Old Nov 29, 2010 | 09:20 PM
  #86
golfinz's Avatar
golfinz
The RXT is only 140ish more and is worth it as it will hold a grip load more if you ever want more power
Old Nov 29, 2010 | 09:24 PM
  #87
Leukic's Avatar
Leukic
Well I just sent the money off today for Jon's HSW kit he was selling. So looks like I will be having this done sometime this winter.
Originally Posted by Superman09
I have a Harris Speed Works 90mm plate kit! It was originally a Dry kit and I purchased the dry-wet conversion for it so you can run it as either... wet or dry! System is complete! Comes with the complete plate system as well as MANY extras. What you get is:
HSW 90mm dry/wet plate kit, 10# bottle
HSW The Interface
HSW Microedge with Plus Progressive unit
HSW Billet Adjustable Bottle Bracket
HSW Dual outlet purge kit (NEW) w/ Install kit
Autometer Electronic Nitrous Pressure Gauge already wired in
HSW Remote Bottle Opener
HSW Bottle heater
HSW C5 switch panel
Old Nov 29, 2010 | 11:17 PM
  #88
jobberone's Avatar
jobberone
jobberone
Here are my soon to be acquisitions for my 347 TT build.
AFR custom heads - $4200
- Cometic boost head gaskets for heads - $160
- Yella Terra ultralight shaft rockers - $425
- Valve cover spacers/gaskets to clear rockers - $35
- FAST 102 Intake - $795
- Custom portwork for FAST intake by AFR (port match intake/exhaust & tunnel) - $375
- New LS7 throttlebody for FAST intake (port matched to intake) - AFR to complete - $525
- Custom Hardedned Pushrods - $100
- FAST fuel rails, mounting kit & fuel connections for LS1 install - $235
- MAP sensor relocate harness for new intake - $40
- Conversion harness to mount LS7 throttlebody on LS1 car - $60
- Gaskets for new FAST intake - $35
- Coolant block-off kit to mount aftermarket intake on LS1 car - $60
I will have a set of LPE prepped 243 heads which have minimal dyno time on them since rebuild recently for sale for $1000 if anyone is interested. These made 685 HP at 4800 rpm on 93 octane at 17lbs and made 635 on 13lbs at 6600 rpm. They have Manley severe duty SS valves and Comp Cam 921 springs with opening pressure of 130. Stock rockers. They have been moderately massaged and never milled.
Old Nov 30, 2010 | 02:30 AM
  #89
jmoody66's Avatar
jmoody66
Default Elaborate
Originally Posted by TT Z06
Chris, since you have the EB2 its not that hard to set up. Just time consuming.
Talk to me! I wanna know more. I know about one option out there but i want something more financially responsible......
Old Nov 30, 2010 | 02:39 AM
  #90
TT Z06's Avatar
TT Z06
Basically you set shift points in it that coincide to boost levels. It mostly reads the clutch vs rpm to determine what next level it will go to. At least thats how I understand it. It can also be done with WOT switches setup around the shifter. With each gear it hits a switch and adjusts boost.
Old Nov 30, 2010 | 01:20 PM
  #91
03redzo6's Avatar
03redzo6
thats my old kit
Old Nov 30, 2010 | 01:56 PM
  #92
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Im really more interested in a boost by MPH than using the switches around the shifter. Im worrying about those breaking with drivetrain movement. I know the eboost2 can do it, but I just need time to figure out how.
Old Nov 30, 2010 | 02:09 PM
  #93
TT Z06's Avatar
TT Z06
then you would be setting up a time delay. I have not looked into doing it that way however I saw that it can.
Old Nov 30, 2010 | 02:24 PM
  #94
Corvette-Chris
St. Jude Donor '08
This is what I am referring to, however, I haven't heard or seen anyone actually do it other than Louis.
Originally Posted by Louis @ LG Motorsports
I have a new solution for the guys wanting boost by gear. MUCH simpler to install, more of a MPH related system, however, still switches within a given MPH window for the EBoost 2.
Oh, its a 1/3 the price, and takes 1/2 as much time to install
The problem with the plate on the torque tube, is that it will fail. There is no room in there for the switch plate, so one instance of axle hop, and it will break a switch. It might not do it the first few times, but they will fail. There is simply not enough room.
My new system is mph based, switching the grounds for the Eboost, within each gear window. Pretty neat.
The other issue that I ran into with the actual gear based system- Say you set the car into spin- Naturally, a good wheel man would short shift to the next gear. However, with the old setup, it would toss you into the next higher boost window, causing more spin.
Now, you can set SP 1-4 to an actual MPH.
Louis
Old Nov 30, 2010 | 02:42 PM
  #95
TT Z06's Avatar
TT Z06
Did not know about that. Will be PMing Louis about this.
Old Nov 30, 2010 | 04:08 PM
  #96
Leukic's Avatar
Leukic
Originally Posted by 03redzo6
thats my old kit
Old Nov 30, 2010 | 10:36 PM
  #97
94-vette's Avatar
94-vette
1 Sending my stll in the box V1-Strim into Vortech to be upgraded to the SI-trim
2 Getting my gages and pod ready for install
3 Getting my Cam/Valvetrain parts ready to go in.
4 Possibly a clutch! (gonna need one)
5 mabe some 3.73's
To Winter Projects
Old Nov 30, 2010 | 11:23 PM
  #98
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
5 mabe some 3.73's
If you don't mind a recommendation, try the car without changing the gears first if you have 3.42's. A car that makes good power doesn't need gears unless this is going to be a purpose built car and you're trying to be banging the rev-limiter through the traps or something. JMHO.
Old Dec 1, 2010 | 02:22 AM
  #99
94-vette's Avatar
94-vette
Yeah Bret the gears were last don't really need them,but figured after all the others why not gear it.
But later this spring
1 harded outputs
2 ecs trans brace
Old Dec 1, 2010 | 12:17 PM
  #100
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
1 harded outputs
2 ecs trans brace
Do the shafts and brace when you do a clutch. You'll kick yourself in the *** if you don't. It will take less than an hour to complete both with the trans/rear out of the car.
