Winter Projects
Old Dec 1, 2010 | 01:40 PM
  #101
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Well after basically taking a year off from drag racing, (new baby-busy business-bla bla) it's time to come back with a bang. So it looks like 2011's mods to my vert will be;
Upgrade power glide main shaft for ZR1 diff and cradle
RHS 427
Callies Magnum crank
R&R aluminum rods
Diamond pistons
Mast heads
Jesel rockers and 9.04 lifters
ARE 4 stage dry sump
A1000 boost controller
And for the power adder, twin cogged NOVI 2500's.
I'll post up some pics of the set up when I have it in the car.
That should keep me happy for a while, and yes, I'll still drive it on the street.
Old Dec 1, 2010 | 01:56 PM
  #102
uniquec5's Avatar
uniquec5
RHS 427
R&R aluminum rods
Diamond pistons
Mast heads
RHS is the way to go in 2011!! Good luck with your build!!
Old Dec 1, 2010 | 02:55 PM
  #103
DOUG @ ECS's Avatar
DOUG @ ECS
Thanks!
Come on Sonnie, I spilled the beans, lets here your build!!
I have an F2 for sale if your thinking of going that route.
Old Dec 1, 2010 | 03:50 PM
  #104
jobberone's Avatar
jobberone
jobberone
And I thought I was a maniac!
Old Dec 1, 2010 | 04:49 PM
  #105
Mr.Big's Avatar
Mr.Big
Can't wait to see this!!!!!!!!!!!!
Old Dec 1, 2010 | 06:11 PM
  #106
DOUG @ ECS's Avatar
DOUG @ ECS
I have the brackets made, and the engine parts just have to be assembled but they are all here. I'm just waiting on some of the cogged pulleys and I have to make the balancer, but I'm close. This was all part of a master plan when I went to a manual rack and relocated the alternator to where the AC normally goes so I had room on the drivers side to do this.
This is what happens when you have an over active imagination and a CNC machine at your disposal.
Old Dec 1, 2010 | 06:38 PM
  #107
golfinz's Avatar
golfinz
Old Dec 1, 2010 | 07:21 PM
  #108
jobberone's Avatar
jobberone
jobberone
RHS 427
R&R aluminum rods
Diamond pistons
Mast heads
Nice heads. What kind of boost and fuel are you going to run?
Old Dec 1, 2010 | 07:40 PM
  #109
MJD's Avatar
MJD
Same as last winters project I never got to:
Old Dec 1, 2010 | 08:26 PM
  #110
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Taking a trip to RPM Transmissions for Level VII, built differential and stall converter. There is some other stuff in the works here as well.
Old Dec 1, 2010 | 08:29 PM
  #111
DOUG @ ECS's Avatar
DOUG @ ECS
On kill I expect that should make 30-35lbs, but I'm heading into uncharted territory for me, so ill let you know when I get there. Each 2500 could easily make 20 lbs plus, but I think the combo wouldn't net 40. Sticking with an air to air for street use, but a thicker core then our base kit, and C16 fuel on the track. I don't street race, so pump gas is fine for cruising around. Should be fun.
Old Dec 1, 2010 | 09:15 PM
  #112
jobberone's Avatar
jobberone
jobberone
30-35 is still a good bit. Should be a bear period esp on C16. Can I supply you with tires? Be safe.
Old Dec 3, 2010 | 12:44 AM
  #113
whitebullet7's Avatar
whitebullet7
almost done here and what do you think my car would make
Tsp 402 9:2:1
225 afr heads,ls7 lifters
Epp blower cam
1 7/8 american racing header system
d1sc-1,Ecs bracket with 3.4 pulley,Cartek flip drive system,Innovator West 8'' balancer
E85,120lbs injectors with aem driver box
A1000 inline fuel pump
Textralia triple disc clutch
Slp oil pump,double roller timing chain
Old Dec 3, 2010 | 09:13 AM
  #114
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Should make 750+ to the ground. Depends on how aggressively you tune it. E85 will take the timing though.
Old Dec 9, 2010 | 07:20 PM
  #115
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Got a couple things dropped off today!
The SpeedInc High-Flow rails will be up for sale because I didn't realize that the LS1 and LS2 manifolds actually had different mounting geometry. I thought the only difference was the injector dimensions. These will not fit my LS2 manifold.
Traction:
Fuel rails:
Old Dec 9, 2010 | 07:24 PM
  #116
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
Traction:
You will LOVE those tires!!!! No more spinny-spin...
Old Dec 9, 2010 | 07:46 PM
  #117
Philip@HPE's Avatar
0Philip@HPE
Former Vendor
RHS 427
R&R aluminum rods
Diamond pistons
Mast heads
To Winter Projects
Old Dec 9, 2010 | 08:00 PM
  #118
BLOWNBLUEZ06
Originally Posted by Philip@HPE
That makes 2 of us!
Old Dec 9, 2010 | 08:04 PM
  #119
BLOWNBLUEZ06
Here's a few pics of a small part of my project.
Old Dec 9, 2010 | 08:13 PM
  #120
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
What i the plate on the back for?
