The Forced Induction Crankcase Evac Thread
Old Aug 16, 2012 | 10:01 PM
  #81
minitech's Avatar
minitech
I got some blow by oil at the rear seal with my A&A Corvette S/C setup. I have a catch can between the valve covers and the S/C air cleaner.
If I put on a breather at the oil fill cap will that ease pressure and not allow the rear seal blow by?
Is there an electric pump that I could use with a vacuum switch to pull pressure from the crankcase with boost mode to prevent the problem? I have an 8 rib setup and don't see any easy way to get a mechanical pump in there, the reason for wanting an electrical pump.
Old Aug 16, 2012 | 10:09 PM
  #82
a/c man's Avatar
a/c man
you need a breather oil cap I have a nice billet one they cost 100.00 new! make me a offer mine is still new out of box.
Old Aug 16, 2012 | 10:49 PM
  #83
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Doug @ ECS what ever happened with the vac pump you guys were or are developing???
Old Aug 17, 2012 | 12:01 AM
  #84
fotoboy's Avatar
fotoboy
Pretty late in this thread but very interested in this! I went back and forth on pcv to breather setup for along time. What tipped my decision in the end was seening the new copo whipped camaro and it was just running breathers in each valve cover and nothing else so that's where's I'm at.
Old Aug 17, 2012 | 08:00 PM
  #85
TRIZ's Avatar
TRIZ
Big Thanks to "The Bat Car" for sharing your knowledge.
Old Aug 18, 2012 | 12:19 AM
  #86
Zeus-of-Boost's Avatar
Zeus-of-Boost
does this look ok????. i have a breather on the back side of the driver side valve cover to suck in fresh air and to vent air under boost.
Old Aug 18, 2012 | 09:58 AM
  #87
a/c man's Avatar
a/c man
yes but try to run one from your valley cover covers the cam under the intake the more the better
Old Aug 18, 2012 | 10:29 AM
  #88
MVP'S ZO6's Avatar
MVP'S ZO6
Scotty wil that breather fit the driver side rear valve cover? Or is that one to replace the oil cap?
Old Aug 18, 2012 | 09:51 PM
  #89
a/c man's Avatar
a/c man
oil cap!
Old Oct 10, 2012 | 01:24 PM
  #90
SuperSteve04Z's Avatar
SuperSteve04Z
Ive really only read the last 2 or 3 pages of this thread. I have seen oil blow by out of the rear seal using the RX dual valve can. I talked to Matt at RX Performance and he hooked me up with the Monster can. After I install it I will put an inline filter in between the valley cover nipple and map sensor to my boost gauge and use the gauge to measure crankcase pressure/vacuum while cruising and in boost. I am pretty sure that nipple is capped anyway after the install so it should be a good test. Anyone see a problem with doing that?
Old Mar 7, 2013 | 12:34 PM
  #91
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Getting my RX Monster 2 can in a week - already ordered!
I should of done this the right way a long time ago!
I had or lets say have a very bad design evac system right now and was breaking all the Evac "RULES" -
Thanks,matt
Old Apr 4, 2013 | 07:18 PM
  #92
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
Thanks,matt
Did you get the Monster can installed yet? Post pics please, I have no idea where to put mine, thing is huge!
Old Apr 5, 2013 | 06:23 AM
  #93
madmatt9471
No! I have not received the can as of yet - I ordered it March 5th, it has been shipped however and I am awaiting its arrival soon -
Just checked and according to the Tracking it won't be here till April 9th
All I want to do is get it put it on and finish the tune and drive it man!
I will post pics and stuff when I finally get it and install it!
Thanks,Matt
Old May 31, 2013 | 11:46 AM
  #94
MVP'S ZO6's Avatar
MVP'S ZO6
TTT. Doug????
No go? To expensive??
Old Jun 9, 2013 | 04:02 PM
  #95
BABYBUGY's Avatar
BABYBUGY
Ok so let me get this straight as I am a little thick headed
I have a sts twin turbo setup one of the first gen only one wastegate and only one
Scavenge pump it’s all good
I want to install a catch can and from what I have read in this thread
It seems to me that if I were to install a dual valve can I could get rid of the pcv switch
Am I correct in that ???
Old Jun 11, 2013 | 12:05 AM
  #96
tlove32's Avatar
tlove32
Thanks,Matt
Now I don't feel so bad. I've been waiting over a month for my Rx catch-can....
Old Jun 11, 2013 | 10:35 AM
  #97
MVP'S ZO6's Avatar
MVP'S ZO6
Tlove32 are you serious? Did you order it directly from rev extreme? Call them up. That's completely unsatisfactory.
Which can did you order?
To The Forced Induction Crankcase Evac Thread
Old Jun 11, 2013 | 11:29 AM
  #98
madmatt9471
I did with mine, ordered directly from them. But it just took that long.
They did field my calls to a certain extent.
But once I finally got the Monster2 C/C I was happy, just wish they were a stocking item, from what I understand they are made to order.
Thanks,Matt
Old Jun 11, 2013 | 02:24 PM
  #99
BABYBUGY's Avatar
BABYBUGY
yes the wait time is a killer i'm trying to get a retrofit hoses for my can
sent payment but no response yet very frustrating
Old Jun 11, 2013 | 04:45 PM
  #100
halltim's Avatar
halltim
I have a brand new silver dual valve RX catch can - never installed - $100 shipped if anyone is interested.
