The Forced Induction Crankcase Evac Thread
Old Jun 11, 2013 | 07:15 PM
  #101
BABYBUGY's Avatar
BABYBUGY
is it the montser can with an fittings ???
Old Jun 11, 2013 | 07:46 PM
  #102
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
I have a black one with slight use (dual valve) not the an fitting can the one with the check valves integrated into it. Only reason I switched to the monster can is because I'm making big boy boost. 90 shipped.
Old Jun 12, 2013 | 10:12 AM
  #103
halltim's Avatar
halltim
Mine is the regular model w/ dual check valve.
http://www.revxtreme.com/performance...al-check-valve
Old Jun 12, 2013 | 11:40 AM
  #104
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Yes!
You can either order it with -8AN or -10AN
Thanks,Matt
Old Aug 9, 2013 | 08:43 PM
  #105
danieloneil01's Avatar
danieloneil01
What about capping the TB and intake. And running a line from the passenger valve cover to "T" fitting to the valley cover with a line going to a catch can then to the air filter off a centri? I have the catch can between the valley cover and intake but would like more vacuum to get out the vapors since the oil cap with a filter mounted on top may not accomplish this.
Valve Cover -----------Valley cover
l
l
Catch Can
l
l
Air Filter
Old Aug 9, 2013 | 08:48 PM
  #106
MVP'S ZO6's Avatar
MVP'S ZO6
The idea is to have sufficient continuous crank case evacuation under all conditions. If you can do that then it don't matter how you hook up hoses.
Old Aug 9, 2013 | 10:22 PM
  #107
danieloneil01
I'm not a gear head, so if I did it that way, how would air get into the crank case if I was pulling a vacuum from the valley cover and valve cover? I'm assuming if I kept the oil cap filter in place it would just pull air straight from that. If I used the stock oil cap where would the air come from?
Old Aug 9, 2013 | 11:59 PM
  #108
Y2KRoadster's Avatar
Y2KRoadster
You can buy the RX Catch can setup and breather cap...it will accomplish everything you need. Air will enter through the breather on the passenger valve cover...work it's way to the driver side rear part of the valve cover, then exit out where the PCV valve was and into your catch can. The other two hoses go to your intake and supercharger intake duct to provide vacuum. There is one check valve on each hose. The way this works is, when not in boost...your intake will provide vacuum to the catch can, pulling air through the crankcase. When boost hits...the checkvalve on the intake closes, while the check valve on the supercharger hose opens and the supercharger will provide the vacuum while in boost.
You will end up capping the passenger valve cover ports and/or your valley cover vent tube (later model C5's)
Old Aug 10, 2013 | 12:16 AM
  #109
MVP'S ZO6's Avatar
MVP'S ZO6
What y2k said.
-8 lines work -10 are better.
I don't even suggest anyone using a line smaller then a -8 on a blown application.
Old Aug 10, 2013 | 10:09 AM
  #110
danieloneil01
Well I have a 2003 Z06 so I don't remember seeing anything on the driver side valve cover unless I missed it.
Old Aug 10, 2013 | 03:26 PM
  #111
danieloneil01
Also, is it going to hurt the blower if oil makes it past the catch can and gets lined with oil on the blades, volute, bypass valve or any other place within the blower piping?
Old Aug 10, 2013 | 11:47 PM
  #112
Zeus-of-Boost's Avatar
Zeus-of-Boost
OK WHAT EVER YOU DO. MAKE SURE IT IS VENTING PLENTY DURING HIGH BOOST PULLS.
I didnt have enough "vent " when i was on the dyno and i pushed oil past the rear main seal onto the clutch. Of course the clutch started slipping.
oil on clutch. I was 17.5 psi
This is what i did this go round.
And these 12an fittings will run to a breather can with a filter on the top.
Ill vent the valley cover to a can and then into the blower inlet
Old Aug 11, 2013 | 12:02 AM
  #113
Chris Stewart's Avatar
Chris Stewart
I have one for sale if you're looking, dual inlet
http://forums.corvetteforum.com/c5-p...ther-tank.html
Old Sep 10, 2013 | 08:21 PM
  #114
danieloneil01
I got a question on my setup.
I have a ECS blower and used the CC that came with the kit. I had it connected to the valley cover -> CC -> IM with hole on filter plugged. I was getting a nice amount of blow by. I recently got a RX dual catch can setup. It's installed like this
DS valve cover -> RX dual CC -> IM
Valley cover -> ECS CC -> RX dual CC -> Air filter
PS valve cover has the filter oil cap.
I kept the ECS CC just to help with getting zero blow by into the blower/piping/IC/IM. But I'm getting zero blow by now in any of the CCs. I removed the hose on the DS valve cover and it's pulling great vacuum. I removed both ends on the ECS catch can and I'm getting zero vacuum that I could feel. I'm not sure if you get a lot of vacuum off the filter while idling though. I checked to make sure I reconnected it right and it is.
Should I removed the hose to the filter and plug the hole and instead use a "T" fitting and connect the DS valve cover and Valley cover to the same hose to pull vapor out? How about instead of capping it I get another check valve and on the suction side use a "T" fitting and connect the IM and air filter hole with the check valve on the blower filter so while under boost the suction will come from the hose connected to the air filter?
Is it pulling so much vacuum off the DS valve cover that it's causing me to get zero blow by off the VC?
Old Sep 11, 2013 | 03:04 AM
  #115
MVP'S ZO6's Avatar
MVP'S ZO6
I don't like drawing from the valley cover. Especially on high boost applications.
Old Sep 11, 2013 | 11:54 AM
  #116
danieloneil01
Just cap it then and only pull from the DS cover?
Old Sep 11, 2013 | 05:27 PM
  #117
SmoothFRC's Avatar
SmoothFRC
what is considered high boost? i am looking to pull only from the valley cover with ~12psi.
it is an updated valley cover that the CTS-V runs, but not sure how the pcv is configured on those cars - are they pulling from anywhere else, or just the valley cover? (anyone know)
Main reason, my new billet covers have no pcv provisions and really did not want to weld into them.
To The Forced Induction Crankcase Evac Thread
Old Sep 11, 2013 | 06:31 PM
  #118
MVP'S ZO6's Avatar
MVP'S ZO6
That should be ok. IMHO 15 psi and up is high boost.
Old Sep 21, 2013 | 06:27 PM
  #119
danieloneil01
About 500 miles later and still no oil from both catch cans. I did get a bit of water but that's it. I still have the VC hooked up getting it's vacuum from the air filter which during idle is nothing so hopefully during boost it creates atleast some kind of vacuum. I'm still getting a ton of vacuum off the IM during non boost obviously and pulling the vapors off the DS valve cover with the oil cap filter in place.
When I had the cheap CC that came with my kit I had it like this VC -> CC -> IM and always got blowby. I verified the check valves in the CC do in fact work so I'm kinda lost on this.
Old Sep 21, 2013 | 07:19 PM
  #120
MVP'S ZO6's Avatar
MVP'S ZO6
It's not uncommon to go a full oil change and get less than a tea spoon. In fact that might be a lot.
