Auto Swap Thread
Old Apr 8, 2012 | 11:40 PM
  #201
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Originally Posted by NEMESISVETTE
Thanks for the response. Keeping this thread alive.
Im going from Stick to Auto in my FRC. I got the full harness from a same year Auto car. My manual wiring harness did not run to the connection of the swith under the clutch pedal. So are you saying I do nothing with the wires that went to the switch under my clutch pedal becouse the Auto wiring harness gets its safety start another way? Again thanks for your brain cells on this.
Not a problem.
Old Apr 9, 2012 | 12:46 AM
  #202
NEMESISVETTE's Avatar
NEMESISVETTE
Originally Posted by ajg1915
Not a problem.
lol..there was a question in there..lol
Old Apr 9, 2012 | 01:07 AM
  #203
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Sorry I missed it. When you add the RPM harness that controlls the auto tranny you'll pick up the purple and yellow wires in the engine compartment on C146. The purple and Yellow wires run through the tranny harness on the automatics to the saftey switch on the transmission that only allows you to start the car in park or neutral.
If that does not help drop me a Pm and I'll give you my mobile #.
Old Apr 9, 2012 | 11:03 AM
  #204
corvette8189's Avatar
corvette8189
I just ran wires from the neutral safety switch to the purple and yellow on the clutch pedal. But i still have the 6 speed harness so to me that looked the best way. I didnt touch any wires at the pcm. I also grabbed the reverse lights from that orange connector on the 6 speed harness and ran them to the nss.
Old Apr 9, 2012 | 05:49 PM
  #205
NEMESISVETTE
O..ok.. I got swapped full wiring harness's with a auto guy. I ran the harness already and at the pcm under the battery everything connected. Only thing is that I know have one extra round harness (its wrapped with the white tape). I assume its the one harness that is automatic specific.
Does the harness that you used from PCS TCM 2000 connect to it? Im going to use them like you did. Hope that made sense.. lol
Old Apr 9, 2012 | 05:53 PM
  #206
corvette8189
i dont think so, when using the pcs 2000 you only hook up a couple wires. Your doing it different than i did. Id call RPM and ask.
Old Apr 17, 2012 | 09:29 AM
  #207
NEMESISVETTE
I hope the OP dont mind but this thread has so much great info on doing Auto swaps that im going to add some of my progress to it.
Well last week I drove half way to another CorvetteForum member who wanted to do a 6speed conversion and me wanting to do a Auto conversion in my FRC. So we meet up and swapped parts. Here is a pic of all the Auto stuff I got from him.
Then got on the phone with RPM and ordered the PCS TCM-2000 automatic transmission controller. Also ordered a stronger converter drive plate. Im going to call RPM back and order the stronger FlexPlate assembly this week.
Old Apr 22, 2012 | 11:07 PM
  #208
4DRUSH's Avatar
4DRUSH
Next is to track tune with Brett and bust off some low low 9's
Old Apr 22, 2012 | 11:16 PM
  #209
corvette8189
Originally Posted by 4DRUSH
Haven't had a chance to go yet but hopefully soon.
Old May 10, 2012 | 11:20 AM
  #210
NEMESISVETTE
Im almost done with my auto conversion here are some pics,
Here is the part number and fitting if you want to adapt a factory trans line to a -6. I think this is valuable becouse I ordered 3 different fittings trying to find the right one. Many people have give the wrong fitting size for this adaption.
Stock Converter drive plate vs. QuickTime upgraded one.
Old May 10, 2012 | 11:22 AM
  #211
NEMESISVETTE
Im about to call RPM to see if they can walk me threw a base tune for the trans. Another funny issue is for some reason my brake lights stay on when I turn the key to accessories?
Any ideas why my brake lights are on all the time? I must have something wired funny or am I missing a wire I should have wired up for the auto?
Old May 10, 2012 | 11:42 AM
  #212
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Without the ignition on does your brake lights work ?
Old May 10, 2012 | 04:51 PM
  #213
NEMESISVETTE
Figured it out..lol.. it was just the switch above brake pedal out of position.. I moved it down. guess i forgot when I changed out the pedal. Issue now is a trans leak at the union of factory line and -6 line. Sucks cuz I have to take all exhaust and headers out to get back to it!
Old Jun 2, 2012 | 01:07 AM
  #214
BuddhaZ06's Avatar
BuddhaZ06
quick question...
if you get the tcs2000, you will not need an auto harness from an 01+ car OR rpm's adapter harness, just the tcs2000 and hook to trans and ur good to go and tune it with the controller, not from the tuner himself? sounds like a lot easier route. i'd be spending close to $500 just for all the wiring compared to $700ish for controller.. seems worth the 200 to me!
Old Jun 2, 2012 | 01:41 AM
  #215
RonSSNova's Avatar
RonSSNova
At what power level level is the stronger flex plate assembly needed?
My car is an A4 car, just wondering as I hope to go bottom 11's.
Ron
Old Jun 2, 2012 | 02:03 AM
  #216
corvette8189
Originally Posted by BuddhaZ06
quick question...
That's right just the controller and the harness that goes with it. The pcs comes with its own software to tune off of.
Old Jun 2, 2012 | 02:05 AM
  #217
corvette8189
Ron
you should be fine, but if/when you change converters or tear it apart you should upgrade, its cheap insurance.
To Auto Swap Thread
Old Jun 2, 2012 | 03:37 AM
  #218
RonSSNova's Avatar
RonSSNova
Might have gotten lost in the terminology. I meant the assembly on the flywheel, not the converter. Sort of seems like there are 2 flex plates.
Thanks.
Old Jun 2, 2012 | 10:44 AM
  #219
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Thanks.
My guess is around 550HP or more it's time to upgrade. By then the Torque tube inners also need to be upgraded. At some point when the couplers start to deteriorate you'll need to pull everything down anyways and that's when I would take care of it along with a blow housing.
Old Jun 2, 2012 | 12:18 PM
  #220
Chris Stewart's Avatar
Chris Stewart
Thanks.
You also need the SFI flexplate to pass tech for running 10's.
