More Vortech Problems
Old Sep 18, 2004 | 09:35 AM
  #61
NBMDVM's Avatar
NBMDVM
You guys have a lot more patience than me. I loved the power of the Vortech and the stealthy sound, but after a late night flat bed, squeaking pulleys, lost belts, multiple sets of spacers, an oil leaking head unit(all within 1000 miles)...I gave up and went with the Mag. No, it isn't as powerful as the vortech, but it has been trouble free since day one and makes more power than I can put to the ground on street tires anyway. Good luck getting your set-ups to work, but I think there is just something fundamentally wrong with the design that no amount of spacer or idler or belt changes is going to fix.
Scott
Old Sep 18, 2004 | 09:45 AM
  #62
7LitreC5's Avatar
7LitreC5
That is really cool that DTE sent guys to fix it for you. That is darned good service!
Originally Posted by Z06 Tom
The worst part is having the thing let go hundreds of miles from home. I guess I need to beat on it locally to be confident in it away from home.
Good luck sorting out your set up!
Old Sep 20, 2004 | 09:41 PM
  #63
MelloYellow's Avatar
MelloYellow
P.S. I'm hearing a squeak from the old GM Stock Accessory Idler on cold starts. There is a TSB for all Model Years to replace this part as needed. I'll be replacing mine shortly. Not truely a Vortech issue.
Old Sep 20, 2004 | 09:47 PM
  #64
Yano's Avatar
Yano
UGGGGHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!
Vortech sent me the wrong SQ T-trim. So now they are saying 3-5 days to build a new one and 3 days to ship it. I wont have my car done now till next Friday
what do you guys think of that new HP TT kit??? I am thinking about going to that kit.
Old Sep 20, 2004 | 10:01 PM
  #65
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
sent you a message
Old Sep 20, 2004 | 10:02 PM
  #66
MelloYellow
What unit did they send you??
LOL, buying a T-Trim and thinking of switching to a Turbo?
Old Sep 20, 2004 | 10:21 PM
  #67
Yano's Avatar
Yano
My kit is the RMCR kit. The SC is on the passenger side, so I believe it spins the opposite of their Vette kit. Also, the oil lines are in the wrong place, and something else was.
My tuner said its a whole different case completly .
Gary sent you back a PM. I couldnt find any info on the FLP kit.
I see HP Tuner, Rob Rayner (sp?) and LPE.
I just want a kit that is very done, and can get me into the low 10's or high 9's at our altitude. I think Bandimere is at 6050 and PMI is around 5000 ft above sea level.
I am not sure if the SC can do that here. Maybe it can be my next winter project
Old Sep 20, 2004 | 11:20 PM
  #68
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Well, it is because it's new. However all the fitting and R&D was done about 6- 8 months ago. I have been waiting about 6 weeks for a few items. One was my 383 being built and 2nd the first custom turbo's were machined wrong. All the parts are there. I have been told I will get it this week. Because I have a new clutch to beak-in I will have a basic tune to get me through the weekend. Then it will be back a FLP for the tuning. Goal is 700-750rwhp on pump gas.
Old Oct 9, 2004 | 04:32 AM
  #69
MelloYellow
Final Setup:
Qty 3 - .740" Alternator Spacers from Vortech
Qty 2 - 1.277" Tensioner Spacers from Vortech
Qty 2 - .030" Shims, 1 under each Tensioner Spacer
I replaced the Vortech supplied 1-shoulder pulley with a custom pulley and this has resolved my belt jumping issues. The supplied Vortech pulley is just way too small in width to accomadate the stock sprung tensioner belt movement. If anyone is having belt jumping problems, PM me for details.
Checked the above with a laser alignment tool and the passenger side Alternator Puley and stock 6-Rib Idler were aligned perfectly with the crank using the above setup.
Old Oct 13, 2004 | 01:19 AM
  #70
COLORADO FRC's Avatar
COLORADO FRC
Use this link to see my RMCR set-up. Click on the 'Our Members' button in the left margin, go all the way to the 2nd to last name from the bottom and click on the far right link if pasting this into your browser doesn't work. Heading to the dyno on Friday (hopefully) to see what she'll do. Been working on this one since February, recently broke a valve spring and had some tuning issues (was running very rich!). I think we have everything worked out now, so should turn some decent numbers.
http://www.cscsc.org/MemberPics/Yaninek-Steve.htm
Old Oct 13, 2004 | 02:14 AM
  #71
MelloYellow
Wow, that looks a lot like the PTC setup.
Where did JB get his 1st Vortech installed? PTC ??
Old Oct 13, 2004 | 07:42 AM
  #72
7LitreC5's Avatar
7LitreC5
Nice setup!.
Mine will look like that soon but with different color tubes.
Old Oct 13, 2004 | 10:37 AM
  #73
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
I may have missed it in the topic but, what is the ballpark price on a RMCR Vortech setup minus the fuel system as I would most likely get a complete racetronix setup or something close?
Also does it uses a countershaft like the Vortech system?
Old Oct 13, 2004 | 11:09 AM
  #74
7LitreC5's Avatar
7LitreC5
The RMCR setup is only sold turn-key at this time. Mine will only be the 7th one that they have done. I think that it is about $10k out the door with a Racetronics pump. I am not exactly sure as RMCR worked a deal with me since we are using some parts from my Vortech kit.
It does use a CCW head unit like the Vortech kit and is driven through a jack shaft. They use 2 readily available 4-rib belts side-by-side to drive the head unit from the jack shaft.
The RMCR setup currently accomodates V-1 and V-2 head units in E-Trim, S-Trim, SC-Trim, and T-Trim. In the coming months RMCR will be working on modifying the setup to accomodate JT-Trim head units as well.
Old Oct 13, 2004 | 12:24 PM
  #75
COLORADO FRC
The $10,000 is the installed price. I know RMCR also ships the kit out for much less. I've heard it's very complete and the directions are very good.
You can call them at:
719-574-0625
Old Oct 13, 2004 | 01:34 PM
  #76
MelloYellow
It is CCW with RMCR also.
Why did Yano send his CCW back?
Old Oct 13, 2004 | 01:39 PM
  #77
7LitreC5's Avatar
7LitreC5
So that you could get yours quicker!
Actually the case on the blower for the Vortech kit and the RMCR blower is different. The cutout for the power steering pump pulley causes a mounting issue with the RMCR bracket. There is also a threaded mounting boss missing on the blower for the Vortech kit that the RMCR setup needs.
To More Vortech Problems
Old Oct 13, 2004 | 02:33 PM
  #78
MelloYellow
Good info, thanks.
Any relation between PTC and RMCR?
Old Oct 13, 2004 | 02:37 PM
  #79
COLORADO FRC
Not that I'm aware of. RMCR created all of their own brackets and special parts. The battery relocates to the trunk too.
Old Oct 13, 2004 | 02:45 PM
  #80
7LitreC5's Avatar
7LitreC5
There is an indirect link. Mark, the owner of RMCR used to work at SVO. SVO was the original developer of what is now the PTC kit. Mark of RMCR was one of the original developers of the SVO kit.
Good info, thanks.
