C6 Shifter Installation
Old Feb 24, 2005 | 06:25 AM
  #41
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
What an incredible review! Patches is the man!!!
Old Feb 24, 2005 | 06:50 AM
  #42
Classic-Chevy-Guy's Avatar
Classic-Chevy-Guy
Patches,
For the ease of installation, is it feasible to order the Stock Insulator for the C6, and just have it bolt in, since the insulator for the C5 does not fit, rather than having to reverse the C5 stock insulator?
Old Feb 24, 2005 | 06:57 AM
  #43
Patches's Avatar
Patches
Actually, Ralph, you should try your stock insulator first. If you look at the area around my shifter, you'll notice a lot of extra insulation and wiring that is not normally there in a stock C5. That could be hindering the correct fit of my isolator over the C6 shifter. My advice is to try your's first and then report back as to how it fits.
Old Feb 24, 2005 | 07:30 AM
  #44
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
Excellent write-up...as is expected...
I would probably stay with the Hurst but I do appreciate the smooth easy stroke of the C5 or C6 shifter...
Thanks again!
Old Feb 24, 2005 | 09:07 AM
  #45
97Black's Avatar
97Black
Default leather color
It looks like the black leather on the shift handle matches ours. Can you confirm this? Thanks.
Old Feb 24, 2005 | 05:56 PM
  #46
dajael
Guest
Posts: n/a
Thanks to Patches and his meticulous write-up as well as his "Hurst Install" write-up I have ordered my C6 kit from Bob & Tom @ Fichtner Chevrolet (BTW...those guys are a class act ). Should be getting it by Tuesday...and installing it on Friday.
My C5 is a DD and does not see track time so convenience and ease of use are priorities for me instead of feel. Patches review seemed to be leaning more toward my specific needs in a shifter upgrade.
Thanks again!!!
Old Feb 24, 2005 | 07:02 PM
  #47
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Default C6 Shifter in a C5
________________________________________ ____________________
[dajael]Thanks to Patches and his meticulous write-up as well as his "Hurst Install" write-up I have ordered my C6 kit from Bob & Tom @ Fichtner Chevrolet (BTW...those guys are a class act ). Should be getting it by Tuesday...and installing it on Friday.
Thanks again!!!
[/QUOTE]
Same here.....had the Hurst, found it took too much effort. I like the ease of the stock shifter. Called Fichtner and ordered the newer model. I stopped by one of my local dealers first (Palanker, West Babylon) to sit in the car and see if I liked the way it felt. I realize the throw in my car may be a little longer than the C6, I believe there is an internal upgrade in the transmission in order to achieve a shorter throw.
Old Feb 24, 2005 | 07:12 PM
  #48
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Fantastic (as always) write-up Patches. Saved for later..........
Paul
Old Feb 24, 2005 | 07:41 PM
  #49
vetpet's Avatar
vetpet
Thanks Patches for articulating your opinions so well. You're on the money when it comes to shifter choice. It's all a matter of preference and use. Knowing what to expect from first hand experience is invaluable in helping each of us make an informative decision.
Kudos Dude
Old Feb 25, 2005 | 08:06 AM
  #50
vetdude's Avatar
vetdude
Let us know how it goes!
Old Feb 25, 2005 | 10:01 AM
  #51
snide's Avatar
snide
CI 4-5-7-8-9-10 Veteran
St. Jude Donor '07 thru '11
Old Feb 25, 2005 | 10:03 AM
  #52
dajael
Guest
Posts: n/a
Will Do...
Not sure yet if I'll be installing it myself or letting the Chevy dealer do it since my car is going in for some warranty work on that day. i.e. doubt there will be any pictures but then again Patches pretty much took care of all of that. I WILL however give a review of the shifter, since Patches was running the Hurst, he was basically referring to the stock set up from memory. I might be able to be a little more comparative of the original C5 shifter to the new C6 since I'm doing a stock replacement instead of a aftermarket shifter to C6, although I'm sure I won't be able to articulate my opinion as well as Patches did even on his worst day
Old Feb 25, 2005 | 11:43 AM
  #53
KenI's Avatar
KenI
Old Feb 25, 2005 | 03:19 PM
  #54
vetpet's Avatar
vetpet
Patches, could you clarify something for me. Is the actual base that the shifter is bolted to different in the C5 and C6? Your pictures show the shifter including the base. Looking at the pictures, the base doesn't look different. I've got a C6 shifter and was going to unbolt my C5 shifter (4 bolts) and bolt the C6 in place. My buddy gave me the C6 shifter because he replaced it with a Hurst. All we did was unbolt the old one and bolt in the Hurst. We even used the plastic ball cover from the C6 shifter on the Hurst.
Thanks,
Old Feb 25, 2005 | 03:43 PM
  #55
Patches's Avatar
Patches
Same base, vetpet.
Old Feb 25, 2005 | 05:53 PM
  #56
cuspid's Avatar
cuspid
How about a GTO shifter next then the CTS-V
Old Feb 25, 2005 | 07:57 PM
  #57
AllCammedUp's Avatar
AllCammedUp
Patches,
Great reveiw, man. I always enjoy reading your posts - definitely good info and something to be learned every time.
I'd LOVE to have the C6 shifter ****, but keep my B&M Ripper shifter. What would it take to get the C6 **** to fit the C5 stock shifter/hurst/B&M do you think?
I'm currently using a stock-threaded Ken King shifter ****, but I'd really like to look at an alternative!
To C6 Shifter Installation
Old Feb 25, 2005 | 08:15 PM
  #58
vetpet's Avatar
vetpet
Patches, thanks for the reply.
In regards to using the C6 shift **** with your B&M, the C6 shift know does not thread on. It is held in place with a set screw. You would have to drill a hole in the shaft and then thread it to accomodate the set screw. The other thing you have to measure is the diameter of the B&M shaft vs the C6. The C6 shaft is larger in diameter than the C5 one and also the Hurst. I don't know what diameter the B&M is but would be willing to bet that it's the same as the Hurst. You'd need to put some kind of sleeve over your B&M in order to make it larger and properly fit the C5 shifter ****. This will keep it snug as well as insulate it from the steel shaft.
Old Feb 26, 2005 | 12:56 AM
  #59
Awsum98's Avatar
Awsum98
Originally Posted by DanielW
I really like that ****, but wanna keep my hurst, Anyone know where I can get the **** only????
gGst20psi@aol.com sells them for $70.bucks and they screw right on the C5 shifters.. i got one on mine with a B&M shifter and it fits and looks great !!
Old Feb 26, 2005 | 08:05 AM
  #60
AllCammedUp
Thanks for the reply vetpet - that's what I thought would be the case.
Could you please post a pic of your shift ****? I don't mean to refute what you're saying, but based on the information above and from what Patches says in his write-up, it would take a different thread, etc. to make this work. Are you sure the **** you have is the 'genuine' C6 **** and not a knock off? Thanks a lot - I'm not meaning to be trouble, I'd just like to see the **** before I purchased from your contact.
