C6 Shifter Installation
As far as the leather color of the ****, it's just a half-shade different than my stock leather but I'd expect that since they're not matched hides. My Hurst **** is futher off my stock leather and it's not at all noticeable in the context of the interior due to how dark it normally is in the cockpit. It takes the camera flash to be able to see the mismatch. Here's the C6 **** next to my steering wheel. The **** is slightly lighter than my wheel leather and has a hint of brown in it when viewed closely in natural light.
Here's the C6 **** laying on my Vette Essentials short boot which matches my interior very closely.
And, here it is compared to my Hurst ****. Notice how similar they are. I modified and installed this **** long before the C6 was released and knew I had the right-feeling **** for me the day I installed it. I was pleasantly surprised when I first saw the C6 **** since it was so similar to my preference. This test confirmed I like this shape best.
Finally, I thought a shot of all three, the Hurst, The C6 and the stock C5 shifters side-by-side would be interesting. I measured the C6 shaft and it is ~.575" in diameter while the C5 shifter is a 9/16"-18 thread, which is slightly smaller (.5625" nominal). The C6 **** bore is ~.610" in diameter. The C6 shifter is 1.00" shorter than the stock C5 shifter.
Once again, thanks to Ralph for having this shifter sent to me to test. Ralph, the C6 shifter is repacked and ready to ship on Monday. You should receive it this week. I'm sending the modified rubber plug just in case you need it. Enjoy!
Great instructions and easy to follow pictures.
Thanks a lot - looking forward to the 'drive test'
I called the dealer Friday and ordered them to install a C6 shifter and I'll pay the difference.
I've used the Hurst but didn't like the spring tension. If I can get close to C6 movement I'll be happy.
I'm e-mailing this to the service manager now
Thanx Patches!
Michael
Ken
VetteEssentials.com
For anyone who is interested, the guy's e-mail is gst20psi@aol.com, and here's a link to his e-bay store:
http://stores.ebay.com/Gst20psi
Ken
VetteEssentials.com
Call me and I'll fix you up.
248-852-9030
www.VetteEssentials.com
Ken
248-852-9030
Ken
Patches, my install did not require the use of the 2 inch plug. Do you think that your stock seal was stretch due to the 2 inch plug and a new factory seal would of worked with out the plug? Nice write up.
Hurst shifter with 1.5" plug.
WildBill_64, the isolator plug I used can be bought in the plumbing section at Lowes. It's a Fernco 1.5" rubber pipe plug. It was originally posted here by another member as a solution to help quell noise and vibration inherent in aftermarket shifters like the Hurst. Below is a pic of the 2" plug although the 1.5" works a bit better.
It took me 2 hours to do. Half of that time was to remove the old shifter. Looked like someone had tried to remove it before and messed it up a bit and I couldn't get hold of it because the top was all broken. Had to drill it out. Would have easily taken an hour if the key on the old shifter would have been in good shape.
