Clear Tail light Lens
Old May 12, 2006 | 11:31 PM
  #81
GettReal's Avatar
GettReal
Originally Posted by 16Again
That's pretty cool, only saw them on 1 other car. What bulbs did you use? How did you modify the housing for the lens? Sory for the questions.
No prob... I did the same thing you did... I used a box cutting knife to cut into the resin that holds the 2 pieces together but ended up breaking a little of the red off.. I used silicone to adhere them back together so i wouldnt get any moisture inside and used these bulbs.. just red "3057's"
PAGING SeaLawyer... I will look for them and if I find them, and you still want them, your name is on them. I also am doing quite a bit of biz in Jacksonville right now.. so when you are back maybe I can even personally drop them off to you.
Old May 12, 2006 | 11:39 PM
  #82
GettReal's Avatar
GettReal
SeaLawyer (in my other thread) is in Iraq and really wanting a set. If your planning on letting them go would you consider sending him a PM? thanks
Bob
Old May 12, 2006 | 11:40 PM
  #83
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Cool Steve i sent Vaughn (SeaLayer) a PM with your info.
Old May 12, 2006 | 11:41 PM
  #84
16Again's Avatar
16Again
Man you just have got to love the members we have here. Very nice of you Steve.
Old May 12, 2006 | 11:42 PM
  #85
DJMRTS's Avatar
DJMRTS
Flush mount those!
Old May 12, 2006 | 11:48 PM
  #86
Yello95's Avatar
Yello95
St. Jude Donor '11
I have installed a very UNIQUE (only saw 1 member here that has this) mod. While it's not for everyone, it's very different and I happen to think it makes my C5 just a little bit different. The RED 25 bulb LED's are in route, so I have no pictures with the lights on..... YET. This is a lot of work, but in my opinion well worth it. I will order the CLEAR 3rd brake light next week. Hope you all like the new look.
Bob
Strange to see clear lenses but it looks really nice with silver...If they light up red then that is going to be very cool...hope you don't have a problem with the "law"
Old May 12, 2006 | 11:59 PM
  #87
torch2000vert's Avatar
torch2000vert
I think they look very cool on your silver car Flush mount would look even better IMO.
Old May 13, 2006 | 12:04 AM
  #88
Zcrazy2002's Avatar
Zcrazy2002
where can i get that clear 3rd brake light, do you have the link to the ebay store?
Old May 13, 2006 | 12:19 AM
  #89
C5BlkVette's Avatar
C5BlkVette
St. Jude Donor '03 thru '08,'16,'18,'21-'22,'24
EBay item number: 8064883842. ProCarParts is the seller who sells them.
Andy
Old May 13, 2006 | 01:57 AM
  #90
C5VetteLS1's Avatar
C5VetteLS1
St. Jude Donor '06-'07-'08-'09
My car is silver so I will not get the same look as Jason above. However, i'm sure it will be very distinctive. Bulbs will be RED Led's. Is it legal?? Well I have no idea at this point. Once it's done i'll walk next door to one of my neighbors (6 on this block are Police or Hwy Patrol) And see what they think. The lens is reflective however it is NOT RED REFLECTIVE.
In case you're not aware, NOBODY makes an LED bulb as bright as standard bulbs. At least not yet. LED bulbs are very expensive compared to standard and totally ineffective. We've been researching these for the past 6 months. Another draw back is that they are not plug & play. You would need to splice a 6 ohm equalizer into each tail light, or change your flasher, to avoid the turn signal strobe light effect. I'll bet they'll look great when installed though I'm looking forward to seeing the completed project
As far as legalities ... look at all the SUV's running around with clear tail light lenses. They light up red, but they're visually clear. I think several are OEM as well.
Good luck with your project,
Richard
Old May 13, 2006 | 03:37 AM
  #91
JohnTheStigGalt's Avatar
JohnTheStigGalt
PM sent Steve - thanks!! Richard, I already have the sequential turn signals on mine which have an adjustment **** allowing you to change the load, so that won't be an issue.
Old May 13, 2006 | 06:47 AM
  #92
16Again's Avatar
16Again
Richard
Richard the bulbs and resistor take about 2 minutes to install. The resistor splices in to the line and the bulb plugs into the existing socket. Now as for cost, yes they are much more. I paid $7.95 per bulb so yes, they are expensive. I temporarally installed Amber bulbs as thats what a friend gave me. My concern is the NARROWNESS of the pattern with this set-up. I am using the 25 bulb lights and hoping that the red is a wider pattern during the day. At night it looks great. Hopefully this pic of the bulb works.
Pic won't work but its the 25 light bulb.
Old May 13, 2006 | 06:50 AM
  #93
16Again's Avatar
16Again
Thanks all for the pat on the back and the kick in the tail. I might try the flushmount set-up after I get these the way I like.
Old May 13, 2006 | 07:12 AM
  #94
BobbyG's Avatar
BobbyG
Did you use the Skill-Saw in the photo to do the install???
Looks good, but I wonder how they'd look against a yellow background?
Bob
Old May 13, 2006 | 07:25 AM
  #95
16Again's Avatar
16Again
Bob
No that was from my "HONEY DO" list earlier in the day, i'll put everything away today.
Here are a few pics I just took this morning, with the temporary just to see if LED's work Amber LED's installed. This is in the garage and it's just the parking lights, no brakes or blinkers. I think i'm going to really like this.
Old May 13, 2006 | 08:11 AM
  #96
ebubman's Avatar
ebubman
bub
Old May 13, 2006 | 10:37 AM
  #97
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
I like them on your car, Bob...if they hassle you on the red reflector part just slap on some Pep Boys mudflaps with the reflectors on them...he he
To Clear Tail light Lens
Old May 13, 2006 | 11:40 AM
  #98
16Again's Avatar
16Again
In the words of Bub......
Old May 13, 2006 | 12:03 PM
  #99
C5VetteLS1's Avatar
C5VetteLS1
Old May 13, 2006 | 12:11 PM
  #100
C5VetteLS1's Avatar
C5VetteLS1
You may want to consider these to spread the light out better. A very clever idea. They are admittedly dimmer than OEM as well, but they're working on their next generation of LEDs that they expect to be brighter than standard bulbs. They expect this next generation to be available around October. They're trying to have them ready for the SEMA show. We'll be testing them as soon as they're available. Going to be costly though. You can check them out at the following link: http://spiderlite.com/
