Clear Tail light Lens
Old May 13, 2006 | 12:17 PM
  #101
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Originally Posted by C5VetteLS1
You may want to consider these to spread the light out better. A very clever idea. They are admittedly dimmer than OEM as well, but they're working on their next generation of LEDs that they expect to be brighter than standard bulbs. They expect this next generation to be available around October. They're trying to have them ready for the SEMA show. We'll be testing them as soon as they're available. Going to be costly though. You can check them out at the following link: http://spiderlite.com/
That's a FANTASTIC new bulb. That thing expands in the housing. However at $45.00 each, that's a really expensive bulb. Hopefully my current set-up will be good until the release of the new brighter LED's your talking about. Once the new generation is released i'll bite the bullet and get them.
Old May 13, 2006 | 01:53 PM
  #102
16Again's Avatar
16Again
As requested here are outside pics.
Just a pic, no lights on
All photos that show lights are AMBER (waiting for red to come in) LED's on DRIVERS SIDE
Standard White bulbs on passenger side.
Parking lights on from approx. 20' away
Drivers side signal while tail light is on
Brake lights with parking lights on, notice the difference.
Same shot as above but closer
Old May 13, 2006 | 02:02 PM
  #103
16Again's Avatar
16Again
Brake lights with parking lights on, notice the difference?
Old May 13, 2006 | 02:11 PM
  #104
DJMRTS's Avatar
DJMRTS
Now you just need the matching 3rd brake light!
Old May 13, 2006 | 02:32 PM
  #105
16Again's Avatar
16Again
Your 100% correct I'm very concerned about how much these leds bleed out when in the sun. I think I might change the LEDs single bulb to a bunch of single bulbs individually mounted in the housing OR give a try to the bulbs C5VetteLS1 suggests in the other thread. http://spiderlite.com/ I am not removing these lenses so I just need to find a safe (bright enough) way to fill the housing.
Old May 13, 2006 | 03:27 PM
  #106
C5VetteLS1's Avatar
C5VetteLS1
St. Jude Donor '06-'07-'08-'09
That looks awesome Once you get that 3rd brake matched, you'll really be styling Looks like a worth while effort to me!
Congrats,
Richard
Rear side markers would really finish it off nice as well.
Old May 13, 2006 | 05:12 PM
  #107
16Again's Avatar
16Again
Congrats,
Richard
Thanks, i'll order the 3rd. brake light this week. Question for you. The last picture I posted above shows the Amber LEDs on the driver side and the White standard bulbs on the passenger side. Do you think RED LEDs will give me a bright light during daytime hours? Am I better off buying the standard bulbs colored red? Of course I really want to see the new bulbs that you eluded to earlier that are coming out in October.
Bob
Old May 13, 2006 | 08:24 PM
  #108
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Bob, I like them on your silver car They look
And major kudos for doing something unique and standing up to the sheep
Stephen
Old May 13, 2006 | 09:16 PM
  #109
shoribs's Avatar
shoribs
Cruise-In VIII Veteran
St. Jude Donor '07
Hey Bob, saw the pictures of your car with the clear lenses installed, looks great, I have searched high and low for them, checked with all the aftermarket companies, asked everyone I knew in the parts related business to help me find them, no luck. I already have the clear Euro front corner lights, the clear rear side markers, and the clear LED third brake light. so I have ordered a set of the LED Euro tail lights, they look like the ones on QuikZilvers car, I guess this is close as I'm going to get to the clear lenses. I got everything Thur ProCarParts. I'll let ya know how it comes out................Jim
Old May 13, 2006 | 09:17 PM
  #110
16Again's Avatar
16Again
Stephen
I knew I could count on you Stephen.
Old May 13, 2006 | 09:21 PM
  #111
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
Originally Posted by 16Again
Thanks for the compliments guy's. The new Red Led's will be here on Tuesday and I certainly will pull her out of the garage and get some pics.
Am I interpreting the Florida code correctly? According to this I should have no problem as it clearly states EMIT RED when LIGHTED
Code 316.221
(1) Every motor vehicle, trailer, semitrailer, and pole trailer, and any other vehicle which is being drawn at the end of a combination of vehicles, shall be equipped with at least two taillamps mounted on the rear, which, when lighted as required in s. 316.217, shall emit a red light plainly visible from a distance of 1,000 feet to the rear, except that passenger cars and pickup trucks manufactured or assembled prior to January 1, 1972, which were originally equipped with only one taillamp shall have at least one taillamp. On a combination of vehicles, only the taillamps on the rearmost vehicle need actually be seen from the distance specified. On vehicles equipped with more than one taillamp, the lamps shall be mounted on the same level and as widely spaced laterally as practicable. An object, material, or covering that alters the taillamp's visibility from 1,000 feet may not be placed, displayed, installed, affixed, or applied over a taillamp.
...thats correct...
...and at least two stop lamp...
316.222 Stop lamps and turn signals.--
(1) Every motor vehicle, trailer, semitrailer, and pole trailer shall be equipped with two or more stop lamps meeting the requirements of s. 316.234(1). Motor vehicles, trailers, semitrailers and pole trailers manufactured or assembled prior to January 1, 1972, shall be equipped with at least one stop lamp. On a combination of vehicles, only the stop lamps on the rearmost vehicle need actually be seen from the distance specified in s. 316.234(1).
316.217 When lighted lamps are required.--
(1) Every vehicle operated upon a highway within this state shall display lighted lamps and illuminating devices as herein respectively required for different classes of vehicles, subject to exceptions with respect to parked vehicles, under the following conditions;
(a) At any time from sunset to sunrise including the twilight hours. Twilight hours shall mean the time between sunset and full night or between full night and sunrise.
(b) During any rain, smoke, or fog.
(c) Stop lights, turn signals, and other signaling devices shall be lighted as prescribed for use of such devices.
The color red is not required...
btw I love the clear lens...
  #112
PUREFUN's Avatar
PUREFUN
St. Jude Donor '07-'08
Stephen
I totally agree Saw them on a white vette on this forum. And the vette looked outstanding.....
Old May 13, 2006 | 09:28 PM
  #113
16Again's Avatar
16Again
Originally Posted by stuart
...thats correct...
Man tonight must be my lucky night. TWO FORUM LEGENDS giving How cool is that? Thanks
Old May 13, 2006 | 09:32 PM
  #114
StuzVette's Avatar
StuzVette
...I may not get to enjoy the clear lens on StuzVette without changing a lot of the looks...
but I can enjoy them on your vette Bob...
peace
Stu
btw ...see you all in BG
Old May 13, 2006 | 09:35 PM
  #115
Freestyler's Avatar
Freestyler
some thoughtful responses - and constructive
glad to see your big enough and ugly enough to hear both sides.
personally,
i like em on yours too (ya, that white vette with em really POPS)
Band Of Brothers.
Amen.
  #116
16Again's Avatar
16Again
Jim, not to ruin your night but as you read above, another member has a set he is not using. I believe that set is going to one of our HERO's in IRAQ. Be patient, they do come along every once in awhile.
Old May 13, 2006 | 09:39 PM
  #117
StuzVette's Avatar
StuzVette
personally,
Band Of Brothers.
Amen.
Preach on...
To Clear Tail light Lens
  #118
16Again's Avatar
16Again
personally,
Band Of Brothers.
Amen.
Thanks Here is the white car I got the idea from. I fell in love the moment I saw it. His is painted white inside the housing. Mine I left silver inside as I thought it would match my car nicely.
Old May 13, 2006 | 09:49 PM
  #119
C5VetteLS1's Avatar
C5VetteLS1
Bob
I'm sorry Bob, but I don't have the answer to that. You'll just have to do some experimenting. I'm fairly certain that a red tinted incandescent bulb will be dimmer than standard clear. If that's factual, red LED's may actually illuminate brighter with your clear lenses.
Good luck with that,
Richard
Old May 13, 2006 | 09:50 PM
  #120
StuzVette's Avatar
StuzVette
looks cool...
like the tag great white...
with white and the clear...mine might read "Got ICE"
