Clear Tail light Lens
Old May 13, 2006 | 10:23 PM
  #121
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Old May 13, 2006 | 10:36 PM
  #122
Vetteran's Avatar
Vetteran
St. Jude Donor '03-'05-'06-'07
Originally Posted by stuart
looks cool...
like the tag great white...
with white and the clear...mine might read "Got ICE"
Bob, I find them to be interesting. Probably not for me. But if you like them go for it.
The "got ice" look is very interesting too Stu!
Old May 13, 2006 | 10:46 PM
  #123
GB Vette's Avatar
GB Vette
CF Over the Hill Member
Cruise-In IV Veteran
CI-4 Car Show Winner
Cruise-In VI Veteran
CI-6 Car Show Winner
Cruise-In VII Veteran
CI-7 Car Show Winner
St. Jude Donor '03-'04-'05-'06-'07-08-'09
NCM Ambassador
I like it It's different and something eveybody else doesn't have Well done
Old May 13, 2006 | 10:48 PM
  #124
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Originally Posted by pewter99
That's just WRONG!!!
I am the Rice King!!!
Old May 13, 2006 | 10:50 PM
  #125
pewter99's Avatar
pewter99
yeah..but this is Bob....BTW..I didn't know Home Depot even sold rice
Old May 13, 2006 | 10:53 PM
  #126
Rhode Warrior's Avatar
Rhode Warrior
Bob, I like them on your silver car They look
And major kudos for doing something unique and standing up to the sheep
Stephen
I second that. Never succumb to the "sheep mentality". If everyone had the same car it would be pretty boring.
Old May 13, 2006 | 11:00 PM
  #127
RFJohnston's Avatar
RFJohnston
From: Russellville, Kentucky 1967 Sting Ray & 2001 C5
Originally Posted by 16Again
when lighted as required in s. 316.217
What does this one say?
Old May 14, 2006 | 09:37 AM
  #128
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Sent you a PM with th requested info.
Old May 14, 2006 | 09:41 AM
  #129
16Again's Avatar
16Again
Originally Posted by C5VetteLS1
I'm sorry Bob, but I don't have the answer to that. You'll just have to do some experimenting. I'm fairly certain that a red tinted incandescent bulb will be dimmer than standard clear. If that's factual, red LED's may actually illuminate brighter with your clear lenses.
Good luck with that,
Richard
Richard, I spoke to a buddy last night, he seems to think a regular red bulb that lights from all directions will work better with the silver reflecting material inside the housing. I might just try this as I think his idea has some merit. A LED bulb only shines forward so it cannot use the reflective portion (behind the bulb) like a standard filiment bulb can. As you say trial and error, i'll report back later this week which set-up works best. Thanks for the help.
Bob
Old May 14, 2006 | 10:18 AM
  #130
Freestyler's Avatar
Freestyler
what about a small diameter red tail light being installed inside the vette one & made to fit behind
the clear corvette lens?
for a look you have the clear with a translucent/red tone behind it, then when it lights, it should be a typical enough glow?
Old May 14, 2006 | 10:24 AM
  #131
16Again's Avatar
16Again
Very similar to what my buddy said. I am using the factory housing and wires so I can just use a red bulb if i'm forced to. What I am trying to eliminate are 2 problems. 1st is just what your eyes see, I don't want to see any color behind the lens. I want it to be clear, if I use a standard red bulb, that will likely be seen even with all lights off. My second and most important issue is SAFETY. LEDs tend to bleed out and don't appear as bright as a standard bulb in sunlight, this is going to drive me nuts finding the answer. That said, I will come up with a SAFE solution.
Old May 14, 2006 | 10:33 AM
  #132
Freestyler's Avatar
Freestyler
what about your wheels - what are ya gonna do there?
speedlines/alco's in matching color or bbs?
Old May 14, 2006 | 10:48 AM
  #133
16Again's Avatar
16Again
99% of the time my baby wears Polished CCW drag rims wrapped in slicks and skinnies.
Old May 14, 2006 | 10:57 AM
  #134
NY~FX's Avatar
NY~FX
Default kudo's
Definitely nice look !
Altho try this on, if you half-mirror (see thru mirror ) some flush mounts,
then your color/tonal variations are even more subtle and elegant.
... but do pump up the number of red leds or some ricer will back end u .
Old May 14, 2006 | 12:21 PM
  #135
16Again's Avatar
16Again
I'm afraid I don't understand. How would that work? The inside of the housing is a shiny silver color already. I think the direction that the LEDs shine (straight ahead) does not allow the reflection inside the lens to happen. A regular bulb lights from the entire glass surface, I believe thats why they "appear" to fill the housing when lit. Keep the help coming, this is going to be safe if it kills me.
Old May 14, 2006 | 12:45 PM
  #136
16Again's Avatar
16Again
Thanks for the merge Grumpy.
Old May 14, 2006 | 03:56 PM
  #137
16Again's Avatar
16Again
Tried the red sleeve (goes over standard bulb) today. That works very well, even in sunlight. I'm going to try a real RED bulb tomorrow and see how that works, before I try the full RED LED...
To Clear Tail light Lens
Old May 14, 2006 | 09:03 PM
  #138
shoribs's Avatar
shoribs
Cruise-In VIII Veteran
St. Jude Donor '07
Can someone tell me what kind of what kind of wheels thoes are on the white coupe ? thanks.
Old May 14, 2006 | 09:11 PM
  #139
16Again's Avatar
16Again
Jim I would e-mail Jason (he has not been on line for the last week or so) jfrc is his screen name here. Good Luck
Old May 15, 2006 | 12:10 AM
  #140
PUREFUN's Avatar
PUREFUN
St. Jude Donor '07-'08
Thanks Here is the white car I got the idea from. I fell in love the moment I saw it. His is painted white inside the housing. Mine I left silver inside as I thought it would match my car nicely.
Yup that's the one i was talking about in a previous post about your vette...His and yours both look
